Just a quick update. Been running the dis2 w 8239 coil on my 96 outback for approx 2 mos now. I noticed that the mpg didn't go up as much as I was hoping for, I was only getting about 2 mpg over what I normally get if not the same. Then about 3 weeks ago I noticed that when I run between 3000 or 3500 or more rpm I get a misfire. Called tech support and they think I'm experiencing some arching and advised me to change the el cheapo autolite plug wires I'm using. They said I should be using wires that do not go above 800 ohms. Today I got a hold of a set of Accel superstock spiral ignition wires (supposedly at 500 ohms). Didn't get a chance to have it checked with an ohm meter, just took a leap of faith and installed them. Feels a lot better with the Accel wires on but I'm not sure if it's a psychological thing, the response felt better but I will see if the mpg will also improve. Will check back in with hopefully good results. Peace!
