Results 1 to 5 of 5
Thread: Downpipe and exhaust advice for my turbo project
    "FNG" SubaruKenny_d's Avatar
    Dec 2012
    Lehigh Valley, Pennsylvania
    78
    3,739
    38
    Points: 3,739, Level: 38
    Level completed: 60%, Points required for next Level: 61
    Alright so I recently bought a TD04 turbo off a wrx that I will be adding to my 01 legacy. I was snooping around on nasioc abut catless downpipes and some other minor things about the project. What is your input on downpipes? I was going to try to cut on cost and possibly go with an ebay special, OR go with a higher end dp ie: Invidia, Cobb, Grimm Speed, etc. Secondly, should I buy a bell mouth or divorced, I want as much turbo whistle as possible out of it. *I plan on running headers w/ catless up pipe to the catless dp then to a 3" straight pipe back. Give me some feedback on your setups!
    Here is the post I was reading regarding dp's: http://forums.nasioc.com/forums/showthread.php?t=445812
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Points: 16,569, Level: 82
    Re: Downpipe and exhaust advice for my turbo project
    eBay specials are fine. I've run one of the $80 ones for years. The difference between bellmouth and divorced is so little that it's not worth the extra price. Just grab an eBay special and be done.
    Jul 2014
    Los Angeles, CA
    15
    3,179
    34
    Points: 3,179, Level: 34
    Level completed: 86%, Points required for next Level: 21
    you should feel a good difference with any aftermarket whether it be ebay or invidia
    SLi Resident Cervantes's Avatar
    Apr 2010
    Okinawa, Japan
    631
    6,695
    53
    Points: 6,695, Level: 53
    Level completed: 73%, Points required for next Level: 55
    I like the divorce style DP. When you go aftermarket DP, specially catless, you'll need a way to control boost. Catless can cause boost spike and over boosting. That can cut down the life of your turbo or cause your car to go into limp mode.
    2000 Subaru Legacy Blitzen SOLD
    2001 Subaru Forester STI
    2000 Subaru Impreza S203 Swap
    Dec 2009
    Kaysville UTAH
    1,823
    9,426
    Points: 9,426, Level: 65
    I bought an used eBay bell mouth for $15 and have had zero issues with it in the 5 years I've had it. The guy before me had it for years as well.
