A log of maintenance-type things.
Replaced drive shaft 09/14
New transmission output shaft seal 09/14
Replaced the glove box/lower dash trim piece 10/14
Cleaned the IACV and replaced seal 10/14
Replaced cracked passenger head to airbox breather tube 10/14
Repaired Rear Defroster Grid in 4 places 10/14
Oil Change 10/16/2014 ODO: 178,352
PCV Valve Change 10/16/2014 ODO: 178,352
Replaced torn air intake flex section: 10/25/14
Fuel Filter 12/09/2014 ODO: 180,747
Oil Change 04/05/2015 ODO: 186,357
Strut Replacement 5/2/2015 : ODO ~188,000
Front Passenger Axle Replacement 05/03/15 ODO: ~188,000
Replaced Driver side axle because of torn boot 6/7/2015
Clutch Slave Cylinder Replacement 6/20/15 ODO: 190,866
Window Gusset Replacement 6/20/15 ODO: 190,866
Oil Change 08/22/2015 ODO: 194,817
Replaced seat back heater elements on both seats 11/8/15 ODO: 198,738
Replaced drive shaft again 2/7/16
Oil Change 2/10/2016 ODO: 201,380
Oil Change 07/5/2016 ODO: 209,111
Oil Change 10/2/2016 ODO: 215,100
Knock sensor replaced 12/27/2016 ODO: 219,120
Transverse Link Bushings replaced 12/28/2016 ODO: 219,150
