Hey all,
I recently replaced my rear camber and toe arms with Godspeed Project arms, and I found that my toe adjustment bolts were so seized that they wouldn't come free at all. I took one of the spacers from the arms to lowes and found a grade 8 bolt that would work. The bolt was a 1/2 - 13 x 3-1/2, it fit perfectly. On my oem toe adjustment bolts, the nut side had one of the oval adjusters that wasnt welded, so i put it on the side that the bolt head to keep it from moving once it was tightened. So far it has seemed to work well for me and was much cheaper than buying new toe bolts.
