Page 1 of 3 123 LastLast
Results 1 to 30 of 66
Thread: Scan Gauge II by Linear Logic
    13,377
    http://www.scangauge.com/
    The Ultra Compact 3-in-one Automotive Computer
    Scan Tool - Trip Computer - Digital Gauges
    The integrated Trip Computer provides realtime feedback while simultaneously tracking three sets of trip data. The Digital Gauges give you realtime data for your vehicle and the built-in Scan Tool allows you to read trouble codes and diagnose potentially expensive problems before they get out of hand.
    My review:
    A few weeks back I happened upon a group buy (RPM) on LegacyGT.com for the Scan Gauge II (SG2). The price that they offered was the same as retail $160, with free shipping, and if 35+ people ordered we got a discount. When the group buy ended, I had a scanner for $140.
    The SG2 is well constructed, and comes with a long (6 ft) cable that hooks into any OBD2 port. The unit itself has two positions for the RJ45 (ethernet type) plug, one on the side, and one in the back. This gives you a few options as how to mount it in the car. The OBD plug is also nicely made, with a right angle, so it's not jutting out weirdly.
    The scanner works by interfacing with the ECU - so it'll only show the information that is readable by the ECU - if you have a sensor out (or not installed) then it won't show a reading on the scanner. For example, my speed sensor sometimes cuts out, which means my SG2 will read MPH as being 0, even though my tach will still read 2500rpm.
    One thing I did find out though, is that BD/BG cars have a finicky OBD protocol - you have to set the SG2 up to read only "SUPPORTED" protocols, not "ALL". This is noted in the manual, which is quite detailed.
    Until I had set the protocol to "SUPPORTED", my SG2 would switch off every 5 seconds, and refused to clear my CELs. Once I switched protocols (easily done via the mode buttons) things were all good.
    Some of the nifty readouts I like using - volts, MAP, TPS and IGN.
    Manifold Absolute Pressure
    Throttle Position Sensor
    Ignition timing
    (I don't know exactly what the differing values mean, but I know what they values should be when the car is running properly LOL)
    One of the coolest functions that this thing does, is you can change the color of the display. Right now I have it to match the green of the Legacy dash lights.
    For the money spent, and considering that an Actron Scanner costs about the same - you get a whole lot of useful stuff with the SG2, that you don't get anywhere else. You could also work out a custom mounting solution for it, and it works in other cars as well (I just recently used it to diagnose a 2002 Pontiac Sunfire, a 2001 Ford F350 and a 97 Chevy Astro).
    The SG2 gets a big thumbs up from me, and I'm pretty darn picky.
    9,857
    Pretty cool. I want one now
    What's the key for?
    13,377
    Quote Originally Posted by Wiscon_Mark
    What's the key for?
    Size comparison.
    I would take some pics of the my setup, but my camera is borked.
    SLi Resident warrior's Avatar
    Mar 2006
    Toronto, ON
    666
    12,951
    74
    Points: 12,951, Level: 74
    Level completed: 26%, Points required for next Level: 299
    Hey Huffer,
    I want to get one of these as well but I wanted to mount it in the 2nd DIN position underneath my deck.
    I know I'll have to wire up some sort of mounting bracket but width wise, is it too long?
    JD - 2005 Legacy GT LTD Wagon 5spd
    jay-d.com
    13,377
    Quote Originally Posted by warrior
    It's shorter than that.
    It actually sits pretty nice on top of the steering column, and they supply a couple of velcro strips.
    The scanner is so light, you won't need anything other than velcro to mount it.
    Mar 2006
    Toronto, ON
    666
    12,951
    74
    It doesn't get in way of viewing the instrument cluster?
    jay-d.com
    13,377
    Only if you're short, or sit way back, gangsta style.
    Look at the cable - it has an RJ45 (ethernet) connector. Compare that to the size of the unit itself (see pics above).
    SLi Supporter blackgtbeauty's Avatar
    Southern Vermont
    1,305
    12,110
    72
    Points: 12,110, Level: 72
    Level completed: 15%, Points required for next Level: 340
    Idoobaleeve I need one of these.
    -Rob
    SLi Resident ivwarrior's Avatar
    Dec 2005
    lewistown, pa
    518
    8,569
    62
    Points: 8,569, Level: 62
    Level completed: 40%, Points required for next Level: 181
    From the bottom of the "features" page
    Compact Size - just 4.8"W x 1.5"H x 1"D
    From what I've been able to find, DIN appears to be 7x2 inches, so you shouldn't have any problems at all mounting this in a DIN size opening, you'll just need to do a tiny amount of fab work to make it look good.
    SLi Resident dropdfocus's Avatar
    Jan 2006
    NEPA
    532
    9,584
    Points: 9,584, Level: 65
    Level completed: 78%, Points required for next Level: 66
    Yeah, Suby Solutions has this in their newest flyer/catalog priced at $169.99. I picked up a small OBDII scanner from the MAC tools rep for $60, but it has no real time display feed back like the Scan Gauge II. I think I'll be putting my MAC tools code reader up for sale now... =)
    - Jason -
    '92 Legacy Sport "Trixie" - SCCA Solo: Street Modified
    '07 Impreza 2.5i wagon "Zoey" - Daily Driver
    SLi Supporter DLC's Avatar
    Dec 2007
    Utah
    506
    8,426
    61
    Points: 8,426, Level: 61
    Level completed: 92%, Points required for next Level: 24
    Digging up a dusty thread, because I just found out about this thing today.
    There's an update that adds a TON of new features to the unit:
    http://www.scangauge.com/support/xgauge.shtml
    It's free for those who purchased the device on or after July 20, 2007, and $25 for those purchased before.
    info here about upgrade
    Still recommend this Huffer?
    March 2008 ROTM
    Legacy Central
    2001 (BH9) Legacy Outback - DD
    1997 (BG6) Legacy Outback Limited | 1998 (BK4) Legacy L | 2000 (BE6) Legacy GT Limited | 1993 (BJ) Legacy Touring Wagon | 1990 (BC) Legacy L+
    13,377
    Quote Originally Posted by DLC
    Thanks for the info, and yep, I still recommend this. It's been invaluable for me and it's a neat gadget to have around for when I'm doing a long drive or stuck in traffic.
    t3h ub3r m3mber 2.5GT's Avatar
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Points: 12,834, Level: 73
    Level completed: 96%, Points required for next Level: 16
    I've just order one last week. I'll update with pics when i get it
    t3h ub3r m3mber deadlydave's Avatar
    Albany, NY
    1,879
    13,439
    75
    Points: 13,439, Level: 75
    Level completed: 48%, Points required for next Level: 211
    SLi groupbuy?...
    1996 Impreza WRX STI V2 wagon
    Southern Vermont
    1,305
    12,110
    72
    Quite possibly in on that...
    -Rob
    Jan 2006
    NEPA
    532
    9,584
    Ditto...
    - Jason -
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Mine came in early!
    The install wasn't that bad. I had to drill a hole at the center of my bezel and route the wire down to a metal hole, down the the OBD2 port. see pics for details
    Jan 2006
    NEPA
    532
    9,584
    Clean install. I like!!! May just have to copy your idea if you don't mind.
    - Jason -
    SLi Supporter
    May 2008
    Vermont
    787
    7,246
    56
    Points: 7,246, Level: 56
    Level completed: 48%, Points required for next Level: 104
    I've got one now too. I like it a lot although there are some times when it won't turn on with the ignition. I still have to hide all of my wires, but I have it loosely installed in the lower portion of the double-din pocket. I don't think I'll secure it because I store some stuff in there. It fits snugly anyway.
    2007 Subaru Impreza 2.5i Special Edition
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Got to test my out today..and does it cut off after like 10 sec? i constantly have to turn it on. I guess it needed to recalibrate itself...
    here some pics of the colors
    SLi Resident J.McDonald Knives's Avatar
    Jul 2008
    Corpus Christi, TX
    586
    6,964
    55
    Points: 6,964, Level: 55
    Level completed: 7%, Points required for next Level: 186
    I like the red/black.
    97 Subaru Legacy Outback (Totaled)
    http://www.cardomain.com/ride/2184403
    http://s27.photobucket.com/user/PimpinS ... ar/Wrecked
    Jacob McDonald
    210-445-9402
    Studying for ASE Certifications
    AIM: PimpinSquee
    Yahoo: MagicSquee
    SLi Supporter
    May 2008
    Vermont
    787
    7,246
    56
    Yeah mine likes to shut off after the engine has started. Sometimes it seems like if you start it up and immediately try to take off, sending information to the unit, it stays on.
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    I just read the manual, its normal that it goes into a sleep mode. i hate it that i have to turn it on all the time. guess thats the down side of it
    SLi Supporter
    May 2008
    Vermont
    787
    7,246
    56
    I assume you've already changed the PID setting?
    SLi Supporter
    Nov 2006
    Cayman Islands
    1,057
    9,955
    Points: 9,955, Level: 66
    Level completed: 77%, Points required for next Level: 95
    ok just spent 170 Bucks, dont know if i should frown or smile but i will let you all know in 7 days
    [url]http://www.CSN.Ky[/url] - Cayman Islands Sport Car Community
    October 2007 ROTM Winner
    PSN Username - Boxertech
    Regular COD4 and Fifa09 Players
    Dec 2007
    Utah
    506
    8,426
    61
    Saw this featured on an MSNBC video article because it shows you your instant gas mileage. Sales are up over %300 percent since June
    March 2008 ROTM
    Legacy Central
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Quote Originally Posted by 99SUS SFD
    what are PID setting? I just hook the socket up to the obd2 port and it starting connecting with the ECU.
    and my gas mileage was 9999 MPG yesterday
    Jan 2006
    NEPA
    532
    9,584
    Nice!!! Super Hybrid Legacy??
    - Jason -
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    yeah..i think it went into a glitch.. ..but today, It reads that i have about 17MPG ...seems feasible.
    SLi Supporter
    May 2008
    Vermont
    787
    7,246
    56
    In the manual it specifically talks about 1995-1999 Subaru's having trouble. I forget what the change is but it's in the back of the manual.
    I'm averaging 22mpg at the moment.
