Results 1 to 2 of 2
Thread: New gauge cluster, and other misc.
Size:  3.09 MBso it's a crappie photo, but if you look hard enough you can see that my instrument panel is a little broken. Some punks tried to take it for a joy ride, and destroyed the ignition along with my gauges. I was just wondering if there is anyway I can find a gauge cluster that goes higher than 120 to replace my old one with. Also if anyone knows how to put toggle switches in for the ignition that would be super helpful.Name:  uploadfromtaptalk1451369076567.jpg
    Sent from my SM-G900T using Tapatalk
    Apr 2016
    Chino Valley, AZ
    36
    2,141
    27
    Points: 2,141, Level: 27
    Level completed: 94%, Points required for next Level: 9
    Created Album pictures1000 Experience Points1 year registered
    I will be parting out my old Legacy in a few weeks. It's a parts car for my Outback now and it's getting the guts to make it run and drive. I have a perfectly good cluster and a good ignition switch. The only thing with the switch is that the key is pretty worn and it comes out without turning off the ignition. The cylinder is good because I can't just use any key to turn it. The cluster and switch is from a 99 Lego L 30th Edition, I don't know if that makes a difference or not.
