Results 1 to 4 of 4
Thread: 04 vs 05-07 STI steering rack
    New User wncscoob's Avatar
    Nov 2014
    21
    906
    16
    Points: 906, Level: 16
    Level completed: 6%, Points required for next Level: 94
    500 Experience Points1 year registered
    Can anyone show me or explain to me the actual differences between the two variations of the STI rack? What differentiates one style from the other? If I was buying one, how would I confirm it was an 04, not an 05-07?
    Will the 04 rack bolt directly up? Will the 05-07? If not, what can I do to make it work. I have a lot of fabrication experience, can weld and have access to all kinds of plate steel
    Sent from my HTC6525LVW using Tapatalk
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Points: 18,003, Level: 85
    Discussion Ender
    http://www.rs25.com/forums/f128/t155...ap-thread.html
    Basically, the top steering rack looks like the 2004 sti (like your stock one), bottom is the 05-07 sti rack (like newer cars, 05+ legacy, etc).
    2005 Outback XT
    GO > Show. Every time.
    "FNG" Michelle's Avatar
    Feb 2015
    55
    2,173
    28
    Points: 2,173, Level: 28
    Level completed: 16%, Points required for next Level: 127
    From the research I've done, it looks like you'd just need the matching crossmember to use the newer rack. You would gain fixed mounting points on one side of the rack, seemingly making the feel of the steering input more solid. If both utilize urethane bushings, though, it might be impossible to tell the difference.
    Jan 2015
    Russia
    20
    1,071
    17
    Points: 1,071, Level: 17
    Level completed: 72%, Points required for next Level: 29
    very informative, really appreciated!
