Results 1 to 25 of 25
Thread: BE Amp wire routing...
    SLi Supporter blackgtbeauty's Avatar
    Southern Vermont
    1,305
    12,110
    72
    Points: 12,110, Level: 72
    Level completed: 15%, Points required for next Level: 340
    So...
    Where's a good place to run the power wire through the firewall on my '01 BE? I looked while I was replacing the airbag wire behind the passenger side dash when i had the glove box and airbag out, but I couldn't see a good spot.
    I'm definitely open to suggestions, as I would like some bumpage in my trunkage.
    -Rob
    SLi Supporter MoclovFlop's Avatar
    Aug 2006
    Arvada, CO
    339
    7,475
    57
    Points: 7,475, Level: 57
    Level completed: 63%, Points required for next Level: 75
    There should be a rubber plug (possibly covered by foam/carpet) behind the brake pedal. I used that for the temp sensor when I had my digital compass. If you look in your engine bay, you'll see it about 1.5 feet directly below the brake booster.
    You can only get so far with a warm spoon
    Dial 5 for teH Niteclub!
    SLi Lurker Brockley's Avatar
    Nov 2006
    Blackburg, Va
    337
    7,120
    55
    Points: 7,120, Level: 55
    Thats how I ran mine... then THROUGH the deadpedal (it was convienent, and made it so I couldnt mess it up)
    then under the white plastic next to the doors (Brake lines and such)
    97 LGT Wagon
    SLi Supporter badbasser98's Avatar
    Upstate NY
    1,475
    14,186
    77
    Points: 14,186, Level: 77
    Level completed: 34%, Points required for next Level: 264
    I can try and take pics of mine... I'm not going to tear everything back apart though
    ~Matt
    '15 Ram 1500 Sport Crewcab
    '06 STi w/full bolt ons
    SLi nOOb HFSDevil's Avatar
    Parker, CO
    170
    8,743
    62
    Points: 8,743, Level: 62
    Level completed: 98%, Points required for next Level: 7
    I ran mine passenger side and tucked it WAY up then under the side sill and under rear seats. Worked out good for me.
    2002 Subaru Legacy L
    Co-Founder of 5150 Krew
    SLi nOOb studum's Avatar
    Jan 2007
    Cambridge, Ontario, Canada
    119
    6,269
    51
    Points: 6,269, Level: 51
    Level completed: 60%, Points required for next Level: 81
    + 1, through the empty service gromet behind the brake pedal, down driver's side under the sills, under rear seat into trunk. Used rear seatback brace as a ground.
    Ryan - 2000 LGT Limited - Swapped to 5spd
    "FNG" 2000LWAGON's Avatar
    May 2007
    northern nj
    86
    6,088
    Points: 6,088, Level: 50
    Level completed: 69%, Points required for next Level: 62
    in my car i have it coming from the battery to out by the pedals under the carpet to the door sills and then out behind the back seat to where i have amp sub and capacitor.
    -M@
    2000 Legacy Wagon
    May 2007
    northern nj
    86
    6,088
    pretty much identical the guy before me but mines a wagon. ground under the back seat.
    -M@
    2000 Legacy Wagon
    9,857
    I wouldn't be surprised if the BE had that same empty grommet with a plug in it as the BD/BK/BG does. Check out my writeup, check out your car.
    "FNG" tylerkroh's Avatar
    Dec 2011
    schuylkill county PA
    2,513
    30
    Points: 2,513, Level: 30
    Level completed: 43%, Points required for next Level: 87
    Re: BE Amp wire routing...
    im bringin this back because i would like some pics please and thanks
    Dec 2011
    35
    2,459
    30
    Points: 2,459, Level: 30
    Level completed: 6%, Points required for next Level: 141
    This is perfect I want some pics of be installs!!!
    Dec 2011
    35
    2,459
    30
    Well guys I have some 1/0 I'm trying to run and it doesn't seem like it'll fit in the door sill... If I run it under the plastic it gets blocked at the a pillar. ):
    t3h ub3r m3mber 02_Legacy's Avatar
    UP of Michigan
    1,142
    9,186
    64
    Points: 9,186, Level: 64
    Level completed: 46%, Points required for next Level: 164
    yep I just ran some 4 gauge for a new setup that I was putting in and I just barely got it through the section between the front and rear doors, so I doubt that you are going to get 0 gauge through there. If you aren't too worried about hiding it just skip that section and go from the front door sill to the rear door sill and leave it exposed between there. If you do want to hide everything... good luck. The only thing that I can think of is run it down inside of the center console and then under the carpet between the console and the back seat.
    04 RSTI
    98 Legacy Outback
    Dec 2011
    35
    2,459
    30
    I was going to do the console but i thought it'd be too close to the source stuff. Me and my buddy took out the front and rear seat and some how managed to get it ran. It does however bulge the carpet by the trunk release and the seat making the seat not move as freely. The question im having is i ran the wire under the seat and through the Velcro for the middle fold down. Did you guys do it like that or down the side?
    UP of Michigan
    1,142
    9,186
    64
    I ran it under the carpet then I cut a small hole in the carpet, just big enough for the wires, right where the amp is. It creates a clean install, less visible wires.
    04 RSTI
    98 Legacy Outback
    Dec 2011
    35
    2,459
    30
    Is your amp under the front seat?
    UP of Michigan
    1,142
    9,186
    64
    No I am talking about the carpeting in the trunk. I ran the wires under the bottom of the rear seat and under the back of the rear seat, and then under the trunk carpet and then just up right by my amp. The only place you can see the wire is the small distance from the trunk floor (where it comes through the trunk carpet) to where it connects on the amp.
    04 RSTI
    98 Legacy Outback
    Dec 2011
    35
    2,459
    30
    Ok well where the back of the back seat goes down did you run it where the other car wires are or did you run in inbetween the back of the back of the back seat and under the carpet?
    UP of Michigan
    1,142
    9,186
    64
    Ok my seat is still apart because I have to run a new RCA cable. Anyway I snapped a few pics for you:
    Here you can see it lay across the bottom of the seat and go under the back part of the seat
    Closer pic of the wire going under the seat. There are 2 or 3 bolts that you have to take out to pull the seat away to feed the wire under it.
    And here it is coming up in the trunk, the carpet is pulled back, usually the carpet covers this.
    04 RSTI
    98 Legacy Outback
    Dec 2011
    35
    2,459
    30
    wow thanks man I really appreciate that! I think i need to move mine over like yours it comes out in the middle of the trunk. Now I'm worried about the trunk release. I'm not sure if it's just the quarter size wire putting pressure on the cable or if i messed up something trying (never succeeded) to take it off. Now it wont automatically go back down on it's own. You have to push it back down. Any thoughts?
    Dec 2011
    35
    2,459
    30
    Can I get a pic of where you put your ground at 02_legacy?
    UP of Michigan
    1,142
    9,186
    64
    You can just barely see the ground at the bottom left of the last pic I posted. It goes to the stud that comes up from the strut mount
    04 RSTI
    98 Legacy Outback
    Dec 2011
    35
    2,459
    30
    if i unscrew that screw will it unalign something or does it have to tighten so much?
    9,857
    I used to run one of the strut tower bolts - no, nothing will misalign if you only remove one bolt. But don't drive it that way - retighten it.
    Or if you're that worried about it, just find another nut to put on there and sandwich the terminal in between them.
    I actually ended up using one of the bolts for the cargo tiedowns. I don't know if the BE's have those though.
    Dec 2011
    35
    2,459
    30
    By the way do you have pics of the finished install or care to say what all you put in? It looks like you got a bass knob wire there also.
    I was going to put mine in between the back of the back seat bracket and the body of the car but didn't know if it would get crushed.
