Back in 2007, I got my SWP 2005 Legacy GT Unlimited as a stage 2 5EAT with a few mods and 2007 Shrek B interior swap minus door cards from a LGT.com member. It replaced my 2003 Mercury Marauder after it was totaled out. Remind me to find and post the video of my Marauder losing to a Subaru on a drag strip in MD which partially lead me to getting one. That and watching a bunch of Tommi Antero Mäkinen videos online. I was a ricer when I 1st got the car in my early 20's, you may see some stuff I didn't remove from those days pop up in pics.
Beginning of ownership pics
Not too long after I got it, I went to MIR and ran left lane against the speed 6 pictured.
Later,I swapped a member for painted wheels and also painted my calipers red
After ditching the TDC tune it came with, I went with DPS open source and ran 13.35 in the 1/4 but at Capital instead of MIR.
Fell on some hard times with no job and I ended up parting ways with my 2007 Shrek B interior. Downgraded (if you can call it that) to 2006 Tan Limited Interior. I kept the black carpet, deck, lower half, and seat belts. This was also the same member I swapped wheels with.
My mods list is this:
Installed
Have
Engine
*OEM 2008 EJ257 Short Block B25C 704 with BBBB pistons
*OEM VF 52 now Black JmP rebuilt with 11 blade billet compressor wheel
*OEM Engine Gasket Set (2005)
*OEM Timing Belt
*OEM Head Bolts
*OEM 10MM Oil Pump
*OEM Closed Impeller Water Pump
*OEM Oil Cooler
*OEM Oil Control Valves X's 2
*OEM STi I/C Sprayer tank
*TIC FU Cam Bolts
*LIC Aluminum Half Moons
*Infamous Performance & Tuning Filtered Turbo Oil Supply Line Kit V2
*AVO Induction Silicone Turbo Inlet
*Mishimoto Radiator Hoses
*Venair 5 Piece Ancillary Silicone Hose Set - Vacuum
*Venair 6 Piece Ancillary Silicone Hose Set - Cooling
*Venair BPV Return Silicone Hose
*Turkeylord Blue Tee replacement
*PERRIN TMIC
*GFB GT BOV 50/50
*GrimmSpeed CAI
*GrimmSpeed ECBS
*Hayden Tranny Cooler
Exhaust
*OEM STi UP
*GrimmSpeed 3" Down pipe to Factory Cat-Back Exhaust Adapter
*Stromung Divorced Waste gate shorty front DP + PERIN catted rear DP
*Mid Pipe Resonator Deleted for 2 bullet style resonators
*2 Aero Turbines used as rear cans
*Custom Angle Cut Pypes Quad Tips Panted Black
Suspention
*Tein S Tech Wagon Springs
*Cobb Front Sway
*Mevotech LCA's
*Kumho Ecsta AST
*Hawk Brake Pads
Interior
*OEM 2006 Legacy GT Limited Tan Interior Swap with 2005 passenger seat(for seat belt and airbag functionality)
*OEM 2005 LL Bean Wood MOMO Wheel and auto shift knob
*Prosport Boost Gauge
*CasopoliS Cubby Boost gauge pod
*Flip Key Conversion
*35% Tint
*Jazzy Aux
*2007 LGT Radio
*YourLEDshop White Puddle, Trunk, License Plate, and Map LEDs and Red Dome LED
*No Name generic 15 Inch Sub in generic build a box and unknown amp(will look and see)
Exterior
*TheGrilleGuy Stiletto Black insert
*Lamin-X tinted Tail Light Overlays
*Black Rally Armor UR flaps W/ white lettering
*2005 Legacy GT Wheels Painted Gloss Black
