So this arrived
Swapped it on in place of the Garrett stock cover. Thankfully it fits straight on and isnt for one of the smaller compressor wheel versions HKS made
Added benefit of being a bit smaller physically so heaps of manifold clearance
So this arrived
Another updoot.
So the rubber line under the car idea was just as annoying as replacing the hardline in the car, so
Completely blocked. Cant even blow through it. Pulled the feed line from my sedan. Yes i made sure it wasnt also blocked. Can easily blow through it and flushed it with brake cleaner as well.
Got back to this stage after a few hours work. Almost like ive done this a few times
Not sure if i mentioned it earlier but my BG specific HKS Super Dragger muffler finally arrived. This cunt is huge
Gave the tip a quick polish
Amazingly it looks like it should bolt up to a stock 25D midpipe. Assumed a TT legacy pipe would be a bit larger
Also cut up a stock 6 speed shift knob for the reverse lockout trim piece and glued it onto my HKS knob to hide the thread left to allow the reverse collar to slide up. I plasti dipped the silver part black for efame
4 day weekend = things getting did
First on the list was getting my shed sorted out. Lots of little jobs means tools and shit gets left all over the place when each little job is done. My shed ended up like a dump. Shit everywhere. Supercheap had a ripper sale of 2 350kg shelves for $130. Considering 1 shelf is $150 its a no brainer. So sorted out all my shit. All of it. Threw out all the useless shit ill never need. Like auto starters (why i have these is beyond me) and the 4 different crank pulleys. Filled 2 whole bins about 3 storage tubs of just junk. Results speak for itself
Put my cool stuff on 1 shelf
Back to cars and parts.
Hub rings finally arrived from Japan. Had to get rays branded ones as I couldnt find any ebay ones for the life of me
Managed to score a shifter surround with mint flocking in the glasses pocket for $9 at pick a part
Chopped the ISO plugs out of the stereo adapter to make it 100x neater
and put the dash back together for the 50th time
Now the real meat and potatoes. 6 speed is out. What a cunt of a job. Such a big heavy cunt just makes everything hard to deal with. Anyway bellhousing off and packaged up to get shipped to Rising Sun Subaru for a speedo drive
After rerouting all of the fusebox area loom so i could get the drivers kick panel on, finally connecting my steering rack to the column and putting the panel below the steering wheel on. I have this
My column shroud has gone walkabout so need a new one of those. Working on getting an OEM ashtray delete pocket from the US and the shifter is obviously on the floor with the gearbox. Happy with the rest but.
Also group n STi exhaust hangers cos why not and proper length pull type STi clutch line
Still waiting on my bellhousing to come back so doing the million other odd jobs that need doing. Starting with a battery tray, which was removed from the wheel tub area by the previous owner. Not ideal but hey $500 gen 2 lol
The solution:
A Jaycar battery tray cut down to fit
and some rivnuts. Job done
The 3rd hole was also going to be used but i didnt realise how far into the frame rail the reo goes lmao. Will pull it out and cut it down a bit one day (probably wont)
Also after being informed the alloy trim rings on momo airbags are removable from behind I bought a black ring airbag from Yahoo. Was hoping to get it air freighted as it has no charge but apparently the Post Office still doesn't like that. Understandably, so container freight and 6 weeks it is
What do they do to fit a speedo gear into a 6mt? I was able to retrofit a gear into an 05 LGT trans without too much difficulty. Everything just dropped in.
Remember how a bought that black airbag from japan?
>B4 comes into pick a part a week later
Just my luck. Anyway headed on over and luckily no one had taken the airbag and the ring was in perfect condition. Pulled the airbag out and indeed the rings are screwed in. They sandwich the badge which is glued on
While I was in the area I helped Joss get remove a gen 4 6 speed from a lucky pick a part score like mine as well. Also got a speedo drive
When i eventually got home having some practice on the B4 wheel had no issues pulling the airbag from the 401 wheel
and swapping over the ring. The difference is huge
before
after
1000% better
Then got under the car and put the bellhousing back on
Wasnt the most fun doing it under the car but didnt want to pull the box out as its a pain to get out from under there
Also put a new donut gasket on the dump pipe thing
Gearbox back in for hopefully the last time in a while. Rob was down for the weekend so paid him in KFC and beers to come and help put it in
Wasnt as bad as i was expecting. Used the engine crane to hold the front of the box up then a trolley jack under the back and some jiggle forking to get it into the clutch. Slid in like butter first try
With the box in we swapped the HEL clutch line out for an STI one and rebled the clutch
And now have a complete interior. Super happy with it
On sunday we had the usual Christmas BBQ
Nice work on this Subaru, look forward to seeing more in!
2010 Red Impreza 2.5i hatchback - SOLD
(Still driving a Subaru now, though)
What a busy few weeks its been.
With a few weeks off over christmas i planned to get the registered and on the road or at least a road worthy. Things started off well; with the gearbox back in and everything hooked up I drove the car out of the shed for the first time and gave it a proper wash
it was now i noticed i hadnt quite sealed up the rear separator plate properly and had a slow drip from the back of the engine. So a metal plate was sourced from a friend and the engine came back out
With that sorted i took the car for its first drive off the block to the servo and a lap of the block. OEM bar is so i dont damage the Syms bar before its painted
Heres where things went down hill. The engine has 0 power. I couldnt even go up hill in 3rd with WOT. A compression test showed 120 psi in the front 2 cylinders. The engine is knackered.
In the meantime i sorted out a number of smaller issues like milky power steering
Drained the reservoir and reseated it onto the pump. Fixed
Airbag light on the dash
This connecter in the footwell as seated but the green bit hadnt clicked in. Fixed
Limped the car to a tyre shop for an alignment. Fixed.
Made the handbrake do something. Fixed
Back to the engine; a local wreckers had a 25D albeit in an un smashed RX. Always worrying
So with the help of a mate went and yanked it out. Engine was full of green coolant so unlikely to have blown a HG. No obvious metal or milk in the sump either so double win. Had 180 psi of compression and my mate found what looks like a dealer tag in the car. So likely a new car trade in sold to the wreckers. Winner
Gave it a quick clean up and checked the timing as it was going in whole to make sure its good
Got it in and fired it up half complete. No rod knock so was good enough reason to finish putting it back together. Filled it with water and found my rad hose had suddenly started leaking
So a new rad hose from SCA and got stuck into bleeding it. Thats when it started knocking lmao
Runs good at idle. 3k rpm~ or so has the beginning of a rod knock
So a bit lost of what to do now and will get back to you when i figure it out lol
Does it have that noise when it's fully warmed up? All my old ej25ds had piston slap when cold, which absolutely disappeared when warm.
The noise was a 10~ minutes into bleeding the coolant so definitely warm
Ah ok. Well I hope you can get your money back.
So instead of actually making the car run again ive been procrastinating with turbo stuff.
Got the 3037 clocked correctly and made the wastegate work ish
Should all work good
Clearance issue with the reg that I fixed with a reg relocation fitting and will install the sard reg i got from the twist mount donor car
After that i got distracted by cleaning the daily Mazda and finally invested in some decent car wash
Normally id get everything powder coated however i want to get some mods done to my cooler piping first as well as use a twin turbo intake manifold for COP so sticking with the STi style manifold for now and going with the everything black theme. So a few coats off gloss black later
​Neato
Low comp engine is back in. Doesnt run cos everything seemed to be fighting me will finish it later
207 on a stand
20K heads on a shelf waiting to go to a machine shop one day
Turbo lettering finished
​kthanx
Sparesbox had a 20% off aeroflow sale sooooooooooooo
new intercooler core as mine was stupidly left sitting outside and open for the last 2 years lol
Coolant fittings for the turbo
-6AN to 8mm fuel hose 90 for the reg relocation
and some black fittings for the fuel reg cos blue is so 2000 in a bady way
Some items that dont make any new progress arrived
OEM Gen 3 S-Edition black roof handles. Gen 3 on the left, painted gen 2 on the right
S2 Legacy Hyper Rev
JDM S2 owners manual cos why not
Tracked down a sump return o-ring from a mate and glued the sump on
And my black airbag finally arrived from Japan so assembled a 9/10 steering wheel i dont need lol
Finally wired up my ricey angel eyes. Theyre white IRL so dont freak out about them being blue
Finally wired up the rest of the headlights feat my thumb
Time for a random assortment of pics of various things that've been did
Fresh still black glove box handle cos gen 2 ones seem to randomly turn white.
Studs back in the 207
Heads picked up from the machinist. Cleaned, decked, tested for cracks and shit. Given the all good with some new stem seals
Head gaskets, oil seals and assorted other gaskets
1x Long block
3rd hand ebay intake didnt have a bov return joiner. Didnt want to spend $20 on an ebay joiner thatll take 6 weeks to get here from china. So cut the end of my jack handle off lel. I havent used it as a jack handle since I got my breaker bar stuck in it years ago lol
Like a bought one
Tidied up a few things and borrowed a stock dump pipe so i wasnt smashing the firewall with smoke and exhaust.
[media]https://www.youtube.com/watch?v=c5g0eb3DAAo[/media]
Currently fighting a turbo oil leak. Have resealed the drain and some fresh copper washers for the feed hopefully kills it dead
Still need some hoses for the header tank to the radiator as my old ones have gone walk about, but with a trip to SCA on the weekend should get that sorted and ready for a test drive
Time for another brain/photo dump.
Turbo started leaking again. This time from what looked like the clamp that holds the ehaust housing to the core i.e terminal failure perhaps. So pulled it off, pulled the housings off and there was no obvious oil leak from either housing. Strange. So gave it a good clean, put it back together and will see if it leaks again.
Pics
Small amount of oil but just above the wastegate port which wont have opened yet lol
Core is covered in oil but turbine is dry
Comparison to my 2835. TD04s are a joke lol
In other news my partner got me a grille from Japan. I think its a "PV4" brand. Shes honestly the best
Finally managed to track down a junction box for the CAMP so got that wired in and connected up
Boost sensor neatly mounted on the strut tower
And testing out Joss' PFC to make sure it works as it was giving him issues. Time will tell if it ends up in my car kek :scratch_one-s_head:
Time for brain photo again.
Been chasing an oil leak from the back of the engine. Ruled out the turbo and started poking around the bellhousing area. Nothing on the back of the flywheel or edge of the bell housing so was confident it wasn't the rear main. Given it was bone dry along with the rear separator when it went in I didnt touch either of them. While digging around the flange for the sump was wet. Given the sump was now on its 3 or 4th install its probably safe to say it wasn't the flattest anymore and likely wasnt sealing so did the un-fun job of getting it out. Found oil on the sealant which thankfully confirmed my theory. With the sump gone i could also get my hand properly into the bellhousing which was oil free as suspected
Didn't find anything sinister in the sump either so bearings are still happy from being started up after sitting for so long.
Ordered a fresh sump which took too long to arrive but is what it is
While waiting for the sump to arrive I went about installing the 1 1/16 master I had modified.
Paid way too much for some M10x1.0 to barb fittings to bench bleed it properly
And in the car
Also finally got my hand brake to work properly
Turns out the cable and pulled out of its bracket and was 10 cm further forward and not held in. Hence not working on 1 wheel. Was stoked as i thought it was a stretched cable and didnt want to deal with it again.
Nothing super important to update.
Spent sunday on my back under the car on ramps making sure everything was properly tight at ride height. Had a few clunks i wanted to get sorted. Most appeared after the alignment so figured theyd left the adjuster bolts loose. Wasnt expecting to find the front strut bolts totally finger tight though :dash2:
In other news someone FINALLY parted out a complete GTB on yahoo so after 2 and a bit years of searching have a GTB rear seat on the way
Also did a crap job of making the front bar white cos why not. Dont look too close lmao
Running out of things to do so decided to stick my pods on. With actual bolts and stuff holding them on this time so even if the tape fails (which it always seems to do) the bolts will hold them on instead of being lost in a gutter
More parts that get me no closer to rego but are cool.
STi speedo and GTB tachometer for a more appropriate redline for the turbo engine
To cut a long story short.
Got car inspected, failed. Then passed again after fixing the issues. Then got rego. Very happy days
Car lasted about 3 days in legal form before modding it.
Turned the boost back up, removed the bov and installed the HKS muffler
Few random pics and stuff from things have been did or doing
HKS actuator heat shield. Probably useless but many cool points
USB socket in the centre console for head unit connections
Retiring the manual boost controller for a HKS EVC. Removed the stock solenoid and put the HKS one there with a rivnut
Lines are about as neat as you can get with a subaru lol. That pod looks damn ugly but it makes cool noises for now
and committed heresy by cutting up an OEM carbon style piece (again) for the controller
