Page 1 of 9 123 ... LastLast
Results 1 to 30 of 271
Thread: TylerHartman's 1999 Legacy GT Wagon STI 6MT
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Points: 5,984, Level: 50
    TylerHartman's 1999 Legacy GT Wagon 5SPD
    Well on Tuesday, November 18th at 4 am I was on eBay and Came across a 99 Legacy GT Wagon with a Blown Engine over 2,100Miles away ending at 5:00 PM. Long story short I ended up winning the car...
    The Car: 1999 Legacy GT Wagon 5 Speed with Sunroof. Pretty Rare combo I've heard, It has a 137,000 Miles and Suffers from two dents from the pictures I can see and a Knocking engine, although the dents and engines are Aye-Okay in my book since I've been watching for a Rust Free, 5 Speed wagon here in Indiana/Ohio for a while and haven't found anything this clean or sweet.
    Body Work/General Completed
    -Respray Factory Color
    -DogLeg Trim Pieces Deleted
    -Antenna Deleted
    -Badges Holes Deleted
    -JDM AeroMajic Rear Skirt With Custom Mounts
    -Refinished Roof Rack
    Maintenance Work
    -Steering rack boots
    -Por15 Painted Front Swaybar, Rear hubs, knuckles, Front Sway bar brackets
    -Rear Wheel bearings,
    -Front Drivers Side Wheel Bearing
    Parts on the way or order soon:
    Outfront EJ25
    Chamber-matched T20 heads
    BC stage 2 cams
    ARP 625+ Studs
    BC valve springs
    Link G4X ECU
    Link Wiring adds
    Radium double pumper with x2 Walbro 450's
    IAG fuel rails
    Fuel labs FPR
    Killer B Holy header
    Killer B Oil pan
    Killer B High flow water neck
    Cobb 4 Bar map sensor
    ID1300X2 injectors
    FMIC kit
    OEM Head gaskets
    RCM cam gears exhaust
    HKS Timing belt
    -JDM BG5 Rainguards
    -eyelids
    -Chargespeed Yellow Glass
    -JDM Prova Grille
    -Esams Mirror covers
    -Prova Hood lip
    -SYMS S2 Front Bumper
    -SYMS Hood scoop
    -SYMS Blend Panel
    -Aeromagic Midwing
    Exterior:
    -Llumar 35% Carbon all the way around
    -HOOD STRUTS/DAMPERS Prova Carbon Fiber
    -Beatrush Belt Cover
    -JDM SYMS Brake Master cap
    -JDM SYMS Clutch Master Sock/Band
    -JDM ZERO SPORTS Cool Radiator Legacy Cover
    -JDM ARC Carbon Fiber Hood scoop Extension
    -JDM Greddy/Trust Lip (RIP)
    -JDM SYMS Grill
    -JDM Hipposleek Grille
    -JDM SYMS Skirts
    -JDM AeroMajic Rear Skirt/Lip
    -JDM Liberal 3 Part wing
    -JDM Silm Door Moldings
    -JDM Facelift Bumper + Bumper Beam
    -JDM Projector Fog lights
    -JDM Clear Side Markers
    -JDM Smoked “kouki” tail lights
    -JDM Projector Headlamps
    -Morette Lights with CB&D Brackets using G5-BRT Projectors-D2S
    -FX-R 3.0 3"
    -3Five Ballasts
    -D2S 5500K Bulbs
    -CB&D Mounts
    -JDM GTB L7 Red Badge Grill
    -JDM Power Folding Mirrors with 95 USDM Bases
    -Hella Supertone Horns
    -Honda Pilot Wiper
    -CDM Roof Rails
    Interior:
    -JDM BG5 GT/GT-B Camo-Stripe Interior (Front Seats, back seats with cup holder and slide up cargo net)
    -JDM BH5 Cargo mat
    -JDM Wood Center Vent
    -JDM BH5 S-Edition/S401 Black Visors
    -JDM BH5 Steering wheel with Black Momo Airbag
    -BG5 option CCFL high powered Dome light
    -BG5 Option neoprene mat
    -JDM Spring-loaded Ash tray
    -JDM Option Extended Armrest
    -OEM Puddle light kit
    -TopStitchTrim Shift boot
    -JDM BH5 Black Oh-Crap Handles
    -Dyed Black Mirror Visors clips
    -Noico 80 mil 36 sqft + 18 Sqft car Sound deadening
    -Outback Floor panels (Tie-down points)
    -USDM 98-02 Forester Option Leather E-Brake Handle
    -EDM/USDM (Rare) Door Grabs
    -OEM OB Limited Rear D Pillar Tweeters
    -JDM Aluminum Legacy Door Sills
    -JDM Center Console E-Brake Trim
    -JDM Auto-Shift bezel modded for the shift boot
    -Blacked out carpet
    -Blacked out Headliner with Fiber optic Starlights
    -Rare Dual socket Ashtray delete
    -LEDS
    -Red Sitch Leather Ebrake Handle
    -OEM 6MT Shift Knob
    -Beatrush blue reverse lockout
    -Cobb Short Throw Shifter
    -JDM Tommy M20TB Gauge Pod
    -Electronics/Audio
    -Defi ZD Club Sport (Water temp, Oil pressure, oil temp, Tacho, and Speedo)
    -Defi Advance CR 60mm Boost 2bar
    -Defi Advance CR 60mm Oil Temp
    -JDM OEM S401 BFM Gauge Cluster
    -Dakota Digital SGI-5E Speed convertor
    -Innovate ECF-1: (FUEL) Ethanol Content & Air/Fuel Ratio Gauge
    -JDM Panasonic ETC CY - ET906KD
    -Skar Audio TX65C COMPONENT SPEAKERS Front and rear with IA tuning adapters
    -Alpine CDA-7894
    -Alpine MDA-5051
    -Alpine PWE-S8 Under seat sub
    -I30 Auto-Dimming Rearview Mirror
    -Fiber Optic Starlights
    Engine & Drivetrain:
    -JDM EJ207 T20 Big Port heads
    -JDM EJ207 S20C (bored to 92.5mm)
    -JDM EJ207 Cross-drilled crank
    -BC Valve springs and retainers
    -Manley H-Beam Rods
    -Manley Platinum series pistons
    -ARP 2000 Head studs
    -Cometic Head gaskets
    -OEM 11mm STI oil pump
    -King racing Rod and crank bearings
    -STI 08-14 Top Mount Intercooler
    -Turbosmart 40MM EWG
    -ID1050X Injectors
    -Grimmspeed 3Port EBCS
    -APS S/R-40 (GT2876R)
    -APS 3" Hard inlet
    -APS 70mm Cold air with new K&N
    -Getadomtune Coolant reroute kit
    -Johnson tuning Speed density kit
    -Mamba GT28/GT30 Stainless Line kit
    -JDM EJ207 V8-V9 Long Runner Intake
    -Fluidamper Crank
    -HKS EL 2 Bolt header
    -HKS Hard Inlet pipe
    -HKS heatshield
    -Nightpager Catch can
    -Bachler Racing Coolant Lid
    -Custom DrivenFab MidPipe 3" to 2.5"
    -Apexi Megaphone Dunk Muffler
    -Kartboy 15mm Extended hangers
    -Killer B EJ25 Pickup
    -Killer B Windage Tray
    -06+ STI Oil Pan
    -Greddy/Trust Type S BOV with an adapter flange and TurboSmart plug
    -GrimmSpeed 38mm EWG Up pipe with Screamer pipe
    -Invidia Catless Downpipe
    -iWire merged with AVCS EJ205/EJ207 V7, With TGV Delete)
    -WALBRO 255LPH FUEL PUMP
    -Prova 1.3 Bar Cap
    -eBay Rad modded with steam port with OEM FXT rubber lines for over flow and extra 1/8 NPT for temp sender later
    -JDM Cool-Nuts Coolant hoses
    -JDM GC8 Ver1-3? Fender Coolant tank
    -JDM STI V7 6MT
    -JDM R180 3.9
    -Snorkus Delete
    -Goodridge Stainless Steel Clutch Line Kit Clear 04-05 Subaru Impreza WRX STI
    -Poly Front Shifter (stay) bushing
    -Kartboy Rear Shifter Bushing
    -TiC Ver7 Pivot Linkage Shifter Bushings
    -Kartboy Subframe bushings
    -Karboy Rear Outrigger Bushings
    -JDM Grounding kit (Zerosports or syms?)
    Suspension & Brakes:
    -Fortune Auto 500 Coilovers 8K Front - 6K Rear - Radial Bearings
    -JDM SUBARU LEGACY BG5 BD5 STI CARBON FRONT STRUT TOWER BAR
    -JDM Cusco Rear Sturt Tower Brace Carbon Fiber
    -JDM Cusco Rear Diff/Subframe Brace
    -JDM Mines Lower Arm Bar/Brace
    -JDM Garage Dog House Roof brace
    -JDM Do-Luck Back Seat Floor brace
    -JDM BG5 Cusco Rear sway bar
    -Group N Sti Pinch mount
    -Group N Sti Transmission mount
    -GrimmSpeed Master Cylinder Brace
    -Kartboy Front Endlinks
    -EBC Rotors (Rear)
    -StopTech Pads (Rear)
    -Goodridge G-Stop Stainless Steel Brake Line Kit 90-01 Subaru Impreza Legacy
    -225/45ZR-17 BFGoodrich g-Force Sport COMP-2
    -2004 STI BBS Wheels (Bronze)
    -Whiteline Front Lower Inner Rear Control Arm Bushing & Bracket Subaru (W53515)
    -BE5 STI Alloy Control arms
    -94 Turbo Legacy Cross Member
    -94 Turbo Legacy Steering Rack
    -94 Turbo Legacy Sway Bar 18mm (Repainted)
    -Whiteline KSR202 Steering Rack Bushings
    -Whiteline KBR HD Rear Sway Bar mounts with PROTHANE 19-1164 GREASABLE Bushings
    Pictures before I even bought it
    Here it is today
    Last edited by Tylerhartman; 11-03-2023 at 11:17 PM. Reason: Adding goodies to my Build
    1997 Legacy GT Wagon
    1998 Legacy L Wagon
    @TylerHartman on Instagram
    Thanks Tyler
    5,050
    Looks like a nice canvas to start with for sure! Pretty clean!
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Thanks that's exactly what I thought when I saw a fairly clean body and blown engine
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    TylerHartman's 1999 Legacy GT Wagon 5SPD :Mods on the way!
    Quick Preview of what's coming
    JDM Side Markers, JDM Rear lights, and Momo Wheel.
    [URL=http://s851.photobucket.com/user/xbox_360_Reapir/media/99LGTWGN/s-l1600.jpg.html][/URL
    1998 Legacy L Wagon
    Thanks Tyler
    3,525
    Well done. That car looks pretty clean.
    SLi Lurker foohfooh's Avatar
    Jan 2013
    Seattle/San Diego
    431
    5,362
    Points: 5,362, Level: 47
    Nice to see you back!
    SLi Supporter CaleDeRoo's Avatar
    Nov 2014
    Rochester, NY
    304
    3,390
    36
    Points: 3,390, Level: 36
    Level completed: 27%, Points required for next Level: 110
    Nice
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Thanks guys! I'm glad to be back
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    ONE OWNER, Till now
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Video of it running. LOLOLOLOL
    The big dent I get to pay to get fixed YAY!
    1998 Legacy L Wagon
    Thanks Tyler
    Jan 2013
    Seattle/San Diego
    431
    5,362
    I would kill for a slate that clean! And that color
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    It's so pretty <3
    - - - Updated - - -
    - - - Updated - - -
    Test fitted the JDM Side Markers
    Got my new STI Key
    1998 Legacy L Wagon
    Thanks Tyler
    ROTM Master peugoby's Avatar
    Sep 2006
    Seattle, WA
    1,241
    14,689
    78
    Points: 14,689, Level: 78
    Level completed: 60%, Points required for next Level: 161
    Congrats! Looks like a clean slate to start from. Nice mods so far.
    '95 Subaru Legacy L AWD Wagon - Original Owner lBBS l CUSCO l WHITELINE l SPT
    '98 BMW E36 M3
    '18 VW Alltrack SE DSG
    '01.5 Audi A4 1.8T Quattro/Manual/APR Stage 2
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Found some Trash under the rear seat and trunk area
    Found tons of dirt
    Installed my Zero/Sports Cover (isn't as good as it was pictured, But I'll work with it)
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    GC8 Hood Dampers/Struts
    Threw on my Old JDM Plates and My New Hella Horns
    Removed the AWD Badge off My Trunk
    Pulled one of the Plugs for fun
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Carbon Fiber Brace on <3
    Led Plate Bulbs
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Tylerhartman’s 1999 Legacy GT Wagon 5SPD BROKEN JDM LIGHTS :(
    Well my JDM lights showed up, The center part got broken Been sad all day.
    Momo Red stitched wheel came in
    Leds in the door and over headlights.
    My goodies, Sadly the center garnish is busted Anybody have an extra? Paypal ready :/
    I'll update more once my pictures upload
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Well I've been quite busy grabbing parts so here's what I've got
    -WALBRO 255LPH FUEL PUMP Subaru Impreza WRX STi EJ25 RS w/ Install Kit 400-791
    -AEM 30-4110 DIGITAL WIDEBAND UEGO CONTROLLER AIR FUEL RATIO KIT NEW BOSCH 4.9LSU
    -04 SUBARU IMPREZA WRX WAGON CHASSIS BODY INTERIOR BULK WIRING HARNESS
    - OEM Genuine Honda 76720-S9V-A01 Windshield Wiper Arm
    -JDM SUBARU LEGACY BG BD PROJECTOR HEAD LIGHTS
    -Subaru Impreza WRX 2.0L Turbo Intake Manifold Collector Aluminum EJ205 Oem 02-05
    -JDM RFRB Door Trims, JDM Climate Control, JDM Climate Control Trim/Vents, JDM Inside door Handles, JDM Door sills (Some Dings but okay shape to use), and JDM Spats but need some work (Cracking and wrong color)
    -JDM Grille L7
    -JDM Cusco under body Brace
    1998 Legacy L Wagon
    Thanks Tyler
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Here's one little lot of stuff I got
    Here's the grille in with Stock Lights
    Door sills
    1998 Legacy L Wagon
    Thanks Tyler
    3,525
    This is going to be fantastic.
    Jan 2013
    Seattle/San Diego
    431
    5,362
    Boosted white gt! Yeshhh.
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Thanks for the love guys I'll have some more stuff coming up soon
    1998 Legacy L Wagon
    Thanks Tyler
    SLi Resident fwa2500's Avatar
    Mar 2008
    KCVG -> NZPM
    561
    9,511
    Points: 9,511, Level: 65
    Level completed: 54%, Points required for next Level: 139
    I still have my bumper if you still want it
    '11 Lexus CT200h - Feb. 2024-Present
    '12 Toyota Aqua - AKA Prius C, JDM city runabout. Sold. Apr. 2023-Feb. 2024
    '09 Toyota Crown Hybrid - JDM executive missile. Sold. Oct. 2019-Feb. 2024
    '00 Toyota Vitz Clavia - Sold. Mar. 2018-Jun. 2021
    '11 BMW 328i Xdrive - Sold. Nov. 2016-Apr. 2018
    '08 Legacy 3.0R Limited - Sold. Mar. 2015-Aug. 2016
    '97 Legacy wagon (BK) TS-R wanna-be - Retired. Oct. 2007-Jan. 2015
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Quote Originally Posted by fwa2500 View Post
    I know I was thinking about that the other day, I'm getting over a cold. I might need to venture over your way once my cold has disappeared. I'll write you on the cincinnati group ;-)
    - - - Updated - - -
    Quote Originally Posted by peugoby View Post
    Loving this project so far! Lot's of good stuff going on here.
    Thanks! It's my only dream to be as JDM as you. ;-) I've got a drivetrain to sort out first though
    - - - Updated - - -
    Solid JDM stuff going on here, good shit!
    Thanks! You know you can support the build by sending me your limited bumper ya know? ;-)
    1998 Legacy L Wagon
    Thanks Tyler
    Sep 2006
    Seattle, WA
    1,241
    14,689
    78
    '98 BMW E36 M3
    1,406
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    1998 Legacy L Wagon
    Thanks Tyler
  28. #28
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Jdm goodness is here
    Something happened over the weekend.
    Third try is the charm, Finally have a set.
    Just sat my Yakima Basket case on the waggy.
    1998 Legacy L Wagon
    Thanks Tyler
  29. #29
    Aug 2011
    Scappoose, OR 97056
    545
    5,984
    Something big is coming up... :D
    1998 Legacy L Wagon
    Thanks Tyler
  30. #30
    SLi Resident iampetro's Avatar
    Nov 2007
    600
    9,482
    Points: 9,482, Level: 65
    Level completed: 44%, Points required for next Level: 168
    Here in Ottawa Canada a set of '04 STi BBS rims in 5-8/10 condition go for $1000. more if they are in 9-10/10 condition
    I hope the market is better where you live
