Page 5 of 5 FirstFirst ... 345
Results 121 to 131 of 131
Thread: rkrenicki's 1992 Subaru Sambar SDX - 2017-10-06 - Day on a DynoJet!
  1. #121
    10,422
    57,313
    Points: 57,313, Level: 100
    I also decided to get my gauge pod installed. I am not really convinced on the placement here, so I double sided taped this down until I can come up with a more permanent solution. This will do for now and I will readdress this after the RI meet. First step was to trim the gauge pod to somewhat match the curve of the dash.
    Attachment 2476
    The curve is pretty good, but I cannot get it to sit flush on the sides. This is what bugs me the most about this setup.
    Attachment 2477
    This is the end result for the moment. I do not have the vacuum hose run yet nor the wiring connected to the truck yet, but the wiring runs into the dash, and the whole pod is double sided taped down.
    Attachment 2478
    Attachment 2479
    Isn't that in your line of sight?
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1993 Suzuki GSX-R 750
    1998 BK L PARTED
    1991 Legacy SS SOLD
    SLi Facebook
    4Zero1Motorsports Facebook
  2. #122
    Northeastern CT
    2,590
    Oh no, it is quite a bit below my line of sight. The windshield on the Sambar is huge. It is a lot like driving a bus or RV.. just way smaller. You will see what I mean in a week and a half.
  3. #123
    10,422
    57,313
    Alright Sounds good
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    1991 Legacy SS SOLD
    SLi Facebook
  4. #124
    3,405
    http://www.duncanimports.com/used/Su...9c1a13f0c9.htm
    You could a Sambar fire truck to your collection
    My cars:
    2009 Legacy 3.0R Limited
    1998 Legacy L wagon
    2000 Outback- Sold
  5. #125
    Northeastern CT
    2,590
    Ouch! Not for that price.. There are at least 3 Sambar Fire Trucks that I can get imported for well under $5k each. In fact, my wife has had her eye on a Sambar Fire Van for the last month or so, but it is a little too new for import...
  6. #126
    3,405
    Yeah, that place has a lot of really cool imports. But all of them seem overpriced by a good amount.
    My cars:
    1998 Legacy L wagon
    2000 Outback- Sold
  7. #127
    Northeastern CT
    2,590
    Now that the engine is fully broken in, I got him up on a dyno to see how it is performing before doing any engine upgrades.
    This is the 5th pull of the day, up to 7000rpm. (Redline is 7250)
    Dyno graph
    Code:
                          HP                    Torque
    Spec (crank):	55BHP @ 6200rpm        51lbs/ft @ 3800rpm
    Dyno (wheels):	50WHP @ 6400rpm        46lbs/ft @ 3500rpm
    The numbers look good, assuming a 10% driveline loss in 2WD mode. The dyno I used today was a single drum, so I could not test 4WD. Overall, I am very happy with the results as it is spot on to what it should be making. Next step is to try to increase the boost pressure a bit from the 0.5BAR (7PSI) that it is making today. The Vivio RX-R is closer to 0.8BAR (11.2PSI) on the same engine, but does have an intercooler..
  8. #128
    10,422
    57,313
    Engine upgrades?? YES!
    This thing is a BEAST
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    1991 Legacy SS SOLD
    SLi Facebook
  9. #129
    Northeastern CT
    2,590
    The patch that I did on the muffler back a few months ago, didn't hold very long. I ended up buying a new muffler and most of the heat shields as they were not in the best of shape to begin with. The muffler was backordered, and the one that I received was built this month, so they may build them on-demand.
    What I started off with
    Mufflers side by side. I did not buy a new Catalytic Converter as they are extremely expensive.. I just swapped the old one over with new gaskets.
    All replaced, both shields around the flexpipe are new, and the shield under the muffler is new as it was all bent up and rusty.
    The truck is CONSIDERABLY quieter now. I have not taken it for a spin yet as it is storming here tonight, but it is almost shocking how much of a difference there was between the old and new just on startup in the garage.
  10. #130
    SLi nOOb Somac's Avatar
    Feb 2017
    133
    525
    10
    Points: 525, Level: 10
    Level completed: 50%, Points required for next Level: 25
    Tagger Second Class3 months registered500 Experience Points
    Wow! You're going to have a brand new Sambar pretty soon by the looks of it!
  11. #131
    Northeastern CT
    2,590
    Pretty much! I have a new clutch, accelerator, and speedometer cable showing up tomorrow as my clutch cable snapped a couple weeks back and replacing all three at the same time is just about as easy as just one.. I also ordered new front diff mounts, as bad/old mounts apparently kill the front struts and I have brand new struts waiting to go in.
    Once those are done.. that should be it for a while except for messing around with the supercharger pulley at some point.
