Results 1 to 3 of 3
Thread: BH5 Manual Antenna options
    Feb 2016
    Austin, Tx
    21
    786
    14
    Points: 786, Level: 14
    Level completed: 86%, Points required for next Level: 14
    2000 Legacy L; the plastic cap/mount portion of my manual antenna is busted and my antenna is stuck in the extended position. While trying to adjust it, I found one of the bolts rusted and broke so now the unit is only held on with one bolt and the antenna mostly out. Furthermore, the area around the bolt hole is rusting too. I want to address this.
    I noticed the higher trim levels of wagon and Outback use a antenna rear left cargo window. Probably not worth the effort to retrofit (is it even possible?), what would be the best way to fix/replace the antenna and rust issue? I have also thought about getting an internal amplified hidden antenna, whether its windshield mounted or hidden somewhere in the car.
    2,678
    The rear glass is glued in. You could have that piece replaced with one from a 2001-2004 car, but you would need someone familiar with automotive glass replacement to remove the old and install the new.
    The pull out antenna is on all 2000 models. Any trim level from 2001-2004 came with the glass antenna.
    Feb 2016
    Austin, Tx
    21
    786
    14
    Ah, that makes more sense. I didn't correlate the year being the pattern as I seldom see an actual 2000 car there.
