hallo, my 98' outback is having trouble, it is slipping in first, it will engage (sort of) and the car will roll forward but if i give it any amount of gas it just slips, the clutch is fine, i just put a different engine in from my other outback, I replaced the slave cylinder as it was a little rough when I played with the piston in it, but that didnt help, I am going to pull the engine again and check if i got oil on the clutch plate or something, just wondering if anyone had and solved this problem. cheers lads.
