Page 2 of 2 FirstFirst 12
Results 31 to 37 of 37
Thread: general swap pricing (ECS)
  1. #31
    Cone Eater
    May 2006
    NYC
    3,599
    18,003
    85
    Points: 18,003, Level: 85
    Discussion Ender
    Quote Originally Posted by decke48
    2750-950(just for wiring)=1800-400 most for gaskets and hoses= 1400 for just labor for a motor swap... its only a 8hr job (book rate) to replace the motor. that $175 a hour for labor... at they labor rate of $75 an hour you should at least get 18 hours of work done just for mechanical. when we swaped my friends GC8 we only spend 9 hours doing the full drivetrain swap... mechanical wise
    You should set up your own shop. You'd make a killing then.
    yeah the bad thing is me and wiring.. dont like it.. maybe just because i just did a 20 hour wiring harness on a toyota highlander..
    Yeah, that's why ECS started the mailorder wiring merge option...Paul was telling me how they found a nice niche in the market that no one seemed to have thought off.
    Send the wiring harnesses to them and just do the mechanicals yourself to save a lot of labor costs.
    Quote Originally Posted by 1-3-2-4
    How hard is a harness from a wrx engine being put into a 98 BD? I work with electronics tv's and PCB's all I would need is a pinout guide?
    It's not hard, it's just very tedious. It also depends on which year WRX/STi you're getting your parts from...IIRC the 02's were the easier to swap into the older models because of some sensor differences.
    Though I know there's some people that just do the 12 wire splice thing...not the most thorough, but I guess if you just want to get the engine to turn the wheels...
    2005 Outback XT
    GO > Show. Every time.
  2. #32
    SLi O.G. 1-3-2-4's Avatar
    Dec 2007
    Greenwich, CT
    2,202
    15,480
    80
    Points: 15,480, Level: 80
    wow mailorder merge.. sounds good.. All you would be doing is sending in the wires from the new engine you want to swap in right? Or do I have to send some parts from my model for them?
    back
    3 4
    1 2
    Front
    97 Legacy Outback Wagon
    <--- 252,xxx miles!
  3. #33
    Cone Eater
    May 2006
    NYC
    3,599
    18,003
    85
    Discussion Ender
    You send both the new engine and your car's harness to them and they'll do the merge for you. Putting it back together is on you.
    2005 Outback XT
  4. #34
    Dec 2007
    Greenwich, CT
    2,202
    15,480
    80
    Quote Originally Posted by rougeben83
    bah gotta send the engine in.. might as well just drive and drop it off then pick it back up.
    back
    3 4
    1 2
    Front
    <--- 252,xxx miles!
  5. #35
    SLi Supporter blackgtbeauty's Avatar
    Southern Vermont
    1,306
    12,110
    72
    Points: 12,110, Level: 72
    Level completed: 15%, Points required for next Level: 340
    zomg 2jz w/ nawz swap in tha hillinder!?!?
    -Rob
  6. #36
    Cone Eater
    May 2006
    NYC
    3,599
    18,003
    85
    Discussion Ender
    [quote=1-3-2-4]
    Quote Originally Posted by "1-3-2-4":1bf3apml
    bah gotta send the engine in.. might as well just drive and drop it off then pick it back up.[/quote:1bf3apml]
    Engine's harness
    If you're in CT, there's a couple of shops that do the swap...but IIRC they just have the wiring harnesses done through ECS anyway, or if they're busy they'll actually just tell you to go to ECS yourself.
    2005 Outback XT
  7. #37
    Dec 2007
    Greenwich, CT
    2,202
    15,480
    80
    Ah ok I was about to say...
    back
    3 4
    1 2
    Front
    <--- 252,xxx miles!
