Results 1 to 4 of 4
Thread: 2010 Forester rotors on 03 BH Legacy?
    SLi nOOb dna's Avatar
    Feb 2015
    WV
    142
    2,614
    31
    Points: 2,614, Level: 31
    Level completed: 10%, Points required for next Level: 136
    Overdrive1000 Experience Points1 year registered
    Good Morning everyone, I have a quick question to see if anyone has tried this before I buy my parts.
    My plan, Buy 03 outback mounting brackets, rotors and pads to upgrade to bigger rotors.
    My dilemma, I am wanting to upgrade my rotors to the 293mm Outback rotors (currently 274mm I believe) and I have a brand new set of rotors for my 2010 Forester that I never put on (Same as 05+WRX and Legacy GT). Everything I read online says they are 294mm and when I try to cross over the part number to the Outback nothing matches. Does the 1mm make that much of a difference?
    I guess my next step if I don't hear back is go ahead and buy the parts, try the rotors and if everything fits okay ill post it up and let you guys know.
    Feb 2015
    WV
    142
    2,614
    31
    Also before it is said, I have spent the morning "searching" to find the correct answer before I posted this. Haha thought I would post this up just in case there is always that one guy.
    2,792
    Both the 2010 Forester and the 2001-2004 Outback have a 294x24mm front rotor, so it should be just fine.
    Feb 2015
    WV
    142
    2,614
    31
    Just to answer my own questions and to verify rknenicki's response the 2010 rotors fit fine no issues. See my build thread for details.
