Originally Posted by
Reuben
You don’t have phase-1, so little point in me explaining it for you as it will only confuse the matter. But for the sake of others with phase-1 that might need this, its pretty straightforward.
Once engine is warm, crack the two adjustment screws loose.
Manually blip the throttle by pusing on the mechanism, and listen for what the idle does as it falls back to idle from the blip.
If the RPM’s dip low, and then springs back up, it’s adjusted too low, you need to adjust the IACV cap so that it doesnt dip as low.
If the RPM’s stop and hold too high, then slowly come down to stable idle, its adjusted too high, and you need to lower it down.
Ideal is, as the RPM’s fall, they just immediately settle to the RPM the ecu is commanding, no dips and bounce back, no pausing then lowering.
When you got it to where you blip, and the revs drop straight to the idle point, you’re done, lock it off in that position. If you find that position is greatly different to the witness marks from the old position, this can indicate you have other issues.
What you are setting is the 0 point of the idle controller, the point at which the ECU starts its IACV control at. You are not setting the idle speed itself, only the ECU has control of that.
Back to your car. Yeah maybe inspect the cat. Pain in the arse, but dont forget to look at both the front side and back side.
And yeah, for 02, i can only recommend just diving in and buying new OE. The factory ones are positively ancient at this point, nearing on 30 years of service. Thats a pretty good innings by anyones standards for an o2
