Results 1 to 3 of 3
Thread: Anyone knows if 02-07 WRX shifter assembly can replace 95 BK one?
    "Proby"
    Mar 2012
    San Jose, CA
    242
    4,606
    43
    Points: 4,606, Level: 43
    Level completed: 28%, Points required for next Level: 144
    1000 Experience PointsO.G.
    Anyone knows if 02-07 WRX complete shifter assembly can replace 95 BK one? 95 fork joint at shifter looks bent 45 degree while WRX is more straight.
    03 350Z - 120K DD
    99 RS - Currently swapping JDM V9 207
    98 RS - 145K JDM 20K V4 WRX
    02 WRX - 150K DD
    95 Legacy Wagon - 200K Winter Tahoe tank
    SLi Resident 86bratman's Avatar
    Jul 2013
    Tazewell VA
    739
    4,313
    41
    Points: 4,313, Level: 41
    1000 Experience PointsOverdriveVeteran
    If you replace the shifter knuckle and all it works. I've got an 02 wrx shifter assembly with a kartboy short shifter in my 97.
    My 1997 Legacy L
    Fuelly
    "Proby"
    Mar 2012
    San Jose, CA
    242
    4,606
    43
    I had to keep the BK/95 shifter arm/wobble bushing part and swapped out WRX plastic base/shifter socket/hockey puck assembly, then I can use WRX short shifter with small socket. BK/95 socket shifter is very big compare to WRX socket and finding short shifter for it is difficult. All KB/Ebay shifter have small socket type. Bought some nylon flange bushings from McCaster P/N 6389K624 for $8 to fix shifter wobble issue and KB front/rear shifter bushings too.
    Mine is this type since there are 2 types.
    03 350Z - 120K DD
    02 WRX - 150K DD
