Hello Everyone,
I've read that a 2002 through 2007 Impreza WRX coilover set, and the coilovers in the link below specifically, will fit a 95 through 98 Legacy Outback.
Is this true?
http://raceland.com/subaru-wrx-sti-i...coilovers.html
Hello Everyone,
Is this true?
XVI///
This should tell you everything you need - https://sl-i.net/FORUM/showthread.ph...704#post266704
2005 BL Legacy 2.5GT (Wife's VF52 powered Grocery Getter)
1997 BK Legacy GT Wagon (2.1 Stroker Build in progress)
2004 GD WRX (16G Panty Dropper)
1991 SW21 MR2 (Camry V6 powarrr)
1992 1Gb Plymouth Laser RS-T AWD (Unicorn)
Good information, thanks!
XVI///
BC Racing has a set that is made to fit although around $1000. F-09 is the part number.
http://www.importimageracing.com/bc-...1995-1999.html
Feal Suspension will make you a set but you have to give them the correct info....and $1400. I believe GC chassis front (for the correct camber plate orientation) and GD chassis rear top hats is what you want.
http://fealsuspensionstore.com/produ...ory/coilovers/
1996 Outback 5 speed
Do you know off hand if they charge more to put the same spring rates for the front and back on the BC Racing coilovers?
XVI///
I haven't read their website in awhile but do believe they will work with you on rates.
That would be great! Thanks for the help, I appreciate it.
XVI///
