Results 1 to 11 of 11
Thread: TMIC..93 legacy
    Mar 2007
    Mississauga Ont
    4
    5,828
    Points: 5,828, Level: 49
    Level completed: 39%, Points required for next Level: 122
    TMIC..93 legacy
    anyone have experience in fitting a tmic into a series 1 legacy?
    legacy 2.0 turbo
    97 SVX
    Dec 2005
    Ventura County, SoCal
    42
    6,940
    54
    Points: 6,940, Level: 54
    Level completed: 95%, Points required for next Level: 10
    Do a search over here:
    http://bbs.legacycentral.org/
    It is dedicated to the gen 1 leggy's. Some knowledgeable guys over there IMO.
    -Kevin
    cyberbackpacker
    10,361
    57,313
    Points: 57,313, Level: 100
    You most likely will have to bang in part of the firewall. If you get a FXT tmic you will have no problems. That's what I ended up getting.
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1998 BK L PARTED
    Williamsport, PA
    394
    8,390
    61
    Points: 8,390, Level: 61
    Level completed: 80%, Points required for next Level: 60
    I installed a MY02 WRX TMIC in my '92 turbo and you have to relocate the ignitor and wiring harness, rearrange the firewall and ignitor mounting area (bash the hell out of it), cut about an 1/8" to 1/4" off the throttle body and relocate the coolant tank. Then you will also need custom compressor oulet to y-pipe plumbing and DV (diverter valve) plumbing. It can be done and the end result is worth it.
    Good luck!
    -Matt
    1992 Legacy SS 5mt. All go and no show....sold :(
    1996 Outback 5mt. Beater
    1997 Tahoe LT.......sold
    2004 Explorer Limited....loaded.
    2007 Legacy 2.5i SE. Daily
    Mar 2007
    Mississauga Ont
    4
    5,828
    thanks for the replys.
    I'v been to legacycentral.org/ and yes very helpful
    also located a 02 impreza tmic c/w intake hose.
    With the existing wastgate, do I need a BOV, or just close off the opening?
    legacy 2.0 turbo
    97 SVX
    May 2007
    41,000 Feet
    6,041
    Points: 6,041, Level: 50
    Level completed: 46%, Points required for next Level: 109
    I mounted a JDM slanty intercooler from an early WRX into mine. No hammering needed. I moved the coolant tank and the ignitor, but you COULD leave the tank there. My tank had broken a nipple already so I thought it would be safer. Good luck
    -RAD
    '98 LGT wagon, 00 2.5 RS rallycross beater with NO straight body panels
    "FNG" Matt S.'s Avatar
    Sep 2007
    Central, PA
    67
    5,617
    48
    Points: 5,617, Level: 48
    Level completed: 34%, Points required for next Level: 133
    Man, does that bring back memmories! I did that to my 91 SS about 8 or 9 years ago. Worked great, never had a problem.
    -Matt
    '97 5spd GT Wagon
    '06 GT Limited 5spd Sedan
    Williamsport, PA
    394
    8,390
    61
    Quote Originally Posted by Matt S.
    Whoa, is this Shik?
    -Matt
    Feb 2009
    2
    4,376
    42
    Points: 4,376, Level: 42
    Level completed: 13%, Points required for next Level: 174
    Re: TMIC..93 legacy
    An 06 TMIC WILL WORK FINE NO BANGING, AND YOU DONT HAVE TO RELOCATE ANYHTING, JUST THE REAR CENTRE CENSOR, AND THE HARNESS, CAKE. AND THE PLUMBING MENTIOND EARLY ON. I HAVE IT WITH A TD04 AND RESULT hellagood
    SLi Lurker hallowpoint's Avatar
    olympia, wa
    436
    5,895
    Points: 5,895, Level: 49
    Level completed: 73%, Points required for next Level: 55
    Re: TMIC..93 legacy
    i had an 06, 04 and v.3 tmic on my last legacy and they all needed firewall clearance
    myspace
    "wagons haul shit, haul ass" not my wagon
    October 09 ROTM
    30
    4,617
    43
    Points: 4,617, Level: 43
    Re: TMIC..93 legacy
    I can tell you that the 06 fxt intercooler will work better than one from a 02-05 and better than the sti's just on clearence issues. When I swaped between the two the 06 was less laggy. in order for you to run any of these intercoolers you will have to make an extension pipe from the turbo outlet(charge side) to the y of the intercooler inlet.
    My91 legacy sport sedan.
