Results 1 to 6 of 6
Thread: Help me decide which engine to use.
    Apr 2014
    600
    11
    Points: 600, Level: 11
    Level completed: 50%, Points required for next Level: 50
    Help me decide which engine to use!
    Parts I have:
    EJ25D heads tapped for turbo
    Polished EJ25D intake manifold
    STi yellow injectors
    TD05H 16g turbo
    Walbro 255lph fuel pump
    Ver 1 STi top mount (I think)
    forge BOV
    Aluminum turbo inlet elbow
    Undecided on Engine Management.
    ej22T complete engine. 160k on it.
    Ej257 shortblock rebuilt. 60k before rebuild.
    I would like to see 300-350hp but would prefer it to be a reliable good all around street car rather then make a number on a dyno.
    Which block would you use?
    Sent from my iPhone using Tapatalk
    SLi Resident 86bratman's Avatar
    Jul 2013
    Tazewell VA
    739
    4,313
    41
    Points: 4,313, Level: 41
    1000 Experience PointsOverdriveVeteran
    Re: Help me decide which engine to use.
    I'd personally run the ej22t, but I'm bias against the ej25 for my own reasons. But looking at the maths of it, an ej257 with 25d heads is 9:1 compression, and still has weak ringlands so tuning would have to be spot on. The 22t with those heads will have a much lower cr (7.7:1) on stock thickness head gaskets, so you'll be lacking some low end unless you go for a set of pistons made for that combo.
    My 1997 Legacy L
    Fuelly
    Apr 2014
    600
    11
    Yeah, I'm aware I need to run thinner gaskets on the 2.2t. Seems a lot of people over on other forums have had success running the 25d gaskets
    t3h ub3r m3mber Garrison's Avatar
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Points: 6,153, Level: 51
    Level completed: 2%, Points required for next Level: 197
    EJ257 every day, all day.
    More displacement = more torque = more smiles
    You could push 400hp (300whp) on that setup all day long
    I've been to boost and back again my friends... and it was good
    "FNG" blankdeluxe's Avatar
    Mar 2014
    Longmont CO
    55
    880
    15
    Points: 880, Level: 15
    22t gets my vote.
    97 L running a 22t on a VF-11 with a few other odds and ends
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    bratman is correct on the 7.7CR which is too low to get a decent daily driveable engine - sell the whole ej22t and get your engine management with the proceeds.
