Results 1 to 3 of 3
Thread: Rusty and broken antenna bolt
Hybrid View
    Feb 2016
    Austin, Tx
    21
    786
    14
    Points: 786, Level: 14
    Level completed: 86%, Points required for next Level: 14
    The other day, I tried to lower my antenna in order to wash my car, well the antenna was stuck. I tried removing the 2 screws holding the antenna so that I can see where the friction was and in doing so, one of the screws broke. So now my antenna is held on with just the forward screw and I still can't get it to budge. Also, the screw has caused the area under the antenna to rust. How difficult is it to retrofit the rear quarter window on a BH5 with the antenna and just patch the roof where the current antenna resides? I have never done rust repair before and have no idea how to go about doing it.
    May 2015
    Ottsville, PA
    19
    1,668
    23
    Points: 1,668, Level: 23
    Level completed: 68%, Points required for next Level: 32
    Rust repair is pretty straight forward, you just need to use either metal or fiberglass. The two different materials each have their own repair methods. I prefer metal, but it will also require a welder.
    Basically you need to sand/grind the rust back until you find fresh metal, then fix everything that was damaged by the rust.
    "FNG" Kamion's Avatar
    Aug 2016
    Slovenia
    25
    708
    14
    Points: 708, Level: 14
    Level completed: 8%, Points required for next Level: 92
    To retrofit window antenna you will need window assembly with a antenna and antenna amplifier.
    I think it can be done, but rear windows are glued in place, just like a windshield, so it is not as easy as replacing a door window.
    Subaru Legacy GL EJ20 (BH, year 2002)
