Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Thread: DIY: FX-R 3.0 Retrofit Into 2nd Gen Legacy/ Liberty BD BG BK JDM Headlights
    SLi Supporter Hinyo's Avatar
    Nov 2011
    Maryland
    482
    7,907
    59
    Points: 7,907, Level: 59
    Level completed: 79%, Points required for next Level: 43
    Tagger Second ClassSocial5000 Experience PointsO.G.
    Cool DIY: FX-R 3.0 Retrofit Into 2nd Gen Legacy/ Liberty BD BG BK JDM Headlights
    FX-R 3.0 Retrofit Guide
    Sorry for Potato Camera will upload better quality when I get them from a friend
    Before
    HID's in stock Housings
    After
    Low Beam
    High Beam
    Time Estimate
    ALOT this is no small task.
    Difficulty
    1st Step
    Order a set of FX-R's
    2nd Step
    Remove Projectors from Vehicle Remove all bulbs and Clean projector housing
    AVOID TOUCHING THE BULBS!!!!
    3rd Step
    Locate silver clamps/clips and remove from Headlight with a flathead screw driver
    Should be a total of 5 clips.
    Place in Plastic baggies for safe keeping
    3 on top
    2 on the bottom
    Should look like this when finished
    4th Step
    Remove Screw holding in projector to housing with a Phillips screw driver and place in baggies.
    Differs depending on model year some have 2 screws some have 1
    5th Step
    Cut out cardboard a bit bigger than projector
    Place Projector in oven preheated to 250 bake for 5-7 minutes
    5th Step
    Hard to do any take pictures of but pry SLOWLY at these points to remove Lens from housing.
    6th Step
    Tip Projector forward using 8mm deep socket and unscrew projector from bracket.
    WARNING!!!! IF rusted ball and socket can be removed with 10mm instead so that bolt heads can be cut off!!!
    7th Step
    And this is where the fun begins
    Select desired metal thickness
    Remove backing for projector and trace
    SAVE THESE PLASTIC ADJUSTMENT CLIPS
    here was my process... I can email you a PDF of the plate that i scanned as a template cut out print and copy onto metal
    Copy Template to make for other side
    8th Step
    Trim Projector for adjustment screw clearnace
    9th Step
    Check Rotational leveling and check for lens clearance
    10th Step
    Once happy with leveling
    Mark holes and bolt projector to mounting bracket
    11th Step
    Reassembly is the reverse of diassembly
    IMPORTANT
    RESEAL WITH BUTYL RUBBER BEFORE ATTACHING LENS!!!
    sorry hard to take pictures and wrestle with lens
    12th Step
    Wire them up
    Here is some inspiration
    I used OEM Nissan Matasushita ballasts and D2S: Osram Xenarc 66240 with Straight adapters. Also amp to DS2 adapter to keep OEM look and cover sealed with silicone. made a mounting bracket from spare steel and attached to 4th unused OEM bolt location for non JDM headlights. I can add more pictures of my setup if people are interested.
    Hope this inspires or helps someones whose on the fence.
    ENJOY YOUR HEADLIGHTS!!!!
    Extra Potato Outputshots
    SLi Supporter WPEC's Avatar
    Jan 2014
    Northern Virginia
    270
    3,904
    39
    Points: 3,904, Level: 39
    Level completed: 70%, Points required for next Level: 46
    Dat' dope man! Yo
    I love that custom brackets , I can save my times on FX-r instead of a Murano if I have your template.
    I will send you pm real quixk
    1995 L-Wagon 45B : Sold
    1997 GT-Sedan 54A
    Jul 2013
    Tazewell VA
    739
    4,313
    Points: 4,313, Level: 41
    Looks awesome man, what gauge/type of metal did you use for the adapter plates?
    My 1997 Legacy L
    Fuelly
    Nov 2011
    Maryland
    482
    7,907
    59
    Bracket
    Quote Originally Posted by 86bratman View Post
    uhm I remade them at a friends house. I think it was steel he said aliminum lol. but it was probably between 14 Gauge and 1/8 inch because the gauge i was using for the first bracket was just TOOOO thin not enough rigidity and adding the flap at the top really helps to add strength
    SLi Resident HeresMyMind's Avatar
    Dec 2007
    southbury, ct
    517
    8,513
    62
    Points: 8,513, Level: 62
    Level completed: 21%, Points required for next Level: 237
    I'm super glad that people are doing proper retrofits!
    I did FXrs in my TSX in my firs tpair of jdms, then FXrs in my 2nd set , then S2000s in my 3rd set.
    Your rotation looks great. but you need to lower the right headlight a bit.
    the steps should look like this:
    *** ____ ____
    ___/ ____/
    NOT this:
    *********** _______
    ***** _____/
    _____/
    -B
    "This thing looks great in person, makes me think getting a wagon isn't so bad lol"
    -Reason
    Nov 2011
    Maryland
    482
    7,907
    59
    Quote Originally Posted by HeresMyMind View Post
    *** ____ ____
    ___/ ____/
    NOT this:
    *********** _______
    ***** _____/
    _____/
    -B
    Believe it or not. you are and were one of my biggest inspirations to tackle this =) ive loved all your headlight builds. And thank you for the tip. Will do
    Jul 2013
    Tazewell VA
    739
    4,313
    Did you link the wrong projectors or did you use the high/low kit for your retrofit?
    My 1997 Legacy L
    Fuelly
    Nov 2011
    Maryland
    482
    7,907
    59
    No those are the right projectors. The FXR is a bi xenon projector and I wired the solenoid in with the 12v for the high beams. So i have both the factory high beams and the x3non high beams. They are mind blowing. My pictures dont do them justice. See video posted on fb though ull hear the solenoid going up and down
    Jul 2013
    Tazewell VA
    739
    4,313
    I know very little about this side of the car modding stuff, I tend to stay under the hood lol.
    My 1997 Legacy L
    Fuelly
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,516
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    I got to see his car Saturday after this was done. They are VERY bright in person. He was also behind me at one point on the road and flicking the high beams on and off. They were very bright down the road, but surprisingly not too blinding in my mirrors.
    Jan 2014
    Northern Virginia
    270
    3,904
    39
    He will build a new project soon!!!!! >>> Fun ha
    1997 GT-Sedan 54A
    Nov 2008
    6
    6,066
    Points: 6,066, Level: 50
    Level completed: 58%, Points required for next Level: 84
    Which size lense did you use with the FX-R? I saw 2.5" and 3" being a option and just wanted to clarify before I order. Thank you for a great DIY!!
    Nov 2011
    Maryland
    482
    7,907
    59
    Quote Originally Posted by Hobo Joe View Post
    3" 2.5" fits but doesnt fill the gap. Glad you like it =)
    Nov 2008
    6
    6,066
    Quote Originally Posted by Hinyo View Post
    Thank you very much! Ive been researching for over a year or 2 and most of the conversions are very over whelming and complicated. This DIY is very straight forward and manageable. If you happen to have any pictures of the rear of the light that you could share I would greatly appreciate it.
    Nov 2011
    Maryland
    482
    7,907
    59
    Ill try to get some tomarrow if i dont have them by over the weekend please remind me they are very much worth uploading. But if you want a descriptiomni ended up using an amp to d2s straight adapter than a ds2 to amp to bring it back to oem style plug. bought a dust cover from the retrofit source for the adapter and cut a hole in the dust cover but was able to reuse it just like factory. Pulled the high beam wire through the rubber cover. Than wired it all with thr jdm plug and 9006 connector. Sound complex but pictures will help im sure
    Dec 2009
    Kaysville UTAH
    1,823
    9,426
    Points: 9,426, Level: 65
    Very nice diy I need to get some JDM headlights.
    t3h ub3r m3mber Thomistopheles's Avatar
    Apr 2012
    Madison, WI
    1,366
    9,783
    Points: 9,783, Level: 66
    Level completed: 34%, Points required for next Level: 267
    5000 Experience PointsVeteran
    I have a set of FX-Rs, Denso ballasts, and Osram CBIs that need a home... Could you send me the drawing/dimensions/whatnot for that plate? Making brackets ahead of time would greatly diminish my car's downtime. I can message you my email if you need it
    97 BD GT - Baller Husky Hauler II
    06 OBXT Limited - Baller Husky Hauler III
    Quote Originally Posted by nikolaus.conrad
    I have the strangest urge to lick your car, and rub my face on it...
    May 2015
    4
    1,333
    20
    Points: 1,333, Level: 20
    Level completed: 33%, Points required for next Level: 67
    This is a great step by step instruction. One thing I dont understand is why you had to replace the projector piece. Is there not an hid kit for the H1 and H3 bulbs? I know I saw a kit for H3 on Theretrofitstore.com
    I just got my jdm headlights and hope to get some hids soon.
    Nov 2011
    Maryland
    482
    7,907
    59
    Quote Originally Posted by 98LegacyGTwagon View Post
    @98LegacyGTwagon
    COOL!!!! Hopefully I can explain some of this.
    Glad that you asked. This question will be asked time and time again. here a link to some good information already on the forum on this exact subject Here but to put it simply. You do not want an HID in the h3 bulb reflector location. No aftermarket kit will fire quick enough to be usable as a high beam in the h3 location and the "flash to pass" will kill the life of the h3 high beam HID bulb as they aren't meant for doing that. So Ill start with that.
    Now onto putting HID's into the h1 location. I did this at first and it was great!!! We each have our own level of satisfaction and after a while, I just wasn't satisfied with having HID's in my projectors. First ill highlight that that projector that is used in the jdm projector is made for a halogen bulb. Its reflects light well but isn't meant for the intensity that an HID creates it comes down heavily to the bowl design. An HID in a haloden projector scatters light and creates glare for oncoming drivers. Its better controlled than say putting an HID into a PURE reflective housing but needs bulb and lens work(Bulb spacers and or a clear lens) to really get the most out of the HID system. @Thomistopheles did some work in that department. At this point trying to optimize and system that is already down seems minimally effective. If you have the entire headlight apart to do this work why not just replace the projector with one that can take full advantage of an HID? The projector I replaced this with adds great light intensity, crisp cut off, the USE of OEM bulbs and ballasts for reliability and quick start-up. No waiting for full light intensity. Also having a BI-xenon projector means that I can now not only take advantage of the HID in a low beam configuration but also as a high beam along with my factory halogen high beam. DUAL HIGH BEAMS FOR THE WIN!!!! and lastly and most importantly... just because I wanted to. Its something you have to want. If you are satisfied with the HID's than by all means go for it but at some point as with many mods you just want more so i went for it =)
    Hopes this helps!!! message me anytime if you ever want anymore help!!!
    STOCK PHOTO OUTPUT SHOTS NOT MINE!!!
    This is just 1 projector btw... much wider with 2 and more intense also consider that there is already light in this picture and how brightly the light still shines through
    Low Beam
    High Beam
    May 2015
    4
    1,333
    20
    Thank you very much for that Explination. Again you have helped a lot. Do you have any recomendations for the jdm foglights? I was thinking of just finding some LED bulbs for for the outer bulb and eventually HID for the projectors. Only problem is I dont know who makes good high output LED bulbs. Ive been using bulbs for my interior dome lights from superbrightled.com but the advertised lumen output for their headight bulbs seems to be....well crap.
    Plus I have been trying to find DIY for properly cutting the bumper and mounts to get them to fit but it seems this website changed the way you post links so I cant find the right DIY.
    Sorry to be a new person nuisance
    Nov 2011
    Maryland
    482
    7,907
    59
    @98LegacyGTwagon
    Dont worry about it in the slightest. I was in your position one day and im glad to help spread knowledge Here is the DIY you are looking for.
    In terms of JDM fogs. I would ask @98legwag about it as I do not have a set myself. I have something quite a bit crazier in my foglights LOL. I have Lexus RX330 headlights in my foglights with yellow d2s bulbs. For a while I had lexus es300 foglights before that and before that I put HIDs in my USDM fogs which was well... not the smartest but looked awesome lol. In terms of LED's its really hit or miss... Depends on what you want. Some of the issues with LED's are their longevity at full brightness. Their brightness teeters off inversely as time increases to an "acceptable level" but not as bright as on start-up. Also PNP leds aren't created equal. Personally I really LIKE CREE/SMT hybrid STYLE LED's but really what matters is the quality of the diode not the style of the LED. Also consider that LED's may never be as good as a halogen in the same application they require different reflectors in order to maximize output but can still do a pretty good job if used correctly to take advantage of the halogen reflector design.
    Moco, Maryland
    3,516
    16,957
    The turn assist bulb on the JDM fogs is an 1156. I tried LEDs in them and the light out put was a joke. I went back to halogen, but I got yellow bulbs.
    May 2015
    4
    1,333
    20
    What brand of halogen bulbs would you recommend?
    Nov 2011
    Maryland
    482
    7,907
    59
    @98legwag
    @98LegacyGTwagon
    I'm pretty sure he has Osram night breakers
    Personally I like Phillips Diamond Vision a little less Lumens but very white
    Moco, Maryland
    3,516
    16,957
    My wagon has all different types of bulbs. I think the lows are Philips Diamond Vision, highs are Osram Night Brakers, projector fogs are mixed matched, and I think the yellow side assist bulbs are Nokya Hyper Yellow. It should all be somewhere in MR1 thread for that car.
    "FNG" Michelle's Avatar
    Feb 2015
    55
    2,173
    28
    Points: 2,173, Level: 28
    Level completed: 16%, Points required for next Level: 127
    I recently had a small accident in my '99 Postal Wagon. Enough so that I am in the market for new headlights once I replace the core support, radiator and condenser. JDM headlights have always been on my list, but you've just solidified this with an easy-to-follow DIY.
    Also, to 98LegacyGTwagon, another reason you should retrofit any(most) JDM headlight that you get is because the cut-offs that are designed into those headlights are set up for a RHD arrangement. In my case, my car is RHD, but since I'm driving on LHD streets here in the US I should apply to that convention. So, in further attempts to not blind oncoming drivers, you should retrofit them with LHD projectors before installing. Most people won't because of the added effort and expense, arguing that you can just adjust them to aim lower on the left side. Personally, I'd much rather do it the right way.
    Jan 2014
    Northern Virginia
    270
    3,904
    39
    Would update mine
    Im tryna figure out why solenoids stuck open
    Will update again after reinstall.
    1997 GT-Sedan 54A
    May 2015
    4
    1,333
    20
    Did you make those brackets? They look like they were machined. How or where can I get a pair?
    Jan 2014
    Northern Virginia
    270
    3,904
    39
    Those brackets were designed by CAD and built by Laser cut.
    I still have the other pair left , but I'd keep them
    Otherwise, you can ask @Hinyo first because He made mine and he has few sets ready.
    1997 GT-Sedan 54A
    Jan 2014
    Northern Virginia
    270
    3,904
    39
    Quote Originally Posted by WPEC View Post
    Would update mine
    6 month later , FX-R's been working like a charm.
    Those pair of bracket would help retrofitter reduce time consuming on doing FX-R swapped into JDM headlights.
    1997 GT-Sedan 54A
Tags for this Thread
