Results 1 to 17 of 17
Thread: radio interference from headlights - help!
    MD, USA
    2,617
    17,786
    Points: 17,786, Level: 84
    Community Award
    So the Forester has an issue where the radio is nice and clear.... until I turn on the lights. Then a noticeable amount of static comes in. This only happens when I turn the lights to the driving lights position, full on position, or turn on the top column switch. I've checked and double checked the connections on the radio, antenna, and antenna amplifier. I don't know what it could be. It has been suggested that it may be the integrated body unit, but I don't have any other vehicles that have one so I cannot switch it out until I get my hands on one. Anybody else have any ideas?
    10,454
    57,313
    Points: 57,313, Level: 100
    Re: radio interference from headlights - help!
    Sounds like a grounding issue.
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1998 BK L PARTED
    "Proby"
    Mar 2012
    San Jose, CA
    242
    4,606
    43
    Points: 4,606, Level: 43
    Level completed: 28%, Points required for next Level: 144
    Check ground wire attach to your radio mount/frame loose or missing. If you have HID, check those grounds too.
    03 350Z - 120K DD
    99 RS - Currently swapping JDM V9 207
    98 RS - 145K JDM 20K V4 WRX
    02 WRX - 150K DD
    95 Legacy Wagon - 200K Winter Tahoe tank
    MD, USA
    2,617
    17,786
    Community Award
    I don't have HIDs, and I've checked all the grounds of the system. Would it help if I added a grounding kit?
    10,454
    57,313
    It wouldn't hurt...
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    MD, USA
    2,617
    17,786
    Community Award
    Okay, I installed a grounding kit. It didn't hurt, but it didn't really help either (with my radio problem anyway). Should I run a direct connection from the headunit to the negative terminal on the battery or would that not do anything? Are there any other ideas? It's freaking annoying to not be able to play the radio whenever the lights are on....
    May 2013
    Plainfield ct.
    153
    3,393
    36
    Points: 3,393, Level: 36
    Level completed: 29%, Points required for next Level: 107
    Where is the antenna on that year forester?
    91 Legacy SS Monster Sedan (The Cleg)
    99 Legacy wagon H6 swap (Sparky)
    00 Legacy GT wagon (Red)
    02 Outback 3.0 LL Bean (Renee)
    74 Subaru DL
    MD, USA
    2,617
    17,786
    Community Award
    The rear driver side window. There is also an antenna amplifier (I think) right by the antenna, but I can't read that it gets any power with my multimeter. It must be working though, since I get no radio signal if I unplug it.
    May 2013
    Plainfield ct.
    153
    3,393
    36
    Hmm. You check under the rear seat area and right rear sill plate for rodent activity?
    It's doesn't look like the body module ties into the radio at all. And the only point any illumination is involved is at the head unit.
    Is it a factory radio?
    74 Subaru DL
    Northeastern CT
    2,651
    He had the same issue with both the factory radio, and the Kenwood navigation unit, so it is not the radio itself that is having the issue.
    MD, USA
    2,617
    17,786
    Community Award
    I know the rear seat area is clear of issues; I removed them to install and run the wires for the rearview camera.
    Now that I've solved the wind noise issue, I REALLY want the radio to work whenever I want it.
    I've contemplated wiring the taillights in with the DRL and just leaving the lights "off", but that would be ridiculous and I'd rather not do that.
    9,869
    Maybe try installing a filter inline with all of your power sources to the HU and see if that helps?
    My 03 does not have this issue, aftermarket JVC unit installed.
    The only TSB I've seen on an issue like this is the rear defogger causing problems with the antenna.
    SLi Supporter
    May 2010
    NJ - near NYC
    128
    4,737
    43
    Points: 4,737, Level: 43
    Level completed: 94%, Points required for next Level: 13
    There is a TSB about the rear defogger and the radio? My 2000 Sedan does that and it is quite annoying. The defogger and the antenna share the rear window in my car and every time the defogger is turned on the radio goes to static. It sucks.
    Regardie
    1997 Legacy L sedan 2.2 auto - crushed by a tree during Sandy
    All upgrades stripped and returned to stock, started up when they hauled it away
    New to me 2000 Legacy GT Limited sedan 5 speed 180K miles
    184K and running on a JDM Bilstein struts and springs set and a replacement RS 5MT
    187K, engine top half rebuilt, Delta 1500 cams, PNP, converted EJ252 to EJ251 for Delicious Stage 1 flash
    190K worked out some engine issues with the swap, now Cobb EL headers and High Flow Cat and mid pipe, muffler shop axle back
    MD, USA
    2,617
    17,786
    Community Award
    Quote Originally Posted by Wiscon_Mark
    Well, the antenna on the Forester is on a different window than the defogger. Also, I just checked and the defogger has no effect on the radio.
    I am curious about this "filter" you speak of. What is it?
    9,869
    It was a recall for all models, but obviously it's not affecting you if you have it off and still have the issue.
    I'm not necessarily recommending any of these, but here are some examples:
    http://www.amazon.com/Pyramid-NS12-InLi ... ine+filter
    http://www.amazon.com/Metra-AX-ANR1000- ... ine+filter
    Quote Originally Posted by Regardie
    Yes, it's here: http://www.cars101.com/recalls.html
    Customer complaint of radio static when the radio and rear window defogger are on at the same time, there is the possibility of a break in one or more of the defogger grids. When the grid is broken, a high resistance field is created at the break point which can create static on some radio stations. The level of resistance is usually high enough to create a field of interference which projects out from the glass. The break can be detected visually or by using a portable radio.
    Using a portable radio, set the radio to the same frequency and station being disturbed by static. From the outside of the vehicle, slowly move the radio’s antenna across the defogger grids. When interference is encountered, inspect that specific area closely for a break. Depending upon the size of the break, a magnifying glass and/or eyeloupe may be required.
    Once the break is identified, it should be repaired using the Permatex® repair kit instead of replacing the rear glass. Note: Make sure to carefully read and follow the instructions
    and precautions that are included with the Permatex® repair kit.
    Permatex® Quick Grid™ Rear Window Defogger Repair Kit, part # 15067, used for repairing damaged rear window defogger grids, is available at local automotive parts stores.
    MD, USA
    2,617
    17,786
    Community Award
    I will try that, thanks.
    SLi Supporter
    May 2010
    NJ - near NYC
    128
    4,737
    43
    I know I have a break in one of the rear defroster lines as I can see it not work every time I use it. Now to find the time and a sunny day for the fix.
    Thanks
    Regardie
