Page 1 of 3 123 LastLast
Results 1 to 30 of 89
Thread: EJ22T into a BD: What all is needed?
    SLi Resident grayguy's Avatar
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    Points: 10,233, Level: 67
    Level completed: 46%, Points required for next Level: 217
    What all is needed to get an ej22t into a BD and running. I know I need, the motor, turbo cross memeber, custom exhaust, custom IC piping (FMIC) and associated gauges. The things I am not sure about are: Do I need a different fuel pump? And what would be needed as far as the ECU goes? Is it possible to get the Stock Turbo ECU to run the engine in a BD?
    The first stage of this would be done as cheap as possible, hence why I asked about the stock turbo ECU, cause I don't have the money to go fullblown stand alone ATM, and it's not really nessecary on a mostly stock ej22t. Basically, for atleast a while, I would want to be running nothing crazy, just slightly more boost from the stock turbo (or possibly wrx/sti take off?) nice 3inch exhaust, and a FMIC setup. Any and all information is welcome.
    1998 Legacy 2.5GT: Stock to turbo to stock, and given to my Dad, then to my sister that blew it up. Now I've repo'd it and it will once again rise to former glory!
    13,384
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    Yes. I know actually getting it in the car wont be an issue. I'm more concerned with the wiring aspect.
    SLi Lurker AJM's Avatar
    Dec 2006
    NY's version of Siberia
    461
    7,862
    59
    Points: 7,862, Level: 59
    Level completed: 56%, Points required for next Level: 88
    Wiring, I don't know alot about, but yes, you should upgrade the fuel pump ,and if you;re planning on running more boost, maybe upgraded injectors too.
    98 bk?
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    The whole OBD1 motor into my OBD2 car thing is kinda worrying me.
    9,869
    Quote Originally Posted by grayguy
    Minnesota doesn't have emissions testing/inspections do they?
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    no emissions testing here
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    Ok, I just got done talking to my ej22t genious friend about some things, and I have a lot better Idea of what i think I want to do now.
    I'm thinking use the EJ22T short block, and the ej25 heads and intake manifold. I'll build a custom Up-pipe to go to a TD04l turbo. I want to run a FMIC, so that's obviously all custom piping. And all custom 3inch exhaust. I am still not certain on injectors. Some say my 2.5 injectors are the same as the STI pinks, others say I need something else, does anyone know for sure?
    As for management, my friend suggested using MAF Translator with a good AF meter and MAP sensor. That puts me at about $760ish for managment. this management seems very user friendly and has lots of features. He also suggested I use a GM boost control Solenoid ($60 dealer part from the typhoo/cyclone blazers of the early 90's) to electronically control boost. The nice thing about the MAF Translator is I could apparenly tell it that I want a certain AFR and PSI at any given RPM, and the computer would figure out how it needs to adjust the fuel curve to get the desired affect.
    I would hope to begin withrunning around 10psi on this setup, and once I knew everything was going correctly, I would eventually turn it up to the 15-16psi range.
    Thoughts on this setup/idea? Has anyone here run the MAF translator management?
    Boulder, CO
    937
    10,682
    Points: 10,682, Level: 68
    Level completed: 58%, Points required for next Level: 168
    Not sure about your management stuff, I've never messed with any of those. However, I do know that the N/a ej25 injectors are NOT the same as the STi pinks.
    [url=http://www.EastCoastBoost.com]East Coast Boost[/url]
    "Arguing on Nasioc is like wrestling with a pig. The pig has fun and you get dirty" -- Sha_zapple
    Dec 2006
    Duluth MN
    1,494
    9,798
    Points: 9,798, Level: 66
    well we pulled the 22t heads off.. we needed a little breaker bar to get the head bolts off but it worked out fine...
    05 Outback XT - DD
    94 Integra GSR - Track Car
    he was a naughty monkey
    Boulder, CO
    937
    10,682
    saweeet. I can't wait until I'm rebuilding myself an ej22t. What all are you doing to the motor? It looks like it might need a cleaning
    Jun 2005
    Parker, Colorado
    2,631
    16,911
    Points: 16,911, Level: 83
    What are the head bolts supposed to be torqued to?! All these engines laying in a garage is making me antsy to start my project!
    1996 Legacy L wagon
    xbox gamer tag: Krautastic
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    I'm not sure what the heads are supposed to be torqued too, but we seriously needed that much to get them off (keeping in mind that pipe flexed a fair amount)
    I'm going ej22t short block (stock internals for now) with the ej25 heads and intake mani. I already picked up a WRX tmic, and I just bought a 16G (TD05) turbo too. Hopefully this project will start rolling faster after I finish up finals this week.
    Dec 2006
    461
    7,862
    59
    The Sti Pink run in excess of 500 cc's wile...I think 2.5's run around high 3's to low 4's. I know the 2.5 fuel rails are larger than an ej22's.
    Someone correct me if i'm wong on the 2.5 injectors.
    98 bk?
    Dec 2006
    461
    7,862
    59
    On a side note, I love how light subaru motors are. Really, for a guy like me it's no problem to carry 'em around.
    98 bk?
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    I'm pretty sure i'm going to run 650cc SR20 nissan injectors like my friend is doing on his ej22t. I still have to discuss that setup with him though.
    13,384
    Should get that block dipped to remove corrosion. Have the crank balanced too...
    Looks like a great project!
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    For the time being I'm not taking the short block apart. In 1-2 years when i can afford a tranny, it'll get pulled back out and get rods/pistons, and lots of balancing. For now it's keeping the stock bottom end. I will defiently be spending some time cleaning eerythign out the best I can before re-assembly though.
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    Well update time: I got my heads back from the machine shop, I just got my oil/water pump yesterday. I still need to drill/tap my heads and then the motor can go back together. I went with the ACT clutch. Tonight I got my FMIC all figured out, and it's pretty much ready to go. I am also working on the dash and HVAC relocation, but I'm not quite done yet. Here's the FMIC pics:
    "FNG" tekkitan's Avatar
    Apr 2006
    6,741
    53
    Points: 6,741, Level: 53
    Level completed: 96%, Points required for next Level: 9
    nice!
    2000 Subaru Legacy GT Limited
    -Cobb cold air intake
    -Whiteline rear 20-22-24mm adj. sway
    -Borla headers
    -NGK Iridium plugs
    -Powerslot slotted cryo rotors
    -Hawk HPS street pads
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    Dash roughed in:
    Jun 2006
    Hatfield, Pa
    45
    6,629
    53
    Points: 6,629, Level: 53
    Level completed: 40%, Points required for next Level: 121
    how are those gauges held in
    00 RS 5MT 2.5L Red-In drive way
    99 LGT 5MT 2.5L BD Black-RIP
    92 L 5MT 2.2L Black-Sold
    SLi Supporter auspex's Avatar
    Feb 2006
    boise, id
    269
    7,894
    59
    Points: 7,894, Level: 59
    Level completed: 72%, Points required for next Level: 56
    Quote Originally Posted by kkushner4474
    love and tenderness, baby!!!!!
    dear god, let this thread keep alive w/sweet tales of 22t bliss. I'm ready for more power soooo bad and the 22t is the only way that I can tell if you're going to be buying piece by piece.....
    YARRRR!!!! Black 1997 Leg GT - 5mt
    t3h ub3r m3mber Sarra's Avatar
    Nov 2005
    Oregon
    1,592
    11,692
    Points: 11,692, Level: 71
    lmao I love how the circulation controls (heat, ac) look almost like they're a part of the stereo!
    That's a pretty nice shot of the FMIC, low key. Are you going to do anything to prevent damage to it from FOD?
    2002 WRX Wagon, Silver
    Currently saving for a Legacy project car
    "Proby"
    Jan 2007
    Whitman, Mass
    237
    6,488
    52
    Points: 6,488, Level: 52
    Level completed: 69%, Points required for next Level: 62
    Wow. How are you planning to run your IC piping? space is soo tight up there.
    97 Legacy GT Red & Silver-------96 OBS Blue Green Black & Silver
    95 Talon TSI AWD Green 12.9@102-----91 Grand Wagoneer Grey & Woody
    Mar 2007
    Duluth, MN
    939
    10,233
    67
    The gauges are pretty much pressure fit in ATM. I still need to work that out.
    I'm not sure what you mean by "FOD?" But there wont be anything infront of the intercooler if that's what you mean?
    The IC piping. It comes off the FMIC, drops down under the fog lights, bend back up and through the hole in the engine compartment that the stock one goes in. Then on the other side, it does the same except I need to drill a 3'' hole where the battery used to be.
    Nov 2005
    Oregon
    1,592
    11,692
    FOD as Foreign Object Debris or Foreign object damage. Though, it looks like it'll be pretty well protected...
    10,454
    57,313
    Points: 57,313, Level: 100
    What work do you need to do to the heads to make it work with the block?
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1998 BK L PARTED
    Dec 2006
    Duluth MN
    1,494
    9,798
    ^ he just has to tap em for oil or coolant (for the turbo), i forget, one needs to be taped, but one needs to be taped the other you can just remove a bolt for.
    besides that and getting the proper HG its a bolt on affair i belive.
    05 Outback XT - DD
    "FNG" glee60's Avatar
    Nov 2006
    Dulüf, Minnesnota
    6,885
    54
    Points: 6,885, Level: 54
    Level completed: 68%, Points required for next Level: 65
    Umm yay? Why haven't I been involved in this... jerks. :smt076 (Kidding)
    Random teaser of my progress in VW land, I just got my block back it's so cleeeean and so 0 mileish!
    So, Mr Max... I need to have a talk with you about details... I may be getting motor funds verrry quickly...
    Peace.
    '00 Outback Wagon
    '99 BMW 323i
