Page 4 of 4 FirstFirst ... 234
Results 91 to 105 of 105
Thread: TylerHartman's 2006 2.5i Wagon
  1. #91
    3,506
    Check your rear sway bar bushings. My urethane ones squeak when they need to be lubed.
  2. #92
    Aug 2011
    Cincinnati, Ohio (47060)
    518
    5,984
    Points: 5,984, Level: 50
    Quote Originally Posted by 98legwag View Post
    Good idea, I should check I'm just lazy. after this snowy rain goes away. Might flip on them Audi a4 endlinks out back too
    @TylerHartman on Instagram
    Thanks Tyler
  3. #93
    Aug 2011
    518
    5,984
    Just bought a Full Navi dropout kit from a 2008 Spec-B from Pmp On Facebook for $150 Shipped, I know aftermarket head unit would be better but always loved the Factory GPS look and dig the sub menu's/features!
    Also bought a super nice 08-09 Leather wheel, and airbag cover to sell! Debating on getting paddles and Steering wheel audio control panel and retrofitting all of that in, but not 100% yet though but would be cake topper with the rest of my Facelift dash
    Also Got some JDM Upper door Tweeters!
    Thanks Tyler
  4. #94
    Aug 2011
    518
    5,984
    Updatesss
    First started off with a Facelift JDM mirror swap, these popped up already 37J SWP White and had to snag. Facelift JDM mirrors with the signals, Heated elements, Power-folding and being Non-Base model they also have bigger mirror glass!
    2.5i have the turn signals prewired to the door harness, so I grabbed up some OBXT/GT Door harness's and then added two wires for the power-folding part and added my plugs in for the HK sound system I retrofitted in the past.
    mirrors side by side
    I ended up raiding my stash and used 2.5i base model mirror connectors as the plugs for the Power-folding side of the harness to keep things clean and OEM. and I just depinned both plugs and pinned in the two wires for it
    All done! (wiring power-folding bits tomorrow to the switch)
    Needed new rear brakes, Went for some Centric Rotors (coated hats that won't look like poop in 3 months.) and EBC Yellow pads I snagged super cheap off a dude that ordered the wrong pads for his 2.5GT.
    Also took the time to grease up the sway bar, and check CV boots, etc..
    also have pretty much all the piece for a Mini H1 Bi-Xenon retrofit, other than one headlight splitter (why aren't these sold in pairs like everything else for headlights?)
    doing the 316mm x 30mm 05+ GT Front brake conversion super soon as well, just need rotors for that.
    Thanks Tyler
  5. #95
    3,506
    I am really shocked JDM mirrors came up in SWP because JDM cars are CWP.
  6. #96
    Aug 2011
    518
    5,984
    Facelift had SWP option, if you look up 37J BP5 you can find quite a bit of facelift parts. Prefacelift was all 36J
    Thanks Tyler
  7. #97
    Aug 2011
    518
    5,984
    EBC Yellows feel amazing but do have a little brake noise coming to a stop (I like it, but some might not) , and the Convex JDM glass on the LHD side is awesome.
    Speaking of paint code things.. Decided to mount up these Spats I've had forever. these are JDM 36J as you can tell, Not going to use all the double-sided tape since they will be getting pulled off at some point to be matched.
    Thanks Tyler
  8. #98
    Aug 2011
    518
    5,984
    picked up a DDX616 for $80 off FB, not the greatest but it's decent upgrade over my stocky, I'm setup for an even better unit now if I want to
    cleaned up the lights and buffed out the hood too
    Thanks Tyler
  9. #99
    Aug 2011
    518
    5,984
    I had some leftover Retrofit parts from MY honda element, so ordered the remaining pieces
    Mori MH1 Projectors
    Custom brackets and designs mounts
    Mori 4300k Bulbs
    Mori 3Five Ballasts
    Mori HD Relay: 9005/9006/9012/H10
    Mori H7 Headlight splitters
    Also ordered up the Rotors and pads for my 05+ LGT Front Brake conversion
    did the calipers the other day, wire wheeled, painted and greased up slides
    Thanks Tyler
  10. #100
    Aug 2011
    518
    5,984
    Headlights Rip!
    Centric Rotor/pad kit and Caliper upgrade, these things are amazing compared to stock 2.5i front brakes...
    Bought some Whiteline KLC32 Front end links for $10 missing hardware, few bucks at the hardware store and 25 for some replacement bushings and im set
    Also have some things on the way ;P
    Thanks Tyler
  11. #101
    This build deserves more attention. Great upgrades, keep us posted .
  12. #102
    Aug 2011
    518
    5,984
    STI Front bar
    JDM paddle shifters (need to trim the bezel a hair more and wire them in. but did that first leap of cutting to install them)
    B-Sport badges (more a less spec-B but N/A, kinda..)
    STI Option Pedals & Weathertech floor mats
    eBay LED Panels
    the dome light is the LG dank
    the bad news...Garnish came busted! we'll see what USPS/EMS will do, but this stinks
    Thanks Tyler
  13. #103
    These are some very cool upgrades, Tyler! Did you also install the telescopic steering shaft?
  14. #104
    Aug 2011
    518
    5,984
    Quote Originally Posted by *thomas* View Post
    No, but it's really tempting me. I know from what I've heard it's not a plug n play swap. you have to swap dash beams IIRC. I actually have a column just would need the dash beam and swap my lock cylinder jazz over
    Thanks Tyler
  15. #105
    Aug 2011
    518
    5,984
    JDM Foot well lighting kit
    Zero/Sports Hard pipe
    Thanks Tyler
