Page 3 of 5 FirstFirst 12345 LastLast
Results 61 to 90 of 134
Thread: Hinyo's 98 Legacy GT - Swap Time
  1. #61
    5,050
    Sounds like good progress, but I want to SEE the progress! :P MORE PICS!
    HAHA
  2. #62
    SLi Supporter Hinyo's Avatar
    Nov 2011
    Maryland
    483
    7,907
    59
    Points: 7,907, Level: 59
    Level completed: 79%, Points required for next Level: 43
    Tagger Second ClassSocial5000 Experience PointsO.G.
    Still no pictures. Maybe soon. Trans is in and seated
    Diff is in.
    Need to fill everything with fluids.
    Things left to do are: Slave Cylinder. pedal assembly, starter, wiring.
    Need a new shiftier circlip otherwise good to go.
  3. #63
    Nov 2011
    Maryland
    483
    7,907
    59
    Learned A valuable lesson.
    Be very careful when installing and removing axles. Ill have to replace an axle seal now *head desk*
    Have to drain the trans again to fix the seal since I found out while I was filling it...
    07 WRX slave cylinder + legacy slave are not the same. Interferes with the throttle assembly.
    I'll be able to use the wrx slave once I finish the swap though.
    Filled everything with fluids.
    Starter is in
    Pedal assembly is in.
    I think I'm going to let the trans leak at least till I get it home. Tired of it sitting in my friends driveway.
    *fingers crossed* find a junkyard slave and getrdun tomorrow. If not it will be finished and home next week and ill order the trans seal just finish it all at once.
  4. #64
    Queenstown, New Zealand
    1,408
    12,999
    74
    Points: 12,999, Level: 74
    Oh god, axle seals... You will need to lookup the service manual procedure on you to set the diff preload, as the thing that houses the seal also sets the load.
  5. #65
    Nov 2011
    Maryland
    483
    7,907
    59
    So updates.
    VSS is wired
    NSS is wired
    Reverse is wired.
    Just need to ground pin 81 and put in 1 more bolt than I should be good to drive it. (at least a little bit)
    Still need to repair the axle seal
  6. #66
    Nov 2011
    Maryland
    483
    7,907
    59
    5 spd swap complete ish...
    Axle seal repaired
    Car runs drove it home in limp mode.
    ABS light is on
    CEL is on P1507 and another related code
    Need to attach pin 82 to the NSS and ground the other side than hopefully Ill be good to go!
    Also adjust the TPS because when it wasn't completely in limp mode it was TERRIBLE off and on throttle
    Might also need to bleed the brakes the have been quite squishy since the swap not sure why
    Also need to remove the tone rings on the wrx axles.
  7. #67
  8. #68
    Nov 2011
    Maryland
    483
    7,907
    59
    Well conflabit all!
    Almost 100% sure I fried the ecu...
    Went to fix the P1507 today. Wired from ecu pin 82 to NSS and grounded other side of NSS to Starter ground.
    Pretty sure eithier back current fed into ecu and killed it or it fed back current because of wrong year NSS. Need to get a pre 05 nss.
    OBD2 Port shows no connection to ECU but ecu light is on when key is in on position. Cranks infinitely. Great....
    Hopefully get a few ECUs a main relay some sbf2 fuses and track this sucker down...
    Lucy im sorry ill figure it out promise
  9. #69
    Nov 2011
    Maryland
    483
    7,907
    59
    Pretty sure I have a leak in my brake system somewhere. Fluid was low causing light to turn on which might also explain my squsihy pedal. Its guns be a bad time if its the booster but it is what it is.
  10. #70
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    Quote Originally Posted by Hinyo View Post
    Well conflabit all!
    Could my spare ECU (04 FXT w/EJ255) help you out at all?
  11. #71
    Nov 2011
    Maryland
    483
    7,907
    59
    Quote Originally Posted by Yamazaki View Post
    Once I finish the swap it might be but for now I got 2 ecu's from the junkyard one from a 97 and one from a 98 and an NSS out of a 3rd gen. So hopefully later today Ill plug in the ecu's and have an update.
    Not guna ground to the starter anymore. EVER
  12. #72
    Nov 2011
    Maryland
    483
    7,907
    59
    FIXED! lol
    So dropped in the new ECU started right up! (THANK GOD!)
    New NSS will go in hopefully later today wire everything up and NOT fry the ECU again is the goal... smh.
    Will keep you all posted!
  13. #73
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,542
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    PICTURES!!!! I beat @Dead91silvia to it this time.
  14. #74
    Nov 2011
    Maryland
    483
    7,907
    59
    Cant win.....
    Drives just fine.... cant stop.... busted rear brake line !#$@*(&@!(*&#^!@#(*^(*&%!#!$)(*&
  15. #75
    5,050
    Quote Originally Posted by 98legwag View Post
    I dont know what you're talking about.... He still hasent posted so I still beat you like weeks ago. :P
  16. #76
    Nov 2011
    Maryland
    483
    7,907
    59
    I'm hoping to pick up the brake lines are work today and have the car back up and running tomorrow once the brakes are bled!
    I'll keep you posted and maybe post pictures smh
  17. #77
    Nov 2011
    Maryland
    483
    7,907
    59
    So picked up the brake lines and couplers and flaring tool. Around 2am last night gave up as It just would not stop leaking.
    5 out of 6 of the flares dont leak. Need to finish the least one and bleed the brake system.
    Wish me luck!
  18. #78
  19. #79
    Nov 2011
    Maryland
    483
    7,907
    59
    Figured out what was wrong. Make sure you have the right couplers when replacing harlines.
    Drove the car around today and love it as a manual.
    Had a mechanic friend take a look at it.
    Needs a new pressure plate(heavy ass clutch) and input shaft bearing. Whines pretty bad in 5th gear.
    But I'm happy!
    Update on wrx swap
    Changed my mind in terms of interior swap. I think I'm just going to have Iwire do a harness merge for me. Not committed to the idea of cutting more holes in the fire wall + more downtime. Pull the dash once. Send it out for the harness merge while the engine is being built plug it all in and on my way!
  20. #80
    Moco, Maryland
    3,542
    16,957
    P i c t u r e s !
  21. #81
    1,408
    12,999
    74
    That's pretty cool that you can just send the loom off to get merged! Makes the process pretty accessible to anyone who can pull a motor out!
  22. #82
    Nov 2011
    Maryland
    483
    7,907
    59
    Bug guard was broken while trying to fix the hood latch. It works now perfectly.
    I don't mind the bug guard less look but It def has to come back!
    Part Number in case anyone wants it
    Hood Deflector / Bug Shield is a direct fit for the following:
    1995-1999 Subaru Legacy
    1995-1999 Subaru Outback
    Genuine Subaru Part Number: E2310AS001
  23. #83
    Nov 2011
    Maryland
    483
    7,907
    59
    Took her out for a quick spin tonight. Still gives me the biggest stupidest smile just to drive her =)
    Cant wait to finish the swap but more than happy with the progress.
  24. #84
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Points: 5,984, Level: 50
    The thing is.. Where's the Pictures?
    1997 Legacy GT Wagon
    1998 Legacy L Wagon
    @TylerHartman on Instagram
    Thanks Tyler
  25. #85
    5,050
    Quote Originally Posted by Tylerhartman View Post
    See, I'm not the only one Nate! Get on it! lol
  26. #86
    Moco, Maryland
    3,542
    16,957
    Pictures or it didn't happen.
  27. #87
    ROTM Master peugoby's Avatar
    Sep 2006
    Seattle, WA
    1,241
    14,689
    78
    Points: 14,689, Level: 78
    Level completed: 60%, Points required for next Level: 161
    I had to....
    '95 Subaru Legacy L AWD Wagon - Original Owner lBBS l CUSCO l WHITELINE l SPT
    '98 BMW E36 M3
    '18 VW Alltrack SE DSG
    '01.5 Audi A4 1.8T Quattro/Manual/APR Stage 2
  28. #88
    Nov 2011
    Maryland
    483
    7,907
    59
    OH boo hoo! Ill Post them... eventually lol! Too lazy
  29. #89
    Moco, Maryland
    3,542
    16,957
    I guess it didn't happen
  30. #90
    5,050
    I'm even posting at least some progress pics! :P
