Results 1 to 5 of 5
Thread: Bypassing the ignition switch?
    "Proby" Felipe's Avatar
    Mar 2012
    Victorville, CA.
    237
    4,073
    Points: 4,073, Level: 40
    Level completed: 62%, Points required for next Level: 77
    Long story short...
    Starter
    Battery
    and
    Alternator are in good shape.
    Still the car will not start and at time it won't even click over the starter. Just a dead turn over. But yet everything is working.
    Can someone direct me to a wiring diagram on the ignition to bypass the key switch till i get a new set up?
    Tips will be awesome on how to turn the car on without the ignition.
    (ps no this is not related to any GTA whatever lol)
    Not really sure if I want a push button start :0/
    Pros:
    99 legacy, wagon, 30th aniversary
    Cons:
    color and auto trans.
    SLi Lurker foohfooh's Avatar
    Jan 2013
    Seattle/San Diego
    432
    5,362
    Points: 5,362, Level: 47
    Veteran5000 Experience Points
    Haha maybe if somebody can crank this out they can send it to you in a pm? Just sayin.
    Mar 2012
    Victorville, CA.
    237
    4,073
    I hope someone would.
    Till then i might just have to install a push button.
    Pros:
    Cons:
    Mar 2012
    Victorville, CA.
    237
    4,073
    So found the root of the problem
    Tada...
    I just opened it up cleaned up the contacts and resealed it.
    Just like new.
    Pros:
    Cons:
    Mar 2012
    Victorville, CA.
    237
    4,073
    I did this on a civic, much easier because it has screws to open and access the inside.
    This little bugger it shut so that you have to buy a new one. I was able to pry it open VERY carefully since its plastic next metal.
    Pros:
    Cons:
