Bought this outback in June of 2019 as I needed a vehicle to drive as I was in the process of sourcing a new 5spd for my LGT wagon.
395,000KM, Overheats when too hot, but as long as you keep the coolant topped up, its fine!! No overheating issues in the winter.
When I bought it I replaced all the brakes, brake fluid flush and tires, flushed the coolant, new rad cap, new thermostat, new spark plugs, replaced the O-ring on the fuel pump that causes hard starting and fuel pressure issues, did a HID retrofit, JDM tailights with all LEDs besides the turn signals, new windshield, couple new coil packs, replaced the driveshaft, so many things here and there, now at 418,000KM
Ive been enjoying the vehicle quite a bit, I'm thinking about either swapping in a new EZ30 or attempting to replaced the headgaskets in this on.
I also had a new radiator to install, but put it off because I wasnt aware the transmission cooler was a part of it and didnt have any fluid or filters on hand, I'll get to that this spring.
Picture dump time!
