Page 2 of 3 FirstFirst 123 LastLast
Results 31 to 60 of 64
Thread: Engine swap questions READ HERE FIRST
  1. #31
    t3h ub3r m3mber impreza_GC8's Avatar
    Carbondale, IL
    1,120
    7,720
    Points: 7,720, Level: 58
    Re: Engine swap questions READ HERE FIRST
    Some of this information isn't exactly accurate but nonetheless still a good summation for anybody wondering. EJ20K was only produced for a single model run, then they switched to the EJ205/207. EJ20K isn't known for its reliability but out of the box is a very strong motor.
    -'97 Legacy Outback - 5MT, DOHC EJ25D/EJ22T hybrid w/ VF8 turbo @ 11psi - 170 whp / 200 wtq (untuned)
    -'00 Impreza 2.5RS - 5MT, LSD, STI Ver 4 interior, I/H/E, spring/strut combo, still N/A
    Past ROTM winner! Thanks for the support SL-i!
  2. #32
    8
    2,900
    32
    Points: 2,900, Level: 32
    Level completed: 50%, Points required for next Level: 150
    Very helpful thanks for the sticky now I know what engine to use for my swap 2 thumbs up
  3. #33
    New User oamster's Avatar
    Mar 2010
    Prescott Az
    23
    3,708
    38
    Points: 3,708, Level: 38
    Level completed: 39%, Points required for next Level: 92
    Would I be able to swap block halves? Like swap my open deck block for a semi closed deck without having to worry about wiring? I don't have to worry about emissions where I live, so I was planning on swapping the open deck for a semi closed deck and put my ej25d heads on it. Boost it, and put in a new ecu or piggy back.
    I wouldn't have to worry about the wiring normally associated with swaps right?
  4. #34
    Jul 2009
    Everett, Wa
    1,531
    7,580
    Points: 7,580, Level: 58
    ^^Swapping the block for another one of the same displacement (and keeping the static compression ratio about the same) won't require any other changes.
    NOOB
    Giggity
    oh boy, thats bad for canada!
  5. #35
    Mar 2010
    Prescott Az
    23
    3,708
    38
    Quote Originally Posted by mike-tracy
    And if I wanted to change the compression (lower eg. for a turbo) the only change I would really need (electrically) would be engine management correct?
  6. #36
    "FNG" 03 Subaru GT's Avatar
    Jul 2011
    Scotchtown, New York
    2,787
    32
    Points: 2,787, Level: 32
    Level completed: 25%, Points required for next Level: 113
    I found a 04-05 WRX in a junkyard near my girlfriend's house and after reading this topic, immediately got all happy inside because of it. So according to this, the swap would work and all I would really need to do once its dropped in is to rewire it, bolt together, and then shim the turbo crossmember and lenghten the exhaust so everything fits? Also the tranny on the WRX was automatic, so I'm wondering if I'm gonna have some problems?
  7. #37
    SLi O.G. httrdd's Avatar
    NEPA
    2,700
    11,761
    Points: 11,761, Level: 71
    Buying a parts car would be your best option. That way you have all the parts you need and more to sell to get some money back. That is what I did to fund my swap.
    TJ
    99 LGT H6 Limited OBP
  8. #38
    Jul 2011
    2,787
    32
    Quote Originally Posted by httrdd
    Well the car is wrecked. I'm stoppin by tomorrow to check it out and see what's what so I know what's salvageable. I'm really hoping the engine is, but at the same time, I'm worried about the tranny problem
  9. #39
    Jan 2012
    Mass
    174
    3,188
    34
    Points: 3,188, Level: 34
    Level completed: 92%, Points required for next Level: 12
    THats something I was thinking about, with my 98 wagon having 240k on it, shes tired. I wanted to do a respectable swap from a wrx or so but I cant have my daily driver sidelined long enough to pull the wiring harness and rewire the entire car as well as swapping out the motor and trans.
    If I were to pull the 2.2 w/ 5spd from another car will I have to pull the wiring too or just the ecu? I already have the clutch pedal assembly, and I know Ill need the reservoir, cables etc but will it match wiring-wise?
    1998 BK4 wagon... 241k Panda FTW!
  10. #40
    Oct 2012
    Berwick, PA
    10
    1,779
    24
    Points: 1,779, Level: 24
    Level completed: 79%, Points required for next Level: 21
    Question: What about swapping the EJ33 from the SVX into an 01 Outback? I've seen them done onto older Outbacks, but I was wondering if it's possible for the newer one?
  11. #41
    SLi nOOb EJ22D's Avatar
    Nov 2012
    193
    2,277
    28
    Points: 2,277, Level: 28
    Level completed: 85%, Points required for next Level: 23
    Quote Originally Posted by tnrknght
    If you were to pull a 2.2 w5spd, it would have to come w/the rear diff to that 5spd (or another FGR matching rear diff).
    Also, if the car you're swapping all of that into was a 5spd to begin with, then everything concerning the engine will be plug & play, wiring & all.
    If the car you're trying to swap all of that into is an auto, there are some wiring differences due to the EGR & such.
    Quote Originally Posted by BlazingAsura
    Shoot for an EZ30. That way, you won't run into too many issues when you go for emissions, which will fail you for having an older engine in that new of a car.
  12. #42
    Oct 2012
    Berwick, PA
    10
    1,779
    24
    Eh, it was just an idea. I have an old SVX with the motor with 154K on it, and the thing will be heading to the junk yard.
  13. #43
    Nov 2012
    193
    2,277
    28
    Save that engine & wiring harness.
    Dropping one of those into a BD body or a GC body will create a small rocket with tq to spare.
  14. #44
    Oct 2012
    Berwick, PA
    10
    1,779
    24
    Well I don't have the money to play with removing the engine and stuff, but if someone else would like, message me for the info on the car.
  15. #45
    Dec 2012
    1,579
    22
    Points: 1,579, Level: 22
    Love it.
  16. #46
    "Proby" pleaidestar's Avatar
    Dec 2012
    el paso texas
    268
    2,320
    29
    Points: 2,320, Level: 29
    Level completed: 14%, Points required for next Level: 130
    Hey everybody, I'm doing a swap into my bd legacy, although I know the swap will work I do have a question.
    The downlow: I'm replacing my 95 ej22 automatic motor to a 98 ej22 came out of a vehicle equipped with a standard transmission...I know that I will have to use my 95 intake manifold and wiring if I wish to equip the egr back into the motor(because the 98 manifold isn't tapped for it). If I don't want to equip the egr back into my car will it have adverse reaction on performance? I have heard that the intake manifold from that motor flows a ton better, so my next question is that if I can use the intake from the 98 and use the 95 wiring harness for the intake? Maybe I can just take the plug for the egr solenoid out of the harness or just tuck it away.
    2000 subaru legacy l wagon (5mt) 176,356
    9o Subaru legacy LS wagon 5mt (297,493) halfway there
    "In the divorce she can keep everything but my Subaru "
  17. #47
    Dec 2012
    el paso texas
    268
    2,320
    29
    This is the right place to ask that question right?
  18. #48
    New User EJ205B11's Avatar
    Mar 2012
    Montoursville, PA
    2,133
    27
    Points: 2,133, Level: 27
    Level completed: 89%, Points required for next Level: 17
    Hey guys I have a 99 Legacy SUS that had an EJ25D and the head gaskets went for the second time. So I found a 2.2 with the dual port exhaust and swapped it in and it runs fine but the lights wont stop flashing. The hazards and the cluster lights are flashing. Does anyone know how to make this stop?
    "When in doubt, flat out!" - R.I.P. Colin.
  19. #49
    Jul 2013
    Tazewell VA
    739
    4,313
    Points: 4,313, Level: 41
    Quote Originally Posted by EJ205B11
    Assuming you unhooked the battery when you did the swap. It sounds like your keyless entry system isn't happy with you.
    http://www.cars101.com/subaru/keyless.html#code alarm
    That will help.
    My 1997 Legacy L
    Fuelly
  20. #50
    t3h ub3r m3mber harrymaneuvers's Avatar
    Mar 2009
    HighCal (aka NorCal)
    1,789
    11,027
    Points: 11,027, Level: 69
    Level completed: 45%, Points required for next Level: 223
    Are the two green connectors under the steering wheel connected? They shouldnt be.
    Harry Maneuvers
    SOLD - 1984 Brat Turbo E81
    SOLD - 1989 XT6
    SOLD - 1991 Legacy SS
    SOLD - 1999 Legacy Sedan 30th Anniversary EJ251/EJ22 High Comp Frankenmotor http://sl-i.net/FORUM/showthread.php?15427
    SOLD - 2004 WRX Wagon Widebody - The Braggin Wagon http://sl-i.net/FORUM/showthread.php?15237
    2006 Forester XT - Mrs. Fancy http://sl-i.net/FORUM/showthread.php?15753
    2016 Outback 3.6R Limited
  21. #51
    "FNG" subyj's Avatar
    May 2012
    Akron Ohio
    89
    2,414
    29
    Points: 2,414, Level: 29
    Level completed: 76%, Points required for next Level: 36
    Wow I'm really glad I found saw this, I have a 2000 outback auto with a leaky hg and the tranny is starting to shift hard so I'm thinking a swap to the ej20t with the 5 speed is in order, the only thing I don't understand is the wirin, my out back is a limited so it has the dual sunroof and heated seats, i honestly don't know if these could be spliced in? But everything else seems pretty straight forward
    00 lowback
  22. #52
    Jul 2014
    3
    429
    8
    Points: 429, Level: 8
    Level completed: 58%, Points required for next Level: 21
    3 months registered250 Experience Points
    OK so I have read this twice now to make sure but it doesn't give me the info I need so here is my question. I have a 99 legacy wagon L 30th anniversary 2.2L and I have been told a few times that the 99 2.2 was special for that year and no other 2.2 can just bolt in so is this true if so what are my options for a swap, can I keep the ECU with a different engine or can I do an easy engine and ECU swap with say a late 90's 2.5 and ECU but use stock harness?
    P.S. the 2.2 in it was toast after i was teaching a friend to drive a MT when he went at tack from 3rd to 2nd and the motor took full revs till it was at normal RPM for that gear and it made a hell of a knock after that and my assumption is he floated a valve and the piston smacked it.
  23. #53
    Jul 2013
    Tazewell VA
    739
    4,313
    The same ej22 came in the 99-01 impreza. You can also use an ej251/3 from a 00-04 ish legacy, impreza, or forester to replace your blown motor, just swap your intake manifold and timing gears over to it.
    My 1997 Legacy L
    Fuelly
  24. #54
    Jul 2014
    3
    429
    8
    ok cool thank you now 1 more question if i were to take say a 2.5t out of an early 2000 forester would it work with just the ECU, engine intake manifold and timing gear? or would their be more involved cause it's a turboed motor?
  25. #55
    SLi O.G. Muse's Avatar
    Jul 2012
    Willimantic, CT
    2,371
    10,774
    Points: 10,774, Level: 68
    it would be far more complex. You'd probably have to do a wiring harness merge. Then again, I'm not an expert.
    Also, I'm not sure where you're from, but at least in the US, Foresters didn't get a turbo until the mid-to-late '00s.
  26. #56
    Jul 2013
    Tazewell VA
    739
    4,313
    To be a 2.5 turbo forester it would have to be 04+ that's at least a harness merge. A turbo swap would be fun, but you're looking at a whole lot of work.
    My 1997 Legacy L
    Fuelly
  27. #57
    Jul 2014
    3
    429
    8
    ok thank you guys now what would have a 2.5 turbo that is in the year range to work because i really want a turbo so i don't have to go threw all the work of putting one in and then having the ECU remapped for it. i would rather have it ready to go unless a turbo install is not that bad and i'm in Maine USA so i would be dealing with mostly US models although i can get some crazy import engines from Canada if i had the funds.
  28. #58
    Jul 2012
    Willimantic, CT
    2,371
    10,774
    I'm pretty sure anything with a turbo is going to need a full harness merge. you're talking about two totally different beasts between NA and turbo motors.
    Maybe you can do an EJ22T, but I'm not sure.
  29. #59
    Dec 2009
    Kaysville UTAH
    1,823
    9,426
    Points: 9,426, Level: 65
    Wait your saying you can put a turbo engine in a car that didn't have one from the factory?!
  30. #60
    Oct 2013
    Tilton, NH
    3,179
    34
    Points: 3,179, Level: 34
    Level completed: 86%, Points required for next Level: 21
    So I'm looking at a 2003 WRX EJ205 swap into my 98 Legacy GT wagon. what exhaust parts do I need to use to make this work? does the WRX downpipe fit? what about the exhaust bits after that? will the downpipe mate up to the original LGT exhaust or are there other exhaust systems that will fit?
