Page 1 of 2 12 LastLast
Results 1 to 30 of 45
Thread: Rougeben's 2005 Outback XT - New Interior, Drivetrain, Exhaust
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Points: 18,003, Level: 85
    Discussion Ender
    Got this one back in May after I crashed my old BEhttps://sl-i.net/FORUM/viewtopic.php?t=7464. I originally drove up to MA to see a Spec B (guy wanted $18k!), and a nice 08 OBXT 5 spd (dealer wanted $16000) but while I was at panera bread for lunch, I found this one on CL for $10000. 05 XT premium...with a 5 spd. It had 100k miles on it and completely stock. Was being sold by some small gas station/repair shop that buys subaru's at auction and resells them. Called the guy and was test driving it 2 hours later. I told him I knew the timing belt service would be due soon, so we agreed on $9400 as-is, since I was planning to do a lot of maintenance/upgrades to it anyway.
    A down payment and another 3 hour drive later, I was driving back to NYC with my new-to-me OBXT!
    The fun part is seeing how many parts off my old car will fit! Been tweaking it since then (mainly the suspension and brakes). I think it was left stock for a total of 4 weeks? I may be eating these words, but I won't go crazy with this one, unlike my old car. D'oh.
    Engine:
    -KN panel filter!
    -Timing belt service with Gates kit by AZP!
    -PW knockoff TMIC
    -Perrin LW crank pulley
    -Group N pitch mount (from my old BE)
    -Zerosport Intake tube
    -CNT catted DP
    -GTspec UP (from my old BE)
    -PnP exhaust manifold w/ CNT crossover pipe (from my old BE)
    -Cobb AP Stage 2
    -OBXT 3" midpipe to stock mufflers
    Drivetrain: (from my old BE)
    -STI 6 speed (05)
    -KB short shifter, poly shifter bushings front and rear
    -matching 3.9 rear diff with VLSD
    -Stock Exedy clutch
    -STi stock flywheel (19lbs vs. 26lb dualmass stocker)
    -Group N transmission mount
    -WL rear diff bushing inserts
    Suspension:
    -Spec B struts, Spec B front tophats
    -Spec B front springs, LGT wagon rear springs with 1/4" rear spacers
    -Whiteline ALK front LCA's
    -LGT rear upper links with Whiteline adjustable camber bushings, rear LGT bumpstops
    -Whiteline/Megan adjustable rear lateral arms
    -Whiteline front rear-arm bushing
    -Whiteline front 22mm FSB, with KB endlinks (from my old BE)
    -Whiteline 20mm RSB
    -AVO rear swaybar reinforcement plates
    -Moog HD rear endlinks.
    Brakes:
    -Nissan 300zx Turbo iron front calipers, KNS Nissan brake caliper brackets, LGT front rotors, Stoptech street pads
    -LGT rear calipers, LGT rear rotors, Stoptech street pads
    -SS brake lines
    -GS Master Brake cylinder brace.
    Interior:
    -Pioneer USB/CD/radio single DIN HU with Novero TrustyOne Bluetooth
    -JDM 2 DIN setup
    -Wood trim repainted
    -Pioneer 3 way speakers all around
    -OEM WRX sub
    -06 WRX steering wheel (from my old BE, stock one had cracked leather)
    -Momo OEM knob
    -WRX pedals (from my old BE)
    -VDO mechanical boost gauge (from my old BE)
    Exterior:
    -5k HID kit Low beams (spares from my old BE)
    -HIR bulbs High beams
    -30% tint in the rears
    -trimmed/rolled fenders front and rear
    -JDM rear tail lights
    -JDM tilt front license plate!
    -CREE LED 25w reverse bulbs.
    -Stebel Nautilus airhorn
    Wheels
    -Prodrive GC-06D 17x7.5 forged wheels w/ 235/50/17 Continental Extremecontact DWS
    -Millia miglia 5 spokes 16x7 wheels w/ 205/60/16 winterforce snow tires
    Parts pending:
    -Tomioka 18g turbo
    -DW 740cc injectors
    -DW 65 fuel pump
    First time seeing the car:
    Currently:
    Summer
    Previously:
    Winter
    Interior:
    2005 Outback XT
    GO > Show. Every time.
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Re: Rougeben's 2005 Outback XT (its wagontiem!)
    First major work (after maintenance stuff like fluids and timing belt and a GOOD cleaning)...addressing the suspension and brakes. Over 100k on stock struts - the rears were already blown, and a lowered OB was my original goal anyway...
    OBXT's also came with pathetic 11.4" front rotors and non-vented rear rotors...so I put in stock LGT brakes front and rear, as well as some SS (goodrich I think?) brake lines.
    Right after I lowered it (initially with front LGT springs and Spec B tophats, hence the higher front ride height)
    Stock vs. LGT height Outback
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Then the wheel whoring began!! 2011 WRX wheels. Unfortunately, 4th gen wagons have WAY less wheel clearance than the 3rd gen...I had to use a 3mm spacer in the rear to clear the inner wheel well around the struts.
    Then scored a good deal on some forged Prodrives...about 5lbs lighter than the WRX wheels, but not as light as my old, wider RPF1's...You can also see how changing to shorter spec B front springs evened out the ride height.
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Then went back to the tried and true Nissan front calipers to go with my LGT rotors! (maybe I shouldn't have sold my old set hmmm) Mainly to fit 16inch wheels with LGT brakes - it was cheaper to upgrade the brakes than to buy new winter tires hah!
    2005 Outback XT
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,542
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    Are the front Nissan calipers a straight bolt on?
    5,050
    LOL... I was wondering if you were gonna regret sells the brake to me. They haave a good home though.
    Car looks great!
    Quote Originally Posted by 98legwag
    They need adapters... Ben sold them and the calipers to me months ago.
    Moco, Maryland
    3,542
    16,957
    I thought the rears need the adapters. I was just looking a thread on Nasioc about using Evo 8 Brembos on the front. And it took a little modification to use the Brembos. Oh and the Evo Brembos can use 4th gen LGT and Spec B rotors.
    http://forums.nasioc.com/forums/showthr ... ?t=2179101
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    yes, the fronts use adapters, originally a japanese company called global Z made them (Dead's set has them), but looks like KNS got a hold of a set and started making copies out of billet aluminum. My new set uses the KNS version (the spacers are integrated into the bracket, unlike the global z ones, but don't seem to be as robust).
    You can use the nissan rear calipers instead of FHI 2 pot calipers with whatever adapter those work with - they have a 5mm pad overhand though.
    Snows are on:
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Quote Originally Posted by Dead91silvia
    Car looks great!
    haha, yeah but its ok, I didn't really know I was going to get another subaru...oh well
    2005 Outback XT
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    Quote Originally Posted by rougeben83
    Quoted for posterity. :smt002
    I can't wait to see what you "don't" do... ...so I can copy it again in some way!
    Moco, Maryland
    3,542
    16,957
    Thanks for the info guys. I like the direction you are going with the Outback.
    Jan 2007
    brooklyn ny
    1,350
    11,922
    Points: 11,922, Level: 71
    finally you made a new thread. Like the wheel whoring theme you've got going here
    t3h ub3r m3mber nikolaus.conrad's Avatar
    Jun 2010
    Finger Lakes/ Rochester NY
    1,622
    9,726
    Points: 9,726, Level: 66
    Level completed: 19%, Points required for next Level: 324
    5000 Experience PointsO.G.Social
    Whoa, I've been out of the loop for too long, so sorry to read about your old car I'm glad you're okay! I can't wait to see what you'll do with this one!
    -Nick
    Quote Originally Posted by Thomistopheles
    The EJ25D likes to blow its head gaskets in a spectacular manner, leaking combustion gasses into places it's not supposed to go; giving you the world's worst tasting milkshake.
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Haven't been active on the site, doesn't mean I haven't been active on the car.
    Got a Cobb AP and went to a Stage 1 map. Car def has extra "poke" in the midrange.
    More carryover parts from the old BE: Cobalt SS turbo badge
    and VDO boost gauge.
    day:
    night (changed backlight to LED to match the cluster):
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Installed JDM (Rev A I think) tails.
    USDM vs. JDM
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Switched to 235/50/17 Continental Extremecontact DWS from 225/55/17. A little lower sidewall height adds to the wagon look.
    Sidewall height comparison:
    Very subtle change in perspective- makes the suspension drop look lower with the 50 series
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Detailed the car after a long winter... wash, cleaner, claybar, zymol cleaning wax, and finally Klase All in One.
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Finally, took a chance on a cheap Stebel Nautilus Air horn on ebay. Louder than Supertones! And more discrete
    2005 Outback XT
    SLi Lurker foohfooh's Avatar
    Jan 2013
    Seattle/San Diego
    431
    5,362
    Points: 5,362, Level: 47
    Veteran5000 Experience Points
    very clean. bravo on the detail. loving the prodrives. they mesh well with the color of nisssan brakes. and the two-tone paint also!
    never thought about adding badges to my car though...
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Thanks, I'm not a big fan of the two-tone, but it is growing on me. I'd prefer the single-tone that later OBXT's came with (all pearl white or obsidian black...)
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Gold Rota SDR's...
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    And a cheap $27 short shifter from Ebay... It works. 'Nuff said lol.
    Also, you can see the full CREE LED lighting treatment. No flash in this pic.
    2005 Outback XT
    Subaru Ambassador geckoboy86's Avatar
    Cburg PA
    1,643
    13,797
    76
    Points: 13,797, Level: 76
    Level completed: 37%, Points required for next Level: 253
    Created Album picturesO.G.SocialCreated Blog entryOverdrive
    Calendar Award
    So much win in this car...
    SLi Lurker soba noodle's Avatar
    Oct 2013
    AKL/NZL
    420
    5,897
    Points: 5,897, Level: 49
    Level completed: 74%, Points required for next Level: 53
    Tagger Second ClassVeteran5000 Experience Points
    Dammit they even copied Prodrives... :\
    SLi Lurker meepers's Avatar
    Sep 2010
    Phoenix, AZ
    423
    5,843
    Points: 5,843, Level: 49
    King of Publishing
    My second favorite Body style after my 98 Outback. I LOVE The way Subie did the 2 tones.... I should see if the You pull it yard has any outbacks and see if I can mod the flares to fit my wagon. Looks great, Prodrives FTW.
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Went Stage 2 over the weekend... CNT DP, GT spec UP, and PnP manifold w/ crossover pipe (the last two were from my old car, yet again! ). Nothing like finishing the job at 2am ughhhh. Need to flash the AP, put in a new rear O2 sensor, and resistor the EGT sensor though.
    Can't wait to see how badly this will end. hahaha
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Rear suspension's finally sorted. WL/Megan adjustable rear control arms, WL front rear-arm bushing. So neutral in sweepers now.
    Pics to follow.
    2005 Outback XT
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Finally got pics - my rear suspension's finally complete!
    Whiteline front bushing for the main swingarm:
    Adjustable rear control arms, bigger RSB, HD endlinks, RSB mount plates.
    LGT upper link w/ adjustable outer bushings, Bilstein shocks, LGT wagon springs w/ 1/4" spacer
    2005 Outback XT
    MD, USA
    2,613
    17,786
    Community Award
    I notice that you're hitting the bump stops.... Does the BL/BP Outback have body spacers like the previous Outbacks? If so, do you plan on removing them at some point?
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Still using outback rear bumpstops...been thinking of switching them to the LGT ones but I gave my old ones to Robin
    But yes these have spacers. And no, I don't have enough invested into the car to de-outback the whole thing.
    2005 Outback XT
