Results 1 to 2 of 2
Thread: D Pillar Brace for BK Wagon?
    "FNG" Gavin_XVI's Avatar
    Feb 2015
    Southern California
    42
    2,318
    29
    Points: 2,318, Level: 29
    Level completed: 12%, Points required for next Level: 132
    Tagger Second Class1 year registered1000 Experience Points
    Master Tagger
    Hey Guys,
    Does anyone know of a chassis brace that will work as a D pillar brace on a Legacy wagon? I'm basically looking for a bar that will fit in between the two upper-rear seatbelt guides and mount the bar on with typical C pillar brace mounting hardware.
    XVI///
    "FNG" scoobydo2.0's Avatar
    Jun 2014
    Hitsville USA
    46
    2,229
    28
    Points: 2,229, Level: 28
    Level completed: 53%, Points required for next Level: 71
    I know that there is a brace like what you are describing being available for the Integra and EG/EK Civic HERE, I think I have even seen them being used on the S Chassis 240SX (S13-S15). Whether it will work on our cars is whether or not the cabin width is the same, or close, and then you need to come up with a solution for where and how you plan to mount it to your Subie.
    Personally I would get some thick wall tubing and cut it to fit, tap the ends so that you can run pillow ball mounts (with standard and reversed threads so you can set the tension on the bar) and then find some bolt down tabs I can mount to the chassis to affix the bar...
    2005 BL Legacy 2.5GT (Wife's VF52 powered Grocery Getter)
    1997 BK Legacy GT Wagon (2.1 Stroker Build in progress)
    2004 GD WRX (16G Panty Dropper)
    1991 SW21 MR2 (Camry V6 powarrr)
    1992 1Gb Plymouth Laser RS-T AWD (Unicorn)
Tags for this Thread
