So, my cruise control WAS working the last time i used it. Since then, i have just installed a short ram intake, and cleaned my engine bay. Not that it should really matter... but maybe it will help point you in the right direction. Anyways.. i went to use the cruise control the other day.. the 'cruise' switch turns on and off as normal, but when i press the set button, to set the accel. speed im currently at.. it does not pick up and keep going. Can anyone maybe send me in the right direction as to WHAT may be wrong.. or what to look for so that i can give you more info? Thanks!
