In case you cannot find the connector used, the connector is available new @ NAPA: http://www.napaonline.com/Search/Detail ... 20+2020029 and probably any other place that sells Echlin products.Originally Posted by J.McDonald Knives
Yes, the coil can be clocked in either direction with just the corresponding switch of the 2 outer (trigger) wires.
I know of no one using the MSD igniter pack although it is much cheaper than any of the replacement ones out there. Not sure of the wiring aspect nor compatibility. It ain't quite plug 'n' play.
Don't let the hood scoop bolt bounce on your coil for too long! Or at all really.
