Page 2 of 2 FirstFirst 12
Results 31 to 49 of 49
Thread: rkrenicki's 2010 SH9 Forester X Limited - 2021-05-07 HVAC Controls
  1. #31
    679
    your just like a kid in a candy store
  2. #32
    2,757
    I have no idea what you are talking about.. >.>
    I hadn't put up some updated photos, so here we go.
    Attachment 3426
  3. #33
    2,757
    I've had a couple of busy days. Thursday and Friday was spent wiring up the turn signals on the rearview mirrors. The driver door happened to have two wires to the mirror that were unused, but the passenger side did not and required some wires to be fished through.. I ended up pulling pins out of some old harnesses to play everything "plug and play". I did not take any pictures of the process, but I did change out the temperature scale on the HVAC controls with a metric version while I had the dash apart.
    I had a box arrive from Japan today, which included the Exiga Steering Wheel, Paddle Shifters, Leveler switch panel, and the rear Fog light assembly. The rear foglight was a simple swap, two bolts and swap the LED bulbs over. I need to wire up the rear fog at some point, but the housing is on at least.
    The leveler switch assembly was equally as fast.. Pop the old one out, and pop the new one in. I was going to swap just the switch itself, but this black panel has the logo for the leveler. This also gives me the switch for power folding mirrors if I ever end up doing them.
    I was not in the market to replace the wheel, but it was a 2000 yen bundle which included the wheel, the paddles, and the leveler switch panel all together. Since I am changing out the other parts with black parts.. I might as well install the black wheel as well. I have not yet wired up the paddles yet, but I can get to the plug from the bottom quite easily.
  4. #34
    2,757
    I pulled the seat out today and installed the underseat subwoofer. The Kenwood KSC-SW11 is an almost perfect fit for the stock mounts. I just needed to drill out the bracket holes slightly and remove the foam underneath the carpet right where the sub went. The best thing about these low powered subs is I do not need to run a power wire all of the way to the battery.. Since it only uses a 10a fuse, I have no worries about using a fuse tap.
    While I had the Weathertechs out, I figured I would swap in my old SLI Aluminum Dead Pedal.. I need to get some new clips for it, but it looks pretty good for being 8 years old now.
    I also managed to get the LED bumper reflectors wired up as well. I wired them to the running lights and the brake lights. I was originally going to do turn signals and brake lights, but I changed my mind at the list minute.
  5. #35
    679
    We really need a meet-miss the all the people and cars
  6. #36
    2,757
    I am chipping away at the red text on the first post. Today was wiring up the headlight levelers. It was not a super exciting job, nor do I have really any photos other than during my testing.. but they are all wired up now with a proper harness which is as close to "plug-and-play" as I can make it. Luckily, the switch is the same as the 09-14 STI, so I used that diagram for the job.
  7. #37
    2,757
    Today was a new item to install. I ordered the Automatic Sensing Wiper and Headlight kit from Japan for the SH. It looks to be a somewhat generic kit, but it has some connectors specific to Japanese market SHs. After some minor modification, and using the drill templates backwards.. it is now installed. I still need to tidy up the wiring for the headlight portion, but that can wait a few days. There is an "AT" and an "MT" version, but it looks like the only difference is the length of the harness due to the mounting location of the module.
    I also still need to make some english labels for the switches.
    And lastly, the sun/rain sensor, to the right of the rearview mirror in this shot.
  8. #38
    2,757
    I did a few things in the last couple of days. First up was replacing the front swaybar bushings. The ones I pulled out were likely original and were quite a bit past their prime.
    I also found a grey switch panel with the headlight leveler logo on PartSouq for only $6, so now my dash is back to one color.
    And lastly.. I fixed the odometer on my cluster. Subaru made it exceptionally difficult to get to the EEPROM on these clusters, by forcing you to remove the needles to remove the PCB. I did not want to risk damaging the needles and servos, so I came up with a different solution. I needed to add about 9500 miles, so I rigged up the cluster on my workbench and fed it a 250mph speed signal for a day and a half. I slowed it down to about 100mph last night to make sure I did not overshoot my target mileage, but it is 100% accurate now. Here is a shot of it on my very messy bench.
    And now a shot with the corrected mileage. I started the process at 113,491
  9. #39
    2,757
    Not a whole lot has happened to the car as of late, but there are a few small changes.
    First, My vanity plate finally arrived yesterday. Nothing too terribly exciting, but at least I do not have the "Blitzen 6" plates anymore. I also changed the rear tail lights with European lights, since they have a proper Left Hand Drive rear fog light, even though I haven't done the wiring for them yet. I also need to polish the lights a bit, as they do a have some scratches on them.
    Secondly, I am in the process of changing out the radio. I just bought a Kenwood DMX907S to replace the DDX9904S that I had. They are essentially the same radio, except the 907 adds Wireless Carplay which is a feature that I have been wanting for a while. It does lack a CD/DVD player, but I never used that function anyways. The 9904S is going to go into my SO's new-to-her 2013 Impreza. The radio looks exactly the same as the old one, so I did not take any pictures.
  10. #40
    2,757
    I finally put all of the Subarus in a row today. Finding a time when all of them are home during the daylight is not the easiest thing in the world.
  11. #41
    2,757
    Now that there has been a line-up change at the house.. I will need to redo that last photo in the near future.
    In the meantime, I took off the winter tires since spring has sprung. It gave me a chance to learn how to reprogram the TPMS with my Autel TS508, which is super easy once I figured out the menus.
  12. #42
    2,757
    I ordered up a set of power folding mirrors for a Japanese GH so that I can harvest the motor assemblies. For some reason, proper SH chassis mirrors are $150-200/side in Japan.. while the GH ones were $35 for the pair.
  13. #43
    2,757
    So.. it turns out that GH mirrors are completely different from SH mirrors. The bases are a totally different shape. I guess I will have a set of JDM GE/GH/GV/GR mirrors for sale whenever they arrive from Japan.
    I did some digging and I found one side of the SH mirrors for an excellent price. I decided to go ahead and get the other side at the "normal price", and I ended up getting a decent deal between the two. I am not entirely sure when they will arrive, but it is going to happen.
  14. #44
    2,757
    The left side mirror arrived today. I ordered the non-heated version, since I was planning on swapping the glass around anyways. I sort of wish that I did order the heated glass so I would have convex mirrors on both sides.. but oh well. I completely disassembled both mirrors to transplant the heated mirror wiring, and repinned the new Japanese mirror to match the US style. I have not connected the power fold yet, but it is otherwise ready to go. The mirror was shipped pre-folded, so I used my bench power supply to unfold it.
    This is just before I re-wrapped the harness.
    And this is after the mirror was attached. I have the ground wire of the turn signal connected to the chassis, and everything else is plugged into the vehicle harness. I need to run one wire for the turn signal, but in the meantime I re-pinned the car to get the turn signal working for now.
  15. #45
    2,757
    I ordered the brake pads and rotors to finish up the fronts, and they arrived today. I went with Centric/StopTech GCX coated rotors and Centric PosiQuiet Pro ceramic pads. These things are huge (316mm) and VERY heavy. The shipping box weighs 52lbs!
    I still need to get some new braided hoses before I install these, but all of the mechanical bits are now in my possession.
  16. #46
    2,757
    A few more things arrived for the car in the last week or so. I did run strobe cables up to the front headlights back into the car. They currently end in the back seat footwell until I can decide where I want to mount the strobe pack.
    Thank goodness for the clutch pedal grommet... I still need to shove at least one more cable through here for the two-way radio, and possibly for the headlight washers.
    Next up is the heater controls for a 2011-2013 Forester Touring. I originally bought the module from a Japanese Exiga which is physically the same module, except it turns out that the servos are configured differently and it reversed the temperature scale (hot when at 18c, cold when at 30c), and it reversed the defroster and front vent positions. Oddly enough, the feet position was correct. These controls are also dual-zone, but the car is not capable of that. I disabled the dual button and the second temperature control, so it is a plug-and-play upgrade here. The controls mount into the large "swoop" across the dash, so I had to replace that as well.
    It turns out that between 2010 and 2011, they changed the color of the silver swoop to more of a gunmetal color, so I guess I need to replace the rest of the silver bits to match. I also forgot to order the black plastic cover, so there are a few holes above the controls as well.
  17. #47
    2,757
    Boy.. lots of progress today. I decided to work on the strobe wiring for the rear, and to install some generic Chinese amateur radio that I have since it is small enough to fit within the dash cubby under the radio. I do not have an antenna for it yet, but the harder part was mounting the radio as it required removal of the lower dash. Since the lower dash came off, I also finished the Power Folding Mirrors and the Paddle Shifter wiring since I had plenty of access.
    Also while the tail lights were out for the strobe wiring, I ran the wire for the rear fog light into the car at the same time as well. It does not connect to anything yet, but it is physically inside the cabin now.
    I have not yet decided where the strobe pack is going.. so the cables are just coiled up under the floor for the moment. I think it will end up in the cubby above this spot, but it sort of depends on how I can attach the pack.
    Here is the dash completely blown apart. Lots of things in progress at this point, and even in the end it is only partially reassembled since I am awaiting some replacement panels from Subaru.
    So, to sum up what happened today:
    JDM Power Folding Mirrors - completed
    Paddle Shifters - completed
    Hide-a-Way strobes - more progress.. need to figure out control wiring.
    Rear fog light - some progress.. will finish wiring when strobe wiring is run.
    Two way radio - completed less the antenna.
  18. #48
    2,757
    I did get the rear strobes wired up, and I just need some more connectors to finish extending the front strobe wiring to the trunk. I decided to install the strobe pack underneath the floor inside of the foam insert to try to cut down on the noise from the pack.
    I also received the shifter shroud and some other little bits of plastic trim that were either missing, broken, or scratched. The center console is essentially complete now.
  19. #49
    2,757
    My STI Catalog Shift Knob finally showed up after being backordered for almost 3 months.
    I also finished the strobe head wiring for the hideaways. I still need to rig up the power and control wires, but those should be somewhat easy.
