Oh no no.. I wouldnt attempt to tow such a heavy car with mine.. that would go WAY over its towing capacity. @Yamazaki drove the car up to me this weekend.
2020 WMA Ascent Limited
But yours is a Subaru. They can do anything......
My cars:
2019 Impreza Sport
2008 Miata
1998 Legacy L wagon- Sold
2000 Outback- Sold
As sad as I am to know I will more then likely not see this car in person again, or drive it, I'm happy to know who it ended up with.
I'll need to see if I can dig up the pic I have of it when I had it as a loaner when I drove to DC to explore...![]()
I am sad to see it go too. But its got a good home and it will be finished with care.
My cars:
2019 Impreza Sport
2008 Miata
2000 Outback- Sold
That isnt true at all.. I can almost guarantee that you will see/drive this car again.
On another note.. new parts for this car! Legacy S401 springs. The STI Pinks that are currently on the car are too low for my tastes.. this will raise up the car about 15mm or so and give it firmer ride.
I am not sure when I am going to have a chance to put them on, but they did show up today.
Bwahaha rad! Crazy thread merge commence?!
i had to re-read the title couple of times before i realized what had happen,
Congrats on the new ride,
I registered the car today. Depending on weather this weekend, I may get the suspension figured out, which I am looking forward to.
What are you changing about the suspension?
edit: NVM just looked up DOH!!
Great pair of 3rd gen!
99 BK postal wagon
http://sl-i.net/FORUM/showthread.php?19010
98 BD GT
http://sl-i.net/FORUM/showthread.php?13830
97 BG outback
http://sl-i.net/FORUM/showthread.php?16329
97 BK GT wagon
http://sl-i.net/FORUM/showthread.php?17636
95 BK Wagon SOLD
http://sl-i.net/FORUM/showthread.php?17179
Nothing to report on this car either. She has been parked under my deck due to fairly limited parking options, and with all of the snow that we have had lately.. she is kind of stuck there for now.
I am eagerly anticipating the warmer days this week so that at least some of the snow can melt, and I can get her into the garage to do some work.
Cwtwbu766
97 RHD SOLD
99 RHD SOLD
01 Outback SOLD
01 LGT SOLD
I was able to get the car out and I did some work on her today.
I sorted out the rear of the car, tightened up all of the bolts, and changed out the rear shocks and springs with the set from the S401. I forgot to measure before and after, but it is a good 20mm or so higher than it used to be. I will be sure to measure the front when I change out the struts.
Comparison of the STI Pinks vs STI Blacks (S401 springs). Same number of coils, but the Blacks are not progressive, and the spring itself is about 2mm thicker.
How the rear sits now. I am sure it will settle a bit over time, but it seems to fail a shoe test as it is.
Once the front is done, then its alignment time.. and then recalibrate the VDC so it will work again now that the steering angle sensor has been replaced. That should keep me happy mechanically for a little while, so I can tackle the wiring.
Front is done! The car is now tall enough that I can use my low-profile car ramps. I did some measuring this time, and the car is quite a bit higher than I guessed.
First. Comparison of the STI Pinks and S401 Blacks: Same number of coils, just thicker springs.
Before, 63cm from floor to the top of the front wheel arch:
After: Almost 66cm!
So, a bit more than the 20mm that I guessed yesterday. I also took the opportunity to tighten up the rest of the suspension and re-orient the front swaybar. Tomorrow morning: Alignment time.
Looks great!!! Keep up the good work
Well done sir. Any pictures from the side showing how the whole car sits now?
My cars:
2019 Impreza Sport
2008 Miata
2000 Outback- Sold
I will get some overall shots tomorrow after the alignment. I havent moved the car out of the garage yet today and it is now dark out.
Alignment went well. I managed to get the front spot on by eye, which was nice. I had already re-centered the steering wheel, which is all it really needed. The rear was out by quite a bit, but I fully expected that since the subframe and most of the bushings were replaced back there.
In other news, I think one of the engine mounts may be broken.. there is a significant clunk up front when going on and off power. I have to get under there and look around. I am surprised at how much they are.. $120/ea at Subaru.
But enough about that, as promised.. here are photos!
Side shot:
Front quarter:
Rear quarter:
Dash: (I havent done anything here except swap out the steering wheel with one from a SG Forester XT)
The height looks perfect to me.
My cars:
2019 Impreza Sport
2008 Miata
2000 Outback- Sold
That height is spot on. Looks great!
Yes officer, I did hit a pedestrian, but instead of dwelling on that why not focus on how many I've missed?
Turns out this was not a broken engine mount.. but a loose pitch stop! I am really surprised the amount of noises the car was making with just one of the pitch stop bolts being a little loose. Tightened that up, and it has been doing very well for me ever since.
I still have something loose in the back end, I hear a good clunk when going over some largish bumps.. but I think I might have forgotten to tighten one of the swaybar endlinks when I was last back there..
Car looks good!
I'm not usually a fan of the Blitzens, but I think this color looks great.
As it should be. *nods sagely*
I have discovered that this car gets noticed... a lot.
In the 4 years that I have owned the RS30.. I have been only noticed on the road a half dozen times. In parking lots, people noticed the XV wheels quite a bit.. but you cant really see them when I am driving.
In the last 2 weeks... I have been flagged down, thumbed up, or waved to at least 5 times. One guy was trying to have a conversation with me about the car in Providence traffic last night. It is definitely a different experience, that is for sure.
Oh, and the louder exhaust encourages me to drive more like an ass.
Yeah. The H6 sounds so great with a nice exhaust note.
My cars:
2019 Impreza Sport
2008 Miata
2000 Outback- Sold
