Results 1 to 7 of 7
Thread: Bolt shoved in head!
    721
    the exhaust in my '99 needs to be replaced-easy-except the previous owner had some jacka** damage one of the studs and shove a bolt into its place-where do I go to get this problem taken care of?
    SLi Resident 86bratman's Avatar
    Jul 2013
    Tazewell VA
    739
    4,313
    41
    Points: 4,313, Level: 41
    1000 Experience PointsOverdriveVeteran
    In no particular order, remove the bolt, go to the help section at advance auto or your preferred parts store. Buy a set of exhaust studs for a Nissan, not sure what the part number is or the thread pitch offhand. But I've used them a few different times with rusty studs on these cars.
    My 1997 Legacy L
    Fuelly
    721
    Problem is-I'm afraid it will snap off-and, I'll be damed if the head has to be removed-everyone who has looked at it just wants to run from it (and they know there way around with torches and mig welders)-should I find an exhaust shop that would tackle it?
    SLi Lurker LeggyxPower's Avatar
    466
    7,220
    56
    Points: 7,220, Level: 56
    Level completed: 35%, Points required for next Level: 130
    When changing my Headers one of the studs stripped the threads on the block.. look up a heli coil.. i drilled and taped and inserted the new heli coil along with the new stud, and its good as new
    Apr 2016
    8
    638
    12
    Points: 638, Level: 12
    Level completed: 76%, Points required for next Level: 12
    oversized bolt
    SLi Lurker nepbug's Avatar
    Sep 2014
    Denver, CO
    411
    4,977
    Points: 4,977, Level: 45
    Exh. Man. Studs - p/n 80091055
    Or you can get some equivalent Dorman or other brand ones at your local parts store.
    To help out with removal, For a week, try to spray some penetrating oil up there while it's still warm after a drive at least once a day. It should wick in there and help increase your odds of success.
    721
    I finally did get it out-two years ago! (really late on the update!)-the bolt was easy to get out-thought, one of the factory studs did stay in the head-the nut came off-usally the nut is rusted to the stud and they both come out.
