Page 8 of 8 FirstFirst ... 678
Results 211 to 228 of 228
Thread: anothernord's '97 OBW, 12/8 - Fab projects, rally wheels
  1. #211
    SLi O.G. Muse's Avatar
    Jul 2012
    Willimantic, CT
    2,382
    10,774
    Points: 10,774, Level: 68
    Re: anothernord's '97 Turbo OBW - 3/14 - EJ257 Hybrid WRX Sw
    That is pretty sweet, man... 330 HP would be more than enough to get me in trouble!
    Also, really diggin' the bumper. Did you use a GT bumper or an Outback bumper, or does it matter at all?
  2. #212
    SLi nOOb Oc7ane's Avatar
    Jan 2013
    Portland, Oregon
    168
    4,677
    43
    Points: 4,677, Level: 43
    Level completed: 64%, Points required for next Level: 73
    1000 Experience PointsVeteranRecommendation Second Class
    Sweet build, Im basically doing the same thing but with a stroked 22t block, wrx heads with harness merge and what not. Sweet deal with merging yourself, I wont touch that part
  3. #213
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Points: 16,569, Level: 82
    Quote Originally Posted by Muse
    I used an outback bumper cover, and fabbed up my own beam for the JDM fog lights. I wanted those things so bad that I built the entire bumper just so I could have them!
  4. #214
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Oh, and pics here:
    http://www.sl-i.net/FORUM/viewtopic.php?f=13&t=28487
  5. #215
    SLi Resident prodriver1's Avatar
    Nov 2009
    Minnesnowta
    901
    8,083
    60
    Points: 8,083, Level: 60
    Level completed: 67%, Points required for next Level: 67
    Re: anothernord's '97 Turbo OBW - 5/14 MANLIEST STRUT BRACE
    I want a strut brace like that. Hell, you could probably sell 'em if you had the inclination.
    ya! I'll buy one!
    if I wanted to lower my car I'd have gotten a GT!
    outbacks go UP^
  6. #216
    SLi Supporter 65pontiac's Avatar
    Apr 2011
    LI, NY
    74
    3,297
    35
    Points: 3,297, Level: 35
    Level completed: 65%, Points required for next Level: 53
    Wow very clean
    Sent from my Galaxy Nexus using Tapatalk
    2019 Outback 3.6r Limited, 18 WRB WRX base - sold, 16 CBS FXT Touring - sold, 13 Tangerine Orange Pearl WRX SE - sold, 13 SWP Outback 3.6r Limited Special Appearance Package, 11 Spark Silver STi sedan limited - sold, 05 Brilliant Silver LGT, 99 Glacier White LOB, 96 Orange Legacy L wagon - sold, 65 Teal Turqouise
  7. #217
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Big update: DUAL RANGE!!
    So I finally finished college and got my degree in Mechanical Engineering (phew). It was about time to give the wagon a well-deserved upgrade: an AUDM dual range 5MT pulled from an 03' Forester. I found it on eBay through one of the JDM importers.
    Over a long weekend, I installed along with a matching 4.11:1 LSD from an RS.
    It turns out that making a linkage to operate the low range shifter arm is quite a task. The OEM cable was chopped part way, and some old throttle cables I had around were not nearly stiff enough to move the lever. I found a B&M racing 4' auto tranny shifter cable through O'reilly's and made some brackets for it.
    Here's the tranny side arrangement:
    Ever wondered what that little circular rubber bump in your shifter seal is for?
    Dual range cable!
    I ghetto-fabbed a lever using an old stock shifter cut down to size.
    All that's left is a little trimming and making a cover for the hole.
    This tranny gives the overall ratio a bump by 1.447:1. It will absolutely chug up steep rocky hills; little to no clutch slipping. You can't crawl as slowly as a true 4x4 rig, but if you're on terrain where you need to go that slow, you're probably going to have other issues.
  8. #218
    "Proby" dynonacht's Avatar
    Jan 2014
    Farmington Minnesota
    242
    3,565
    37
    Points: 3,565, Level: 37
    Level completed: 44%, Points required for next Level: 85
    Re: anothernord's '97 Turbo OBW - 8/9 - Dual Range 5MT
    Awesome! Hey, probably somewhere in this thread but I suck at skimming pages, what center console is that?
  9. #219
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Quote Originally Posted by dynonacht
    It's a WRX center console. See the link in my signature.
  10. #220
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Some more updates:
    Nokian WRG2 tires (225/65R17) on Sparco Terra 17x7.5's.
    These things required rolling of the fenders, trimming of the unibody, and some pounding of the wheel wells with a hammer. These are 28" wheels. Same a stock XJ Cherokee! I managed to get away without using wheel spacers on all four corners. Even with fender rolling, there is still some rubbing in the rear. I plan to fix this with King springs.
    I made a quick master cylinder brace out of some 1/4" plate and and angle iron. It really stiffens the pedal under hard braking. Before, you could actually watch the master cylinder move when the pedal was pressed.
    Since the unibody is slowly falling apart, I decided to build a real rear strut brace. Bolt-on rear strut braces really don't do a whole lot; you've got to remove the extra degree of freedom that allows the strut towers to move vertically relative to each other.
    First, I welded a bar to the floor, with some 1/4" uprights for bolting the brace in. (Excuse diarrhea welding)
    Then, the stringer between the two braces, and the triangular braces. (Finished product was painted)
    Results? Not sure on handling or anything like that, but it sure quiets down all the creaking. Maybe it will help with rear passenger safety?
    Oh, and here's the trailer hitch I made. I thought that the bolt-on ones suck.
    It's welded into the stock bumper beam, bolts into the tow hooks, and to the unibody frame rails with 6" long bolts that go all the way into the inside of the trunk.
    APS TMIC, Kinugawa TD05H 20g, 8cm, STS 9 blade turbine
    Some random pictures from the summer's adventures around CO and WY.
    "4WD High Clearance Only"
  11. #221
    "Proby" KNaph's Avatar
    Oct 2013
    Tacoma, Washington
    229
    6,116
    Points: 6,116, Level: 50
    Level completed: 83%, Points required for next Level: 34
    5000 Experience PointsVeteran
    Re: anothernord's '97 OBW, 12/8 - Fab projects, rally wheels
    Wow. I never knew I needed this, but I need this.
    The cut bumpers for clearance gives it a sort of rock crawler look and the Sparcos and beefier tires really help bring that look together too. Looks like you're clearing the struts by just a few hairs haha.
    Definitely subbed.
    "You ruined your car" - Dad
  12. #222
    SLi nOOb Alphius's Avatar
    Aug 2009
    Rochester, WA
    149
    6,489
    52
    Points: 6,489, Level: 52
    Level completed: 70%, Points required for next Level: 61
    This is a great swap and I really like seeing what you've done to the car over the years. The documentation is excellent and I can tell you really intend to keep this car for a long time.
    I'm about to start my own harness merge for my '99 Legacy GT, so your pictures and documentation have helped me immensely. I'm no stranger to engine harnesses having built many MegaSquirt harnesses for different swaps and LS1 ECU standalone harnesses, but the Subaru integration of the body harness with the engine harness leaves things a little more complicated. I do have an entire donor '02 WRX, so at least all my wiring will come from the same car!
    I'm curious on a couple aspects of your swap: What have you done for the clutch and for the radiator/fans? I'm keeping a push style clutch (like your DR trans) and have been debating between doing the 06+ WRX flywheel and clutch or shelling out for the ACT HDSS. As far as the radiator goes, I was planning on using my stock radiator and gutting the cap to use the overflow connection as the connection to the coolant tank, but I also have the WRX radiator and fans available to me if they would be of any help. Thanks in advance for any input you may have.
    99 Legacy GT WRX - Now for sale!
    05 Legacy GT Limited 5MT Wagon - Stock-ish.
    02 Outback Limited 5MT - Lifted, Dual Range
    84 Camaro Z28 - LS1/6-speed
    85 Silverado - Low and slow tow rig
  13. #223
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Whoa, haven't updated this for a while, I've been busy with my other thread for the twin charge build.
    Quote Originally Posted by Alphius View Post
    Figured a late reply is better than never! For the clutch , I used an 06/07 WRX Clutch and flywheel, with the stock push-style fork and slave cylinder. My TOB is from the TSK snout repair kit, so it's a little bigger in diameter than the stock one and pushes on the teeth nicely. For fans I had to use an aftermarket one mounted on the front of the A/C condenser. And thanks for the kind words!
    And for the update, here's the current state of the engine bay:
  14. #224
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    This thread needs some updates and more pictures.
    I have been daily-driving with the twin-charge system, which is now drinking E85 for more power.
    Engine bay shot:
  15. #225
    Jul 2012
    Willimantic, CT
    2,382
    10,774
    Err... The lower two pictures aren't showing up.
  16. #226
    Jan 2014
    242
    3,565
    37
    Quote Originally Posted by Muse View Post
    same
  17. #227
    Nov 2012
    Novato California
    26
    12,703
    73
    Points: 12,703, Level: 73
    Level completed: 64%, Points required for next Level: 147
    Veteran10000 Experience Points
    Downloads
    Cool ass ride man!
  18. #228
    Jan 2014
    242
    3,565
    37
    updates?
