Results 1 to 12 of 12
Thread: higher watt bulbs in factory foglights?
    Cone Eater
    May 2006
    NYC
    3,599
    18,003
    85
    Points: 18,003, Level: 85
    Discussion Ender
    Hey everyone,
    I was wondering if anyone has any experience running higher wattage bulbs in the factory fogs (BE specifically, but I doubt subaru changed the wire gauges/relay specs much on other models)? I was thinking of using Hella yellowstar bulbs, which are 85 watts.
    I'll be running 100w's in the Hella driving lights, which has the wire harness to support it.
    2005 Outback XT
    GO > Show. Every time.
    9,869
    Upgrade the wiring, you should be fine.
    Is the lense assembly glass or plastic in the BE fogs?
    Either way, I would think it'd be able to handle the heat fine.
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,456
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    Re: higher watt bulbs in factory foglights?
    I just put 100 watt Hella Yellowstars in my factory fogs. I do have better wires (up until the plug/pig tail to the fog), better relay, and better fuse. The fogs are independently wired. Do you think anything bad will happen if I am just using the fogs when needed?
    My cars:
    2009 Legacy 3.0R Limited
    1998 Legacy L wagon- Sold
    2000 Outback- Sold
    209 NorCal
    1,684
    13,292
    75
    Points: 13,292, Level: 75
    There's a chance of melting the housing if its made of plastic other than that it should be fine. What about doing a 55w hid?
    Moco, Maryland
    3,456
    16,957
    I don't really want to spend the money on a HID. Would 85W have a chance of melting the housing too?
    My cars:
    2000 Outback- Sold
    9,869
    I really doubt you'd melt the housing. I've had no problems with 100watt bulbs in my high beams over the last 3 years. I mean, think about it, you put headlights in the oven and they're fine. Bulbs generate good heat, but I doubt it's in excess of 300 degrees, especially with the car moving and air outside the housing cooling it.
    Cone Eater
    May 2006
    NYC
    3,599
    18,003
    85
    Discussion Ender
    I used 100w bulbs in everything from the stock foglights to the PIAA driving lights I have now for a few years (all running the right wiring harness btw). Never had a melting problem.
    2005 Outback XT
    Moco, Maryland
    3,456
    16,957
    Are the stock fogs on the BE glass or plastic?
    My cars:
    2000 Outback- Sold
    9,869
    I would assume plastic. You don't see many glass headlamps. Should be able to tell by tapping on them.
    MD, USA
    2,617
    17,786
    Points: 17,786, Level: 84
    Community Award
    Quote Originally Posted by 98legwag
    Judging from pictures, the CAN/US '00-'02 non-Outback BE/BH had plastic foglights. The '03-'04 non-Outback BE/BH had glass. I don't know about the Outback.
    Moco, Maryland
    3,456
    16,957
    The Outback is glass. We have a 00 Outback and I have a BG Outback fog light in the garage.
    My cars:
    2000 Outback- Sold
    Moco, Maryland
    3,456
    16,957
    I can now report back that YES 100 watt bulbs in the stock plastic BD/BG/BK fogs will melt/distort the lenses. I took mine off to clean and there is slight distortion in the same spot on both fogs.
    My cars:
    2000 Outback- Sold
