Results 1 to 4 of 4
Thread: BE Rear swaybar mount
    Th3 Asshol3 Airgne's Avatar
    Mar 2008
    横須賀 さいたま 日本
    2,953
    17,635
    84
    Points: 17,635, Level: 84
    Level completed: 57%, Points required for next Level: 215
    10000 Experience PointsO.G.Overdrive
    So my car is in the shop getting some work done because I neglected it for six years in storage. While on the lift the mechanic was inspecting before he started he found an issue. The rear swaybar mount is coming off from the body.
    Does anyone know if this will work? I don't remember what the underside looks like.
    https://www.rallysportdirect.com/fit...5w8aAgp-8P8HAQ
    2013 VW GTI(Daily)
    1991 Nissan Laurel(Weekend warrior)
    1997 Nissan Laurel ClubS25t(Sold)
    1997 Nissan Laurel Medalist RB26DETT swapped(Sold)
    1997 Nissan Laurel ClubS25t Drift Missile(Junked)
    2001 Legacy Gt Ltd(Sold)
    1992 Legacy SS(Sold)
    1991 Legacy L(Sold)
    Quote "I must reconcile courage and surrender in equal measure." Charlton Heston RIP
    Mar 2015
    Sydney, Aus
    1,680
    Points: 1,680, Level: 23
    Don't think so.. BE/BH rear mounts have a drop-down flange from the body and the mounts are a simple pipe-strap type arrangement with horizontal facing bolts..
    I suspect you've munted the flange
    this image nicked from http://legacygt.com/forums/showthrea...-164248p7.html
    Mar 2008
    横須賀 さいたま 日本
    2,953
    17,635
    84
    Sweet. Thanks. Now that I can see how it goes together again. Been 7 years since I looked at the underside. I have ideas how to get it fixed.
    2013 VW GTI(Daily)
    1991 Legacy L(Sold)
    2,790
    Yea, the swaybar connects to tabs on the subframe. If the subframe is rotting away, you probably should replace the whole assembly. The 2000-2001 subframes were not properly coated to prevent rust during manufacture, but the 2002-2004 frames are.
    That said, if the subframe is rotted, the 4 subframe bolts are probably not in great shape.. and will be quite difficult to remove without sheering them off.
