just gonna say ty ahead of time cuz this will come in so handy while I'm replacing burnt out bulbs in mine. And prolly just recoloring while I'm in there anyway.
1991 Honda Accord EX (263k-267K) Totaled by Deer
1995 Honda Civic LX (91K-130K) Sold, to many issues.
2001 GT BE 5 speed MT (123K-137k) Sold
2005 Subaru Legacy GT Limited 5MT 117k I joined the Turbo'd side
http://badges.fuelly.com/images/sig-us/355586.png
Good luck! Just did my centre console ones, love the results
Yes officer, I did hit a pedestrian, but instead of dwelling on that why not focus on how many I've missed?
What u do to urs? Change the color up in guessing?
Yeah, gone blue. Check my ride to see how it looks so far
So, I did not read through this whole thread to see if any one has come up with anything definite for the cruse/ fog switches but I have found something that works. The NEO3-x bulbs kinda work. They are not a perfect fit in the fact that they do not twist and lock in like the stock sockets do. They are a very tight fit however, tight enough that after I forced them into their place I am not afraid that they will fall out. This is a viable choice for anyone looking for LED lights for the cruise/fog switches.
Here is a link to the bulb that I ordered, the 3mm (T-1) is the size you need.
https://www.superbrightleds.com/more...panel-led/220/
02 Legacy GT BE 5MT now with boost!! SOLD!
04 RSTI
98 Legacy Outback
They sure are tight!! The problem I had with these bulbs is they were so tight I couldn't remove them (damn polarised bulbs!!!!!) and ending up having to pull the whole fog light switch apart. End result 3 wrecked led bulbs and now have no lighting in my dash or HVAC Hoping like hell it's just a fuse
ouch... Tough break... I hope so too for ur sake that it's just a fuse!
haha yep I had to take the switch apart to turn them around but I didn't ruin the bulbs. I also ended up blowing the fuse lol. The fuse is in the the fuse box to the left of the steering wheel, you have to remove the little storage pocket to get to it. Then it is a 10amp fuse, the very bottom middle I believe. The diagram calls it the "illumination" fuse.Originally Posted by Snow Wolf
04 RSTI
98 Legacy Outback
I found that when I did my LEDs in the 97 that the sanding drum on the Dremel was my best friend. I just spun it around the base a few times to make them a little smaller and I cut the little bump off the side attaching things to allow the LED to turn in. Anyone who has seen the LEDs and the original bulbs will know what I mean.Originally Posted by 02_Legacy
I also used the FSM illumination circuit diagram and a 9 volt battery with a pigtail attached to check that the LEDs were installed correctly at the dining room table, long before they got to the car.
Regardie
1997 Legacy L sedan 2.2 auto - crushed by a tree during Sandy
All upgrades stripped and returned to stock, started up when they hauled it away
New to me 2000 Legacy GT Limited sedan 5 speed 180K miles
184K and running on a JDM Bilstein struts and springs set and a replacement RS 5MT
187K, engine top half rebuilt, Delta 1500 cams, PNP, converted EJ252 to EJ251 for Delicious Stage 1 flash
190K worked out some engine issues with the swap, now Cobb EL headers and High Flow Cat and mid pipe, muffler shop axle back
Was a fuse!!! TF for that! Still, destroyed the leds so gotta place another order now
Have done all HVAC bulbs, cig lighter ring, ash tray, glove box and door lights now. What a relief, HVAC stopped working, thought I'd cooked it but was just a fuse LOL
Just an FYI, these dashlight LED's burn out after 1 year. My HVAC are still gong strong, as are my puddle lights, but the cluster I've had all 4 go after about 1 year each. SuperbrightLEDs will ship a replacement, but it's kind of a PITA. For me the look is worth the effort, but buyer beware
Hi,
What are the LED bulbs for the turn signals and all the warning lights? Also what are the correct fitting fog/cruise LED bulbs?
Thanks much!!
Originally Posted by blackstar
what bulbs would you use to light up the shifter?
Is there any way to bring the images back for this DIY?
+1Originally Posted by xezey3sx
Doh! All pix dead.
Just getting g into this in my BD. But also wondering if I can put LEDs in the instrument cluster and HVAC b/c of the dimming feature on that circuit. . .
