Page 1 of 2 12 LastLast
Results 1 to 30 of 47
Thread: SCCA Autocross: Need your car classed? RIGHT HERE
    t3h ub3r m3mber deadlydave's Avatar
    Albany, NY
    1,879
    13,439
    75
    Points: 13,439, Level: 75
    Level completed: 48%, Points required for next Level: 211
    Hello again. This thread has one point and one point alone, SCCA autocross (Solo II) classification.
    Link to SCCA Rulebook 08: http://www.scca.org/documents/Solo%2...lo_Rules_2.pdf
    Post the following, and I will help you figure out where you belong:
    Car Year
    Car Make
    Car Model
    Engine Mods
    Suspension Mods
    Wheels/Tires
    If you have removed any interior pieces
    If you're anything like me, you modded your car and then decided to autocross. I got screwed because of my hood, for instance.
    1996 Impreza WRX STI V2 wagon
    SLi Supporter Mr. Sociable's Avatar
    Sep 2007
    Lakewood, CO and Bozeman, MT
    479
    6,612
    53
    Points: 6,612, Level: 53
    Level completed: 31%, Points required for next Level: 138
    Here's some more help!
    More on Categories…
    CLICK ME
    And:
    "Listed below are some common modifications governing the classifications. For all classes, review
    the SCCA National Solo Rulebook.
    Stock
    Legal In Stock
    -Cat back exhaust
    -Upgraded shocks/struts
    -Upgraded spark plugs and wires
    -Upgraded brake pads/brake fluid/lines
    -OEM airbox filter upgrade (airbox can’t be changed)
    -Aftermarket wheels must be OEM size, and offset
    -Racing harnesses (except convertibles)
    -Dot race tires
    Illegal In Stock
    -racing seats
    -larger wheel than OEM
    -aftermarket steering wheels
    -cross drilled rotors
    -aftermarket air intakes
    -aftermarket rear anti-roll bar
    -modified computer chips
    -lowering springs
    -modified throttle body
    -aftermarket headers
    -modified turbo or boost
    -modified cams
    -missing interior parts
    -ground effect kits
    -aftermarket super-charge/
    -turbo kits/NOS
    Street Prepared
    Legal In Street Prepared
    -Unrestricted exhaust system
    -Lowering springs
    -Camber adjustment plates
    -Aftermarket swaybars/links
    -Aftermarket ignition control
    -Aftermarket air intakes/racing seats/Harnesses/steering wheels/shift knobs
    -Aftermarket wheel sizes/dot race tires
    -Spoilers meeting SCCA requirements
    -Intercooler upgrades
    -Aftermarket strut bars
    -Modified computer chips non boost related
    -Unrestricted intake, carburetors or fuel injection
    Illegal In Street Prepared
    -aftermarket turbo
    -boost control system
    -pop off or blow off valves
    -gutted interiors
    -NOS systems
    -carbon fiber hoods
    -ram air kits/body mods
    Street Touring
    Street Touring cars must be 49-state emissions legal, have at least 140 tread wear rated tires, and meet the following restrictions:
    STS: Minimum of 4 seats and seatbelts, maximum of 7.5 inch wheels and 225 tires, maximum engine displacement of 3.1 liters without forced induction, no limited slip differential other than OEM viscous type. Some small turbo cars are specifically allowed.
    STS2: STS rules, but for two seat cars up to 1.8L, excluding ‘99+ Miata, ‘91+ MR2 and Spyder, or anything that says Lotus! Viscous limited slips only.
    STX: Minimum of 4 seats and seatbelts, maximum of 8 inch wheels and 245 tires, engines of up to 5.1L normally aspirated or 2.0L single turbo or supercharger. 2WD cars may use any limited slip, AWD cars must use standard limited slip differentials in axles and center. If an AWD car did not come with any limited slip differential (including center), one aftermarket limited slip may be added. Some performance 4 seat cars specifically excluded.
    STU: Displacement limits? We don’t need to stinkin’ displacement limits. Unless you have a turbo, of course, then the limit is 3.1L. Tires limited to 275 for 2WD, 245 for AWD. No wheel width limit. Otherwise, STU follows STX rules.
    Legal In Street Touring
    -EPA legal exhaust header
    -Cat back exhaust system
    -Camber plates/kits
    -Aftermarket sway bars/mounting
    -Strut bars, upper and lower
    -Drilled and/or slotted brake rotors (OEM diameter in STS, larger in STX/U)
    -Upgraded brake pads / fluid / lines (DOT)
    -Aftermarket wheels
    -Ground effect kits (over stock fenders)
    -Intake systems up to stock engine inlet (OEM throttle body or turbo inlet)
    -Pedal kits
    -Fully upholstered seats, not lower than driver’s head
    -Non-metallic alternate suspension bushings
    -Shifter kits
    -Alignment specs are free
    Illegal In Street Touring
    -removal of catalytic converter
    -body structure mods for air intakes
    -engine displacement changes
    -removal of emission controls
    -cars not registered for street
    -NOS systems
    -fender flares or wheel well mods
    Street Modified
    So you don’t like rules? You’ve come to the right place! Of course, there are a FEW rules…
    SM: Minimum of 4 seats and seatbelts. Up to 6.0L displacement, with minimum weight depending on engine size and intake. Some cars specifically excluded.
    SM2: All 2 seaters, except that Lotus Badge thing, or cars excluded from SP category. Unlimited displacement, minimum weight based on displacement and intake. Cars underweight for SM displacement/weight rules.
    All SM and SM2 vehicles must have original road equipment: lights, heaters, wipers, interior and such.
    Legal In Street Modified
    -Engine swaps, block must be a production unit from the same brand as car
    -Suspension components are free, as long as they use stock attachments
    -Rear seats may be removed
    -Steering components other than original Column
    -Subframe connectors
    -Suspension bushings
    -Any DOT tire, any size
    -Twin turbo, nitrous injected, 3 rotor peripheral port, AWD, independent rear suspension Mazda Proteges
    Illegal In Street Modified
    -Chrysler Hemi Subarus
    -Jet turbines
    -Anti-gravity systems"
    ***I give all credit to this work to the Colorado/Continental Divide Solo division, as taken from their 2004 "Newcomers Guide to SoloII"***
    2005 Saab 9-2x
    Xbox Live gamertag: MrSociable - Forza 2, Halo 3, CoD4, and CoD5
    SLi Lurker Brockley's Avatar
    Nov 2006
    Blackburg, Va
    337
    7,120
    55
    Points: 7,120, Level: 55
    how about my 84 RX-7 that has a 5.0 Small Block, no other mods except for the fuel pump to make it run...
    EMod right?
    97 LGT Wagon
    Albany, NY
    1,879
    13,439
    75
    Quote Originally Posted by Brockley
    EMod right?
    I'd say you might be in Street Mod 2. We have a swapped wagon that runs in my region as SM, but they have a ton more mods. Also, they have 5 seats instead of 2.
    Sep 2007
    479
    6,612
    53
    Quote Originally Posted by deadlydave
    EMod right?
    The engine isn't a Mazda engine, so he's going up from SM2. Either Emod (I think...) or a prepared class.
    2005 Saab 9-2x
    SLi Supporter Grafton's Avatar
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Points: 12,386, Level: 72
    Level completed: 84%, Points required for next Level: 64
    ground effect kits <- huh no lights on the bottom of your car?
    2007 Impreza WRX STi
    2012 Impreza 2.0i Premium CVT
    Sold 1997 Legacy L Sedan, 2.5L 12:1 Compression Hybrid, The 'Lego'
    RIP - 2005 LL Bean Outback, The 'Bean' & 1999 Impreza Outback Sport
    Albany, NY
    1,879
    13,439
    75
    Quote Originally Posted by Grafton
    No, the original meaning of 'ground effect kits' is 'body kits'. think front lip, side skirts, rear lip.
    SLi Lurker ShadowGT's Avatar
    Nov 2008
    3rd Coast Texas
    376
    5,774
    Points: 5,774, Level: 49
    Level completed: 12%, Points required for next Level: 176
    Re: SCCA Autocross: Need your car classed? RIGHT HERE
    Interesting. I was actually considering SCCA, I live fairly close to Houston and I know they do stuff there. Of course, I still need to get some mechanical issues resolved before I start flogging my car.
    I wonder, I suppose with my intake system I fall in the street prepared division. But I'm curious if removing my hood scoop block plate is considered as a ram air induction because I'm not using the stock air box but a cold air intake.
    But this endeavor will be awhile off. Still need to chase my ECU problems around.
    98 Legacy GT. Kartboy LW drive pulley, KB short throw shifter, KB front / rear shifter bushing kit, KB stainless shift knob, Cosmo Racing "Custom" CAI, SpeedyRacer (thermal taped) UEL, K&N cone filter, K&N Dry Filter, Exedy Street clutch, Fidanza LW flywheel, Group N engine mounts, GN pitchstop, GN rear diff armor, GN strut top hats, ebay front / rear strut bars, KYB GR2 struts, paranoid fabrication ground kit, N1 axleback. Falken Sincera tires, Konig Zero wheels, Brembo Rotors, Stoptech SP Pads, Lots of little custom mods. 160,000 miles.
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    how about my car
    97 subaru legacy L
    all stock execpt snokus delete, lightweight crank pulley and gutted 02 wrx muffler
    outback rear sway bar, gt 2 pot fronts 16" snowflakes
    nothing removed from the interior
    Sep 2007
    479
    6,612
    53
    how about my car
    97 subaru legacy L
    Those brakes are going to mess with your classing. Most local regions would probably let it slide and allow you to run in STS. You're technically in SM I believe since they aren't original calipers on your car. I would email your local region and see if they'll let you run in STS.
    2005 Saab 9-2x
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Quote Originally Posted by Mr. Sociable
    how about my car
    97 subaru legacy L
    really the breakes giving the most trouble, i figured the sway bar would be the most trouble...
    Dec 2006
    Duluth MN
    1,492
    9,798
    Points: 9,798, Level: 66
    well looks like my integra will never be a competative auto crosser haha
    05 Outback XT - DD
    94 Integra GSR - Track Car
    he was a naughty monkey
    Sep 2007
    479
    6,612
    53
    how about my car
    97 subaru legacy L
    Your brakes wouldn't be a problem if you had a GT to begin with. I know you can completely update your car to GT specs, but it has to be EVERYTHING, which is tons of work. Since the GT was offered with those brakes, your local region should let that slide, you'll just have to ask. I'm not sure on updating just one part, but I don't think it's allowed. Swaybars are a pretty common item in auto-x racing.
    2005 Saab 9-2x
    13,377
    Car Year Make Model: 1998 Subaru Legacy GT wagon AWD 2.5L
    Engine Mods: Lightweight crank pulley, headers, catback exhaust, 96 GT factory intake, snorkusectomy.
    Suspension Mods: lowering springs, KYB GR2 struts (OEM spec), 22mm RSB, front and rear strut braces, Hawk HPS pads (front)
    Wheels/Tires: 16x7 205/55/16 Kumho Ecsta (OEM size and offset...for an Impreza RS)
    Full interior, factory front seats swapped for 06 STI fronts, 02 WRX steering wheel w/ SRS airbag.
    Short shifter
    My guess is Street Prepared.
    Sep 2007
    479
    6,612
    53
    EDIT:
    Huffer -
    You're completely fine in STS except for this rule:
    D. Alternate steering wheels are allowed except that steering
    wheels with an integral airbag may not be changed.
    I'm not sure what "integral airbag" means, but if it means what I think it does then you're F-ed. I would say that as long as the airbag in the WRX wheel still works and it looks good you should be fine.
    2005 Saab 9-2x
    13,377
    Nice. yep the SRS airbag in the WRX wheel is the same as the one in the stock wheel. Should look very stock.
    Jun 2005
    Parker, Colorado
    2,631
    16,911
    Points: 16,911, Level: 83
    1996 Subaru Legacy L 2.2l w/5spd manual
    Engine mods: snorkus delete, neon coilpack, lightweight crank pulley, grounding straps, catback exhaust
    Suspension mods: eibach pro kit springs, KYB GR2 shocks, subaru outback 18mm rear sway bar (stock is a 14mm)
    Wheels/tires: 16x6.5" 2.5RS wheels (stock is 14"), 205/55/16 Falken Ziex 512's
    No visual exterior/interior modifications besides JDM lighting and grill.
    1996 Legacy L wagon
    xbox gamer tag: Krautastic
    Sep 2007
    479
    6,612
    53
    Quote Originally Posted by Plays_with_Toys
    Other than having no idea what a neon coilpack or grounding straps are, you're in STS. I also know for a fact that if those provide no significant gains, the STS guys should be fine with letting you run locally here in CO.
    2005 Saab 9-2x
    Jun 2005
    Parker, Colorado
    2,631
    16,911
    Have you ran STS in colorado? If so, what's the competition like? As for the neon coil pack, it's simply that. A dodge neon coil pack rated at 34,000volts compared to the 28,000 volts stock on the legacy. It's just a step down from an MSD ignition coil at 35,000 volts. But no. No appreciable difference besides being slightly more peppy and alot more smooth. The grounding straps/grounding kit was a debated item for a while. SCCA never really clarified if it was a class changing mod. That was a year or 2 ago, wasn't sure if the ruling had been made yet.
    1996 Legacy L wagon
    Sep 2007
    479
    6,612
    53
    Then you'll be fine running in STS. I've never run in that class myself, I've met a guy named Mark who runs in a 2.2 Impreza and there's some dude in a newer 2.5i too. Otherwise, it's full of pretty damn well prepped civics mostly and it's a fast class. I know in X class there was a fast as f*ck STS civic too. If you're a decent driver, you'll do ok.
    2005 Saab 9-2x
    SLi Resident evolegacy's Avatar
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    Points: 6,755, Level: 54
    Level completed: 3%, Points required for next Level: 195
    ok this has me curious about mine, so let me toss my 2 cents in and find out what class I would be part of.....
    1998
    Subaru
    Legacy GT
    Engine
    8mm Spark Plug Wires
    Weapon-R dragon Intake
    Custom 2.5" Magnaflow exhaust system
    2.5L UEL Headers
    Suspension
    Totally Stock
    Wheels & Tires
    OEM 98' GT wheels
    Goodyear Eagle RS-A 205/55R16 91H
    Interior
    A-Pillar Gauge pod
    Volt Gauge
    EGT Gauge
    AFR Gauge
    3.5" Tachometer
    OK thats what I have so far, if you could give me the classification for that setup that would be cool, if you want to classify what im about to post you can do that too. I am going to post the future mods that I plan for the car and hope to get done before the meet this year.
    Engine
    Hyper Ground Wire Kit
    Nology Spark Plug Wires
    Nology Spark Plugs
    APEXi SAFC NEO
    MSD Ignition Coil (8239)
    W-R Secret Weapon Intake System
    W-R Cold Air Box
    Group-A throttle Body Spacer
    Group-A Pitch Mount
    Group-A Lightweight 2 pully kit
    EJ25 Stage I DOHC Camshafts
    Spring/Retainer Kit DOHC
    Rotors & Pads
    Power Slot Front and Rear Slotted Rotors
    EBC Red Stuff Pads (Front)
    EBC Red Stuff Pads (Rear)
    Suspension
    Cusco front Strut Tower Bar Type OS
    Cusco Rear Strut Tower Bar Type OS
    Cusco Rear Lower Arm Bar
    Perrin Rear Adjustable Sway Bar Kit
    Perrin Front End Link kit
    Perrin Rear End Link Kit
    STi Sport Lateral Link Set 6-pc
    KYB GR2 Struts
    Exhaust System
    OBX Impreza 2.5RS EL Headers
    Stromung Hi-Flo Cat Pipe
    Stromung Cat-Back Pipe/Muffler
    Surprisingly all of this is only going to run me a little over $6,500, but its because i want to keep this build strictly N/A, afterall, N/A is better than turbo HAHAHA.
    02 WRX wagon 5spd MT Daily Driver
    98 2.5 GT 4AT RIP
    99 2.5 GT 5spd MT RIP
    00 2.5 GT LTD 5spd MT RIP
    SLi Supporter jey's Avatar
    Texas
    1,663
    10,971
    Points: 10,971, Level: 69
    Header will put you into STS.
    The proposed mods look allowed in STS except camshafts - I think that bumps you to a higher class.
    - Jey
    1995 Legacy Wagon EJ257 turbo
    2011 Tribeca Limited EZ36
    Sep 2007
    479
    6,612
    53
    ^ Bingo. I'd look into the spring/retainer kit as well.
    Otherwise it looks like a well sorted STS car suspension wise.
    2005 Saab 9-2x
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    ya im going to add that kit in along with the cams when i get around to picking them up
    98 2.5 GT 4AT RIP
    Sep 2007
    479
    6,612
    53
    Quote Originally Posted by evolegacy
    I meant that the kit (as well as the cams) will bump you up into either FSP or SM. I don't know which.
    I would skip on the cams/kit and do everything else. You'd have a great local STS car.
    2005 Saab 9-2x
    Albany, NY
    1,879
    13,439
    75
    Oh God, if at all possible stay out of SM. I'll go back through the rulebook tonight, is the 09 one out yet? FSP probably wouldn't be too bad. I know locally, there are almost no protests and we kind of 'trust you' to help us class you. If you are slow or hit a lot of cones, nobody will protest anyway. :smt002
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    lol ok so you think i should skip the cams then? hm...well, it is pricey, main reason i was getting them was for added HP for the drag.
    98 2.5 GT 4AT RIP
    Albany, NY
    1,879
    13,439
    75
    Ultimately it's about what you want to do with the car. If you want more power, totally go for it and have fun at autocross. If you want to win or trophy in a class, you have to mod a car to the maximum allowable for a class, and SM is very expensive. So, if you're just doing it for fun, to push your car, I say mod the crap out of your car and class be damned. If you're a competitive person and really want to do well, then you might wanna mod towards a particular class.
    Nov 2006
    Blackburg, Va
    337
    7,120
    55
    I run XP now... lol
    97 LGT Wagon
    t3h ub3r m3mber 2.5GT's Avatar
    Mar 2006
    Fascist state of VA
    1,881
    12,834
    73
    Points: 12,834, Level: 73
    Level completed: 96%, Points required for next Level: 16
    I would also like to know where I fit in
    Car Year: 1998
    Car Make: Subaru
    Car Model: Legacy
    Engine Mods: Injen short ram, ground wires, header + exhaust, stock cats.
    Suspension Mods: H&R springs/ KYB struts
    Wheels/Tires: BBS 17X7.5/ 215/45R17 Fuzion ZRI
    Note: Will be using a harness without rollcage.
