Page 1 of 5 123 ... LastLast
Results 1 to 30 of 149
Thread: DIY: Installing MSD Coil 8239 MY96 2.5GT
    Jul 2008
    Scappoose Oregon
    148
    5,962
    Points: 5,962, Level: 50
    So today I decided to install the MSD 8239 Coil pack on to my Phase 1 EJ25D.
    I took some pictures and I followed liquidracing's method so I'm going to copy it from the huge MSD thread and post it here.
    so, i was going to go with all MSD, and i will. for now though, i opted for a nice little neon coil. picked it up for 40 bucks with a connector. here is the low-down on the neon "upgrade"(three pin ONLY, haven't done foot work on four pin yet) Rolling Eyes
    1)if you look at the two coils side-by-side, arranged with the connector to the left(just like if it were in the car, you at the front, looking at it, facing towrds the firewall), you will see the two "bumps" on the coil pack laying horizontally, with spark plug ports out either side. these are the individual "coils". there is a port in the middle on the left side, with 3 pins in it.
    2)with these factors still inplace, walk around to the passenger-side of the car, staying at the front quarter-panel(driver's side for you east pond drivers). look at the connector port on the coil. you will see three pins. from RIGHT to LEFT, they are numbered 1, 2, 3, respectively, although there is no formal inscription of any kind on the connector, or port.
    3)cut the connecter off your car between the snap and the coil pack, prefferably closer to the pack as i want you to throw it away when your done. Shocked remove coil and connector from your car.
    4)take said connecter that you just cut, and lay it down next to the neon connecter. throw away the coil you cut the connector off, it's pretty much just a paperweight now. Cool
    ready for the fun part? Very Happy
    5)the connector diagrams are the same, EXACTLY! wiring-wise anyway.
    yeah, it's that stupid simple!
    6)looking at the pins, on the neon connector, they are read from LEFT to RIGHT:1, 2, and 3(the reason it's not the same as the port, is that it's a mirror image of the pins on the port)
    7)looking at the pins on the subie connector, they are read from RIGHT to LEFT:1,2 and 3
    8)pin 1 is for cyl numbers 1 and 2
    9)pin 2 is "12v signal in"
    10)pin 3 is for cyl numbers 3 and 4
    11)literally take the neon connector and subie connector and connect the wires, number for number: 1 to 1, 2 to 2, 3 to 3. now you have a universal connector/adapter to use on your msd, accel, or neon coil, without killing the wiring on your car, although the subie coil has to give it's life for this connector. Very Happy
    12)just plug into the neon coil and your off.
    wow, this is sounding like a diy, but, is it? i mean, yes and no.
    Now on to the pictures, just follow the method quoted above completely and install with the MSD facing towards you so the harness port is facing the drivers side, which is opposite the way it is on phase 1's. I installed it facing the right way and the car just backfired when I turned it over. The bolts are M6 x 2". Also if you have a phase 1 block, you'll need later wires I believe from a phase 2 so I purchased NGK wires for a 1999 Legacy GT, they fit perfectly.
    1997 Subaru Legacy 2.5GT 5MT
    - Borla replica, custom 2.25" catback stromung track pipe 20" vibrant streetpower
    - MSD 8239 Coil Pack, NGK wires/plugs.
    - KYB AGX Whiteline Control springs
    - Whiteline adj anti-roll bars F/R
    13,384
    Nice... I might have to try this out myself. So your driving impressions?
    Jul 2008
    Scappoose Oregon
    148
    5,962
    Put this in today and had the tank topped off so I'll see what my MPG are over the next week or so.
    Starting: Starts up about the same as before, perhaps a little quicker but it's more sure of itself and doesn't ramp up to 1500 rpm like it used to. Goes up to 1000 or so now.
    Idling: Smooth, perhaps moreso than before, minimized hesitation I was having off idle sometimes.
    Driving: Got my low end power back, I already have a lightweight flywheel so I have to rev more than a car with a stock flywheel when taking off from a stop. Driving around town @ 25MPH I BARELY have to have my foot even touching the pedal and the car maintains speed. Then I ever so slightly, like a few mm's move the pedal down and I pick up speed. Throttle response has improved quite a bit. Got more ooomph in 5th on the highway as well.
    Power is smooth throughout the band and revs higher easier/smoother and pulls harder in the upper RPM's than before. It basically pulls harder everywhere in the powerband moreso now than with the stocker on there. My car is also smoother now, less vibration from the engine especially in the lower RPM range.
    Sound: Exhaust is more prominent, I expected that because now I'm getting a cleaner more powerful combustion and you hear it in the exhaust. Sounds a little more beefy now like it's got something under the hood.
    Martin and Big Rapids. MI
    168
    5,241
    46
    Points: 5,241, Level: 46
    Level completed: 46%, Points required for next Level: 109
    Cool. Its nice to have detailed pictures. Defiantly need to do this soon.
    1997 Subaru Legacy GT
    190k miles
    Jul 2008
    Scappoose Oregon
    148
    5,962
    Your welcome.
    This is definitely an easy mod, the wiring is about as straightforward as it gets; I'm a beginner at wiring. It's very useful with stock subaru maps because they're on the rich side from the factory so I expect a rise in MPG from this.
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,027
    16,569
    82
    Points: 16,569, Level: 82
    Is there a difference between the a stock neon coil and the fancy red MSD? Is one better than the other?
    I figured from reading the giant thread that flat pins are better, so I would be getting the coil with flat pins regardless.
    Here's the MSD I was lookin' at: http://www.shop.speedunlimited.com/Shop ... rid/126429
    Jul 2008
    Scappoose Oregon
    148
    5,962
    If I remember correctly the Neon coil is very close in power to the MSD, but the MSD is still more powerful.
    PM Reason, he'll hook you up
    Sep 2008
    Ft. Collins, CO
    2,027
    16,569
    82
    Thanks for the reply, I'll check with Reason, hopefully I have enough in the budget for this mod.
    Guest
    what do these things do???
    Jul 2008
    Scappoose Oregon
    148
    5,962
    Quote Originally Posted by Zues Marine
    Provide a more powerful spark in your ignition system which means more complete combustion which translates into more power and better MPG.
    Sep 2008
    199
    5,211
    46
    Points: 5,211, Level: 46
    Level completed: 31%, Points required for next Level: 139
    iirk, the msd is 40000v and the neon is 34-36000v.
    Sep 2008
    199
    5,211
    46
    winston, did you ever use your coupon to buy the large herb chicken mediterranean deLite pizza?
    Nice job. me likey! and yes, i have verified, to myself, a mpg rating that is +3-5mpg average. this is over the course of 4 tanks of 87oct, from the same shell station(yeah i know bush owns stock in shell , but, it's GREAT gas!) no additives, except the seafoam i did two weeks ago(after tank#2) i think that actually netted the extra 1-2mpg overall, afterall.
    2-3mpg for the msd
    1-2mpg for the seafoam
    no matter. Winston856 FTW!
    good job.
    Sep 2008
    199
    5,211
    46
    "I installed it facing the right way and the car just backfired when I turned it over"-winston856
    oh, shyte! did i have pins 1 and 3 reversed? because mine faces to the passenger side. i'll have to review the topic. whoops?
    Jul 2008
    Scappoose Oregon
    148
    5,962
    Quote Originally Posted by liquidracing
    You might have, it's all buttoned up and working fine so I'm not gonna change it. However it would have been nice to install it the other way
    Oct 2008
    Concord/pittsburg California
    85
    5,045
    45
    Points: 5,045, Level: 45
    Level completed: 48%, Points required for next Level: 105
    I just finished doing this to my 96' 2.2L. Well I stole the coil from the junkyard (yes yes, shame shame) and I got the plug wire ends free. But I accadently took the wrong connector, so I went back this morning and got the right one for 5 bucks. So total it cost me...well, 5 bucks.
    As for the coil, I love it. It feals like I just added a bigger throttle bodie or sumpthin. :-)
    Northern california MILLWRIGHTS local 102
    91 black golf GT-I
    Mar 2008
    7
    5,062
    45
    Points: 5,062, Level: 45
    Level completed: 56%, Points required for next Level: 88
    Re: Installed MSD Coil 8239 MY96 2.5GT (liquidracing method)
    I just did this yesterday. Ended up being like $75 for the MSD pack and $2 for the connector at the junkyard. The bolts from the Neon worked fine to mount the MSD pack, but only one hole lined up. Going to get a metal plate and make an adapter soon.
    This was a very easy mod, took me (with no real electrical experience) about 2 hours to do. I used a hacksaw to cut apart the old coil and take the connector off (mine was actually attached to the coil and not on a wire to it) so I could make an adapter and not actually cut the car's harness. Soldered everything together and made sure there was shrink wrap and electrical tape around all the bare wires, and it plugged in fine. I made the mistake of crossing wires 1 and 3, but just flipping the pack 180 degrees fixed that.
    Now, hopefully this will fix my misfire issues , the coil is the only thing I haven't checked and/or replaced in the air/ignition system so far.
    10,455
    57,313
    Points: 57,313, Level: 100
    hmmm I'm wondering if maybe I wired up the coil wrong, maybe that's why I'm having engine knock.
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1998 BK L PARTED
    Mar 2008
    7
    5,062
    45
    Well, assuming you have the middle wire correct, there's really only 2 ways to wire it. One way won't work at all and one will be right.
    10,455
    57,313
    Yea thats what I did. One way didn't work I switched 1 and 3 and it fired up. I was wondering since I have the coil on reverse would it mess with the firing order.
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    Oct 2008
    85
    5,045
    45
    This will work on a 95 impreza 1.8 right. My friend just picked one up with a broken clutch fork for 800 bucks. Drove it home 70 miles. Its a project for sure tho.
    91 black golf GT-I
    Mar 2008
    7
    5,062
    45
    Hmm, i have my coil on reverse to what everyone else has been doing and it's working fine...
    I don't really think that would change anything in the order, one wire fires 1 and 2, and the other fires 3 and 4. if you mix up the wires and rotate the coil 180 degrees I don't think that would cause anything bad to happen. You could always redo the wiring and turn it back and see if that helps...
    10,455
    57,313
    Quote Originally Posted by KnifeyMcShanker
    That would be a good idea, but it's too cold for that lol. The problem is recent, so I doubt it might be the problem, it was a thought.
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    Sep 2008
    Ft. Collins, CO
    2,027
    16,569
    82
    I wired my neon coil in reverse so the plug faces the passenger side; It worked perfectly the first time. I just switched the two outside wires. (Yellow to Black - Red to Green - Blue to Blue)
    I will have to try it the other way and see if there is any difference.
    Nov 2008
    Davis, CA
    176
    5,187
    46
    Points: 5,187, Level: 46
    Quote Originally Posted by winston856
    So, does that black plug come with the pack?
    Is that the plug off a phase 2 like you stated above?
    Is that a plug for a neon that you spliced to work with the car's plug?
    I think my distributor is going bad so I'm bumping this thread
    99 30th anniversary BD legacy 2.5GT (current) used JDM ej25 replaced at 135,814 mi.
    00 Impreza 2.5rs (RIP) sold as-is...
    89 Bronco II (Still running "knock on wood" for Off road) for where even my subie can't go
    SLi Resident iampetro's Avatar
    Nov 2007
    600
    9,482
    Points: 9,482, Level: 65
    Level completed: 44%, Points required for next Level: 168
    double bump
    love the diy but need some "for dummy's" questions answerd.
    where does the coil go?
    what does "neon" coil mean?
    when doing this is it easy to change spark plugs at the same time?
    please and thank you
    :smt026
    SLi O.G. decke48's Avatar
    Feb 2008
    TF Mass
    2,322
    10,706
    Points: 10,706, Level: 68
    Quote Originally Posted by iampetro
    double bump
    :smt026
    1) right in the middle of the intake manfold where the stock one is
    2) the coil is designed for the dodge neon
    3)change the plugs on subarus is taking the washer bottle out and the intake box to get access to the plugs. its not hard just a different way to do it
    98 2.5gt
    MA.N/A 413
    Sep 2008
    Ft. Collins, CO
    2,027
    16,569
    82
    So after 6 months with the neon coil, I have noticed that the ECU seems to be adjusting to the increased fuel burn, and adding more fuel and thus I am getting slightly worse mileage. I wonder if there is any way to "tune" this correction out without a full blown EM.
    SLi Supporter jey's Avatar
    Texas
    1,663
    10,971
    Points: 10,971, Level: 69
    You can try a piggyback fuel controller like an S-AFC, though the ECU seems to learn around that too at times.
    - Jey
    1995 Legacy Wagon EJ257 turbo
    2011 Tribeca Limited EZ36
    Sep 2008
    Ft. Collins, CO
    2,027
    16,569
    82
    What about a RRFPR? Or is that only for forced induction?
    Texas
    1,663
    10,971
    Indeed it is. As the name implies the Fuel Pressure Regulator increases fuel pressure as manifold pressure increases.
    - Jey
