Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 121 to 150 of 233
Thread: nepbug's 01 Outback - 1/22/17 Eff Me! Gut check time!
  1. #121
    SLi Lurker nepbug's Avatar
    Sep 2014
    Denver, CO
    411
    4,977
    Points: 4,977, Level: 45
    Come to think of it, I swapped the H6 logo from my 04 beige console to the 03 black console.. The large and small logo inserts were interchangeable within the same console type. I guess I assumed that the 01 console logo was the same as well.
    So a little more info on this front. My console is from an 03, I pulled an AWD badge from an 02 double-cup center console and it was the same style badge as my 01. Thus it seems there are two different style badges and they don't correspond with single vs double cupholder, but instead are 00-02 and 03/04.
  2. #122
    Sep 2014
    Denver, CO
    411
    4,977
    17mm Baja Turbo Rear Sway Bar Upgrade
    I further upgraded my rear sway bar today. I started with a 14mm, then moved to a 16mm and now I have a 17mm (out of an 05 Baja Turbo).
    While I was at it I also replaced one of my dying endlinks, so that's quieter, and I also installed the rear passenger mudflap I was missing.
    The 17mm bar is a noticeable improvement over the 16mm, I highly recommend it.
    Looking at the stiffness calculations. 17mm means I am 27% stiffer than with the 16mm and 117% stiffer than I was with the 14mm.
    If anyone is interested in a 14mm or 16mm sway bar for their 00-04, let me know I've got one of each extra now.
  3. #123
    Sep 2014
    Denver, CO
    411
    4,977
    High Flow Cat Wrap, Paint and Port and Polish
    I had some old header wrap that was not totally unusable so I decided to use it to wrap my high flow cat section.
    First the HFC was painted. Then I wrapped it. Then I sprayed the wrap with DEI Black High Temp Silicone Coating. It looks a bit ratty, but should serve it's purpose.
    Then I did a little port and polish on the inlet. Carbide burr, 80 grit, 120 grit and then 240 grit; I didn't feel the need to go finer than that. While doing the PNP I stuffed a rag in the tubing to prevent debris from getting into the cat.
    I'll let the paint cure for at least a week before installing it, I've heard that DEI paint can smoke quite a bit during curing.
    One note, I really didn't care for the spray nozzle on the DEI paint, I much prefer the Duplicolor and VHT style nozzle.
    July 19, 2015 Edit:
    I decided that I wanted the cat wrapped, so i did that and hit it with some paint again. I'll be looking to install this in a few weeks from now.
  4. #124
    Sep 2014
    Denver, CO
    411
    4,977
    Well, I've been inspired by @still_alive (https://sl-i.net/FORUM/showthread.ph...le-Port-Header) and @LeggyxPower (https://sl-i.net/FORUM/showthread.ph...188#post264188) to make my own set of UEL headers. I ordered the bends I need tonight. In my 20 minutes of looking I only found Jegs and Summit as having the necessary bends, and Jegs had the better price.
    Here's what I bought.:
    Jegs P/N 555-319213 (1 5/8" tubing with a 4" center-line radius)
    Jegs P/N 555-319310 (1 5/8" tubing with a 6" center-line radius)
    Cost came to ~$38 shipped to my door.
    Now I just need to pick up an OEM header and get my welder and the garage wired for it and this project will be a go. I could always take it in to work and weld it, but it's kind of a big awkward thing to bring in to do, but if I run into snags getting my welder setup, then that is what I will do.
    I'm not a big fan of the way the two sides join up, so I might splurge and buy a 2 into 1 collector here:
    http://www.coneeng.com/pdf/3-1%20&%2...ctor%20PDF.pdf
    I need to take some measurements first though.
  5. #125
    SLi Lurker LeggyxPower's Avatar
    466
    7,220
    56
    Points: 7,220, Level: 56
    Level completed: 35%, Points required for next Level: 130
    Never thought i would be an inspiration! best of luck . you gotta love something you've made more then something just bought done for you. Best part is its mad cheap!
  6. #126
    SLi nOOb shoguy's Avatar
    Dec 2011
    York, PA
    104
    4,349
    41
    Points: 4,349, Level: 41
    1000 Experience PointsRecommendation Second ClassO.G.
    what is stock diameter for sway bars? what was the 16mm bar sourced from?
    -Rick
    1998 Outback-Lift kit, plasti dip camo tan, 03 WRX calipers, slotted rotors, header, high flow cat, custom 2 1/4 catback, vibrant muffler, fresh rebuilt .020 over EJ25D w/ 251 block, strut tower bar, etc...
    04 35th anniversary H-6 Outback-Dynomax VT Muffler, power mode mod, not much else......yet!
    85 V65 Magna
    86 'Zuki Quadsport-fun machine
  7. #127
    466
    7,220
    56
    Quote Originally Posted by shoguy View Post
    THE ULTIMATE SWAY BAR THREAD This should answer you.
  8. #128
    Sep 2014
    Denver, CO
    411
    4,977
    00-01 have the 14mm bar, 02-04 got the 16mm
    Sent from my DROID RAZR HD using Tapatalk
  9. #129
    Dec 2011
    York, PA
    104
    4,349
    41
    Quote Originally Posted by nepbug View Post
    Thanks! I have the 04, so the only upgrade then except for aftermarket is to go to the Baja bar, I didn't know they changed between 02 and 03, that would be another reason why the 01 outback I had felt like a pig and this one is more planted
    -Rick
    85 V65 Magna
  10. #130
    Sep 2014
    Denver, CO
    411
    4,977
    Yeah, once I went to the 16mm from the 14mm, the difference was night and day. The rear springs are pretty soft, so a soft sway bar just exaggerates the problem.
  11. #131
    Sep 2014
    Denver, CO
    411
    4,977
    Window Tint
    Window Tint
    I finally got the Outback tinted. Always one of the best mods, functional and aesthetically pleasing in one swoop. I especially appreciate the front windshield strip, once you get used to having that it's frustrating to have a car without it. 3M 20% tint all around.
  12. #132
    Sep 2014
    Denver, CO
    411
    4,977
    I've acquired an OEM exhaust manifold from an 02 Forester for $10. DIY UEL headers parts are coming together.
  13. #133
    Sep 2014
    Denver, CO
    411
    4,977
    Heated Seat Install
    Heated Seat Install
    I did this a while ago, but never got around to writing it up. My Outback was a bare bones base model and came with non-heated cloth. In this scenario, the wiring isn't even there for the seat heaters. Through some scrounging I came up with a set of 01 LL Bean Heated leather seats and the wiring harness from an 03. The 03 harness falls a little short when using the 00-01 single-cup center console, so I had to extend the switch wires there.
    The start, bleh.
    First I started with the salvaged harness. I chopped out from the passenger foot well to the driver's seat. That looked like this:
    That is much more than you need. I pared it down to what was needed for heated seats only, this is what that looks like:
    Finally, tidy it up with some electrical tape.
    Now everything is ready to install.
    Pull out the seats, center console and door sill trim on the passenger side. You might need to pull out the b-pillar trim too, you need to get under the carpet.
    Your power and illumination hookup is in the passenger foot well, look for these connectors. The white connector with fewer wires (2 rows) will have the power, the white connector with more wires (3 rows) will be where you get illumination.
    See the two vacant pins at the far left of the middle row, those are for illumination.
    Insert the extracted pins on the backside of the connector (the other side of the connector is already populated with illumination wires.
    For the power, the connector is already populated, the light blue wire is what you want. I removed the sheath in a section and soldered-spliced in the heated seat harness.
    Hard part done. Run the wires under the carpet, don't forget to attach your ground for your new harness under the passenger seat, and poke the connectors out in the appropriate places.
    Put the interior back in and plug in the heater elements. Turn on car and power them up, enjoy.
    Power tilt from LL Bean seats, oh yeah!
  14. #134
    Sep 2014
    Denver, CO
    411
    4,977
    Easter morning oil change.
    Odometer: 186,357 miles.
    Changed using an OEM filter and Valvoline NextGen plus one full can of LubroMoly MoS2
  15. #135
    3,526
    I would love to have heated seats in my wagon, since its mostly a winter/work/drive to hockey car now. Buts its on its 3rd and probably last set of seats.
  16. #136
    Sep 2014
    Denver, CO
    411
    4,977
    Quote Originally Posted by 98legwag View Post
    I've installed heated seats in 5 Subarus, only once did I install new seats. It's totally possible to retrofit just the heater elements to your current seats.
    Here's a link to the write up for me adding them to my Forester, that's a little more detailed into how to go about it (I link to another post that goes into the element install part, but talk the wiring part).
    http://www.subaruforester.org/vbulle...8/#post2616794
    Also, the FSM does a really good job telling you how to disassemble a seat.
  17. #137
    3,526
    Yeah, I am much too lazy for that. Thanks though.
  18. #138
    SLi nOOb dna's Avatar
    Feb 2015
    WV
    142
    2,614
    31
    Points: 2,614, Level: 31
    Level completed: 10%, Points required for next Level: 136
    Overdrive1000 Experience Points1 year registered
    After my engine is finished, this will be my next interior project.
  19. #139
    Sep 2014
    Denver, CO
    411
    4,977
    Well, I've been in Moab for the last 5 days, but I managed to bleed the clutch while I was out there. And put in some work on two other legacies too.
    The Outback performed flawlessly on the 6 hour each way drives.
  20. #140
    Sep 2014
    Denver, CO
    411
    4,977
    Powder Coated Battery Tie Down
    I decided to do something about my rusting ugly battery tie down.
    Start:
    Media Blasted:
    Powder Coated:
  21. #141
    t3h ub3r m3mber superu's Avatar
    Mar 2010
    Moab
    1,032
    7,787
    59
    Points: 7,787, Level: 59
    Level completed: 19%, Points required for next Level: 163
    5000 Experience PointsSocialO.G.
    @nepbug i can only imagine how much better it could have performmed while baking the EL headers
  22. #142
    Sep 2014
    Denver, CO
    411
    4,977
    Quote Originally Posted by superu View Post
    LOL, I think the EL headers will only ever live on the Impreza, but I do have that high-flow cat earmarked for the OB.
  23. #143
    Sep 2014
    Denver, CO
    411
    4,977
    Well, I just purchased some new KYB dampers for the car. I went with the 04 Outback version as they have a higher damping rate than the 01 version.
    I went through RockAuto, used a 5% off coupon code, and there is a $40 mail-in rebate right now, so it came out to under $60 per strut shipped to my door. Score.
    These will be paired with some 05 Baja turbo springs for a lift of ~1.5 inches. I didn't want to use the Baja struts as that would give me even more lift and that is more than I am looking for. So, I will eventually have my Baja turbo struts for sale.
  24. #144
    Sep 2014
    Denver, CO
    411
    4,977
    BH vs BP vs Baja Turbo Strut Comparison
    Alright, a few comparison pics of different struts. I'll add some measurements later, but I wanted to get the pictures up and annotated.
    Front Struts. Left is new KYB 04 Outback, Right is 05 Baja Turbo.
    Bottom bolt to spring perch is the same, the strut tube above the spring perch is 3/4" longer on the Baja strut, strut stroke length is the same. So overall the Baja strut is 3/4" taller.
    Rear struts. Left is an 06 outback, middle is 04 Outback, right is 05 Baja turbo.
    The 05-09 OB struts has a sping perch that is lower than the others, but has the longest strut tube of the bunch. 04 Outback has the same spring perch height as the 05 Baja, but the Baja has a slightly longer strut tube (3/4"). The 04 OB and the 05 Baja have the same stroke as well, the 06 OB has a shorter stroke.
  25. #145
    Mar 2010
    Moab
    1,032
    7,787
    59
    @nepbug hmm, this is good info. It's reported the Baja swap lifts third gen OBs, but this indicates the OB's longer strut makes for a more cushioned ride in the third gens. This speaks highly for Baja springs alone. I'm awaiting THAT report! :glasses7:
    More fuel for my suspecting OBs are trending more towards the luxery side of the crossover market. The 4th and 5th gens fueled that fire substantially as well.
    Ooh and my 1000th post goes riiiiiiight here!
  26. #146
    Sep 2014
    Denver, CO
    411
    4,977
    I swapped in some new kyb struts with Baja turbo springs. Then this happened on the test drive, stupid aftermarket axle. A used WRX axle goes in tomorrow.
  27. #147
    Sep 2014
    Denver, CO
    411
    4,977
    Baja Turbo Springs on 04 Outback Struts
    I installed some 05 Baja Turbo Springs with some new KYB struts for an 04 Outback, here's the result:
    Here's the wheel arch height pictures.
    Rear Before:
    Rear After:
    Front Before:
    Front After:
    So it looks like 1-1.25" of lift in the rear and 1.75" of lift in the front. The front is likely greater because these were springs out of an 05 Baja Turbo with automatic transmission and I put them in a 5MT Outback.
    The ride is stiffer for sure now, reminds me of my Forester XT. So comfort is slightly down, but I've got better handling now and I'm not bottoming out over my neighborhood speed bumps. I like this change.
    I'll ponder whether I want to add in some 0.5" spacers in the rear or not in the future to even it out, but it doesn't look that noticeable to me.
    Edited to add:
    After driving around on them for a little bit now I really like the ride. Handling is improved even at the higher ride height. If I were to do autocross or even rallycross with this car I think these springs with some amount of coil cutoff would be a good choice, you could get back down to stock height and increase the spring rate a little further by doing that, cheap, yet quality stiff springs.
  28. #148
    Mar 2010
    Moab
    1,032
    7,787
    59
    As Yogi Berra once said, "It's like deja vu all over again."
    I've had one of those. . .
  29. #149
    Mar 2010
    Moab
    1,032
    7,787
    59
    the lift is impressive for just springs. Expect them to settle with time but you'll probably still be .75-1" in rear and 1-1.25" in front with settling. Maybe just .25" rear spacers. I think coparing front to rear at fender is deceiving b/c of differing fender clearances front-rear.
    It looks good t hough, again, i'm impressed with the lift from springs alone. I'd always assumed it was a spring-strut combo but this is good confirmation for Baja springs alone for useful lift in a 2nd gen OB.
    I bet it'll ride comparably better when loaded too, this will be a good, loaded, over the road/camping set-up.
  30. #150
    Sep 2014
    Denver, CO
    411
    4,977
    Except, then I went and took it apart and fixed it, now it's a spare.
