Results 1 to 4 of 4
Thread: Be/bh front control arm bushings?
    56
    4,883
    44
    Points: 4,883, Level: 44
    Level completed: 67%, Points required for next Level: 67
    So, the lower rear control arm bushings in my dd legacy are sacked. The aluminum housing rear bushings. (Its actually a baja, but this one has all the crossmembers, arms, brakes, everything from a 2002 2.5gt)
    Id prefer not to drop $100 on whiteline caster bushings if i dont have to, but i want something that will fit and last. I ordered Amazon repayments, but theyre the taller outback housings. The reviews on the prothane bushings say they dont fit legacies.
    Is there something correct other than whiteline? Or is spending the good money the right answer here? Trying to fix whats worn before new tires, amd since im doing struts too....
    SLi O.G. Muse's Avatar
    Jul 2012
    Willimantic, CT
    2,366
    10,774
    Points: 10,774, Level: 68
    https://www.amazon.com/FEBEST-SAB-BH.../dp/B00R97HJNS
    https://www.amazon.com/20201Fa050-Bu.../dp/B00DMA76D4
    I've got these on the Blitzen6, which, underneath, is an Outback dropped to Legacy height. Should work for you, but won't be any kind of performance upgrade, just not shot.
    56
    4,883
    44
    Perfect! Why i couldn't find those, i do not know. Ordered!
    Mar 2015
    Sydney, Aus
    24
    1,680
    23
    Points: 1,680, Level: 23
    partsouq is also really good for this stuff. Either to purchase from, or find alternate suppliers and PN's.
    https://partsouq.com/en/search/all?q=20201FA060
    https://partsouq.com/en/search/all?q=20201FA050
    Glad you found the febest ones with housings, but pushing in new bushes isn't a huge task.
