Results 1 to 4 of 4
Thread: Can not set timing correctly on EJ25
    Mar 2013
    Stockton,CA
    12
    2,857
    32
    Points: 2,857, Level: 32
    Level completed: 72%, Points required for next Level: 43
    I can not set the timing on my 97 legacy gt 2.5L DOHC.
    I've followed the haynes manual exactly and even looked at a few other sources. When I originally took off the timing belt , I did line up all five marks according to the manual. When i put the new one on, bolted everything back up, the car threw a CEL and started running in LIMP MODE. I have attempted this three times and it is still not correct. Are there any tips or tricks that I should know about to get this correct?
    5,051
    Did you rotate it a few times before start up? Also, what is the CEL for?
    Mar 2013
    Stockton,CA
    12
    2,857
    32
    I did rotate it a few times and everything looked and felt fine. I don't remember the specific code but they were about a misfire in #1 and crankshaft sensor issue
    209 NorCal
    1,684
    13,292
    75
    Points: 13,292, Level: 75
    Did you get the heads resurfaced? Supposedly if you have them machined many times they start throwing misfire code and some use this adjustable idlers to compensate for it.
    https://www.rallysportdirect.com/par...idler-bearings
    I know the 25d that I rebuilt will throw a phantom misfire on 3 (I think) when going past 70. It drives fine and doesn't do any misfire symptom.
