I am a new member of this forum and I'm requesting your help in solving a slipping problem with my transmission. I own a 2002 Subaru Legacy Twin Turbo Touring Wagon. I encountered problems with my transmission and had to open it.
The clutch plates were loose from the plate. I replaced them with other clutches I had from a other transmission. After 2 days it drove perfectly but after that it began shuddering, binding or braking in low gear. In the 3rd and 4th gear it changes normally.
When I arrived home it di not want to go in reverse speed. It can go forward but with low power.
What could be the cause and why did the clutches come loose from the clutch plate ?[/QUOTE]
