Results 1 to 3 of 3
Thread: 98 Legacy Ej20g swap *sold and gone!
    SLi Lurker Bookem's Avatar
    Dec 2008
    Moorhead, Mn
    314
    7,238
    56
    Points: 7,238, Level: 56
    Level completed: 44%, Points required for next Level: 112
    Located in Moorhead, Mn 56560
    1998
    Subaru Legacy Gt 5 speed
    Vin 4S3BD6W6213475X95
    Green paint some flaws, this is not a show car but does look good
    Gray cloth interior in decent condition
    145,000 miles on the car
    Jdm Ej20g engine from manual Wrx sedan (260hp stock)
    The engine has 85,000 miles, ran a compression and leakdown test two years ago and still runs great
    Chipped Z4 ecu wiring harness merge done at Tintmasters
    New timing belt, tensioner and water pump at time of swap
    Td05 turbo, Slanty top mount intercooler
    Blitz blow off valve, Hallman manual boost controller (set at 12psi)
    Sti coils, brand new Subaru OEM green Maf
    Uel header, Hks down pipe, Apex-I N1 3" exhaust
    Koyo racing radiator 2 spal fans
    Group N motor and transmission mounts Exedy Stage 1 clutch
    Phase 2 transmission (easier to weld diff for rear wheel drive)
    Lsd rear diff 4.111 gears
    Kyb gr2 struts with H&R lowering springs
    Front strut tower bar Front and rear sway bars upgraded
    Whiteline rear sway bar links
    New front brake calipers, pads and rotors
    New front axles from RA Axles
    New one piece headlight assemblies, Jdm side marker lights
    Jdm taillights, Jdm fog lights (not hooked up)
    16" stock snowflake rims with Bridgestone Insignia tires 75% tread
    17" Alt Hyper revs powder coated in white, Blizzak tires new last year with less than 2k miles on them
    Clarion cd player w/usb input
    AEM boost, afr and oil gauges
    Compustar 2 way auto start with alarm, temp and volt gauges
    Oil was changed every 2500-3000 miles with Rotella T6 5w40 and Mobil 0w20 in the winter
    The bad
    Sunroof doesn't slide back but does go up
    Left rear strut starting to leak
    Rust spot by left rear wheel well
    Crack in bottom of bumper
    Parking brake doesn't always hold
    Have extra parts to go with including:
    Original Phase 1 Trans
    Jdm Alternator
    Scoop plug
    Spare axles
    Has fresh oil change and full tank of gas
    Looking to get $4500.
    Here is my rides thread that has a lot of info.
    https://sl-i.net/FORUM/showthread.ph...s-and-Radiator
    Dec 2008
    Moorhead, Mn
    314
    7,238
    56
    I have tons more pictures if anyone wants something specific let me know, photobucket doesn't seem to be working well these days.
    Dec 2008
    Moorhead, Mn
    314
    7,238
    56
    Car is sold!
