So as i mentioned the other day, I bought my newest project. it was an impulse buy, near the checkout counter.
2005 Legacy 2.5 GT in pearl blue. the owner was asking $2,000 but I talked him to $1500. its a premium edition and in decent shape. He said he couldn't get it to idle and that he thought that the car had low compression on one side. so I shelled out the moola, and rented a trailer I forgot the ball though (those bastards at Uhual made me buy a hitch.) Then I went to the junk yard and pulled an EJ255 from the wrecking yard. I'm not sure how good this one is, but I figured I should be able to make a running engine between the two.
I got it home, and yes the timing is WAY off. all 16 valves are most likely bent. There was also a very bizaar buzzing coming from under the intake. The only thing I could think that would make a buzzing noise in that area would be the throttle body. i plugged my trusty scanner into the OBD port and got a TPS code, a MAF sensor and a air temp sensor code. presumably the cause of the buzzing and no idle. the junk yard EJ255 came with a throttle body, tomorrow I will snag a MAF.
Im not really sure if I am going to fix and sell, or mod and drive... it's kind of nice being able to actually find parts for your project car
