I did my timing belt , when I removed the 2 lower smaller pipes , oil was dripping instead of coolant , I believe that is going to the Turbo ,
To make thing worst now the radiator leaks , it did not before the timing belt, I did change the water pump and thermostat , I believe the thermostat was stuck open before the change
does the lower part of the radiator has a separate cooling system just for the turbo ?
Thanks !
